Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Records and Data - Quality, Legal and Other Evidence
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 29th July 1998, 05:44 PM
Linda Jurasin Linda Jurasin is offline
Registration Date: Jun 1998
Karma Power: 47
Linda Jurasin has less than 100 Karma points so far.
Default Interpreting 4.10.5 Inpection & Test Records
The company I work for tests our product 100%. Some of the tests/inspections are not documented i.e: tests via fixtures, go-no-go. Then we have other tests that are performed using a testing unit and software which automatically records the data. Can we continue doing both and still comply with 4.10.5 (QS9000 3rd edition & current TE Supplement)? How does this affect Quality Records 4.16.1 (QS9000 3rd edition & current TE Supplement)?
Sponsored Links
Old 4th August 1998, 05:10 PM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Default
You can do both. The auditor question will be why do you do those other tests and why do you not take data if you're doing them?
I would want to look at the control plan and I would want to understand what you're doing and why.
But - to look at the requirements, it is a matter of defining appropriate tests and inspections during the design phase and documenting them. In a production type of scheme, you're looking at the process FMEA and the process control plan contents. For inspections and tests defined within the control plan you 'have' to take data.
If you have inspections and tests not on the control plan my 'auditor' question would be why? Please explain.
I would also look at this from 4.20: Have you evaluated the need for statistical techniques on data you could gather from those 'hidden' inspections and tests.
I do want to caution you I'm not a T&E expert so I can't say exactly how that plays in.
When I think of inspections and tests I think of two levels. The minimum is Customer Requirements (including print call-outs, etc) and I think of company 'requirements' (which often exceed customer requirements). Company requirements may or may not be on the (a) control plan.
I see an obligation to record the customer requirements (inspections and tests) - they are a must.
I typically would expect to see additional inspection and test results recorded because I figure if you're doing the test/inspection you have the time to take the data and the data might become a useful continuous improvement tool (I love data, in case you can't tell) but I do not see it as a requirement unless it is a Control Plan item.
The rule is that if it is on the control plan, it must be recorded
Well, that's my 10 cents worth. That's the way I read it
Sponsored Links
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Circuit Board Incoming Inpection Criteria jscholen Medical Devices (21 CFR part 820) 8 14th April 2009 08:04 PM
Test records shall show actual test results data - 8.2.4.1 Inspection documentation clara AS9100 Aerospace Standard and Requirements 4 26th January 2007 12:37 PM
Records that stand the test of time RosieA Coffee Break and Water Cooler Discussions 5 16th December 2005 10:24 AM
Inspection and Test Records - Question on electronic retention Don Watt Inspection and Test, Sampling and Related Topics 5 24th August 2000 09:48 AM
Quality Records - Storage - Interpreting the requirement Marc Records and Data - Quality, Legal and Other Evidence 2 4th August 1998 11:46 PM
The time now is 10:06 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
