26th August 2005, 11:21 PM
Registration Date: Aug 2005
Karma Power: 18 Karma: 10
CE mark - Trying to determine if our product needs CE approval
 Hi, I am trying to determine if our product needs CE approval. It is a low voltage hand held tool used in crafting. No temperature control or on/off switch. Max temp is less than 300 degrees. How can determine if it needs approval? How can I find the registry, if there is one, where all approved products are listed?
Thanks!
27th August 2005, 02:47 AM
Metrologist-Auditor
Registration Date: Mar 2004
Thanks Given to Others: 1
Karma Power: 186
First question.....do you currently or intend to sell in Europe? If yes, then you need CE.....
If you need testing to support CE declaration, I suggest an accredited organization such as UL, CSA, or FM.
Others on here are better sources to direct you to a notified body.
Hope this helps.
Hershal
28th August 2005, 07:15 AM
Courtesy Access
Registration Date: Dec 2001
Thanks Given to Others: 10
Karma Power: 80
Your product probably comes under the scope of the Low Voltage Directive, and the EMC Directive for CE marking.
The full texts of these directives can be found at www.europa.eu.int
Look also however at all the other directives that require CE marking, as I am not fully conversant on all of them, and there may be others which affect you.
As the previous post says, this is only applicable for selling into the EU member states.
You should also consider the WEEE directive and the RoHS directive for your product, as these are not related to CE marking, but none the less have to be addressed by anyone wishing to sell into the EU.
28th August 2005, 03:23 PM
Registration Date: Jun 2002
Thanks Given to Others: 48
Karma Power: 192
Thanks!
Hi Crystal and welcome to the cove. If you are selling into the EU you will need the CE Mark. It seems like you will need to meet the Low Voltage Directive as a minimum. You can find all the directives along with the list of harmonised standards relevant to each one here.
Al
28th August 2005, 05:24 PM
Courtesy Access
Karma Power: 80
Thanks for in effect repeating my post
29th August 2005, 09:36 AM
Karma Power: 192
Not exactly. The link is more useful.
Al
29th August 2005, 09:47 AM
Courtesy Access
Registration Date: Sep 2001
Thanks Given to Others: 3
Karma Power: 65
Here is a number that you may want to contact:
US Department of Commerce International Trade Administration's Office of European Union and Regional Affairs (what a mouthfull)
202-482-5276
Reason: removed spoofed link
4th February 2007, 03:38 PM
Involved - Posts
Registration Date: Jul 2003
Thanks Given to Others: 29
Karma Power: 50
Re: CE mark - Trying to determine if our product needs CE approval
I am interested in exporting an insultation tester to Europe. Form the Notified Body it has been determined that the insulation tester is not a medical device.
I consider that the device does not fall under Low Voltage Directive, because it is not an “equipment designed for use with a voltage rating of between 50 and 1000V for alternating current and between 75 and 1500V for direct current”. It is supplied at 9VDC and produce 2800VDC for testing purpose.
I was not able to find another mandatory European directive, for CE marking, that could apply to this device.
The device has been successfully tested to EN60601-1-2:2001 for EMC.
Can I make a self declaration? Do I need an authorized representative in Europe?
If I made a self declaration and I will supply the Technical Documentation File to my European representative, could I affix the CE mark on my products?
Danny
