Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Philosophy, Gurus, Controversy and Evolution
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 18th February 2000, 09:37 PM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Lightbulb Demonstration Of Pavlov's Theory of Bureaucracy
Subject: Demonstration Of Pavlov's Theory of Bureaucracy
Start with a cage containing five monkeys. In the cage, hang a banana on a string and put stairs under it. Before long, a monkey will go to the stairs and start to climb towards the banana.
As soon as he touches the stairs, spray all of the monkeys with cold water. After a while, another monkey will make an attempt with the same response -- all of the monkeys are sprayed with cold water. Keep this up for several days.
Turn off the cold water. If, later, another monkey tries to climb the stairs, the other monkeys will try to prevent it even though no water sprays them.
Now, remove one monkey from the cage and replace it with a new one. The new monkey sees the banana and wants to climb the stairs. To his horror, all of the other monkeys attack him. After another attempt and attack, he knows that if he tries to climb the stairs, he will be assaulted.
Next, remove another of the original five monkeys and replace it with a new one. The newcomer goes to the stairs and is attacked. The previous newcomer takes part in the punishment with enthusiasm.
Replace the third original monkey with a new one. The new one makes it to the stairs and is attacked as well. Two of the four monkeys that beat him have no idea why they were not permitted to climb the stairs, or why they are participating in the beating of the newest monkey.
After replacing the fourth and fifth original monkeys, all the monkeys which have been sprayed with cold water have been replaced. Nevertheless, no monkey ever again approaches the stairs.
Why not?
"Because that's the way it's always been done around here."
Sponsored Links
Old 20th February 2000, 08:03 PM
David Mullins's Avatar
David Mullins David Mullins is offline
Aussie Bloke
Registration Date: Nov 1999
Karma Power: 51
David Mullins has less than 100 Karma points so far.
Clown
Pros and Cons here. I know of several companies who have re-invented the wheel several times, each time doing the project the same way, and always with the same results.
I think there is nothing wrong with revisiting a topic, provided that there is grounds for appeal (so to speak). That is, that there is something different about the approach that increases its likelihood of success.
If we know (measured fact) that the water is cold, it is on (system ready), and the triggering mechanism is functional, then an alternative approach must be used whereby the water is not triggered or you don't get wet when it does spray.
I always remember the bushmen who catch monkeys by digging a hole in rock and putting food in it. The hole opening is big enough for the monkey to get it's hand in, but small enough that when the food is grabbed the monkey can't get it's hand out. When the monkey grabs the food, it is too stupid/desparate to let go, and the bushmen simply walk up and catch the monkey - AND THE MONKEYS KEEP GETTING CAUGHT!
Sponsored Links
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Sale of Demonstration Units - How should we document it from GMP standpoint? aoldendo Medical Devices (21 CFR part 820) 3 18th November 2009 09:10 PM
Electronic Approval Demonstration - Use of the voting option in Outlook Howard Lee Documentation Control Systems, Procedures, Forms and Templates 9 1st September 2009 09:16 AM
Best/Worst Production Demonstration Runs (PDR) - Share yours John B. Manufacturing and Related Processes 3 2nd October 2007 06:14 PM
Demonstration of auditor competence. Baldrick ISO 19011 and ALL Auditing Discussions 10 15th June 2005 05:36 AM
Par.5.6.1 Demonstration of suitability, adequacy and effectiveness of QMS MVladimir ISO 9001 - Quality Management Systems Standard 4 14th January 2005 02:20 PM
The time now is 02:12 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
