Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Six Sigma
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 1st September 2005, 10:39 AM
prasanth prasanth is offline
Registration Date: Aug 2005
Karma Power: 18
prasanth has less than 100 Karma points so far.
Let Me Help You Can any one explain about different variable sampling plans
Can any one explain about the variable sampling plans. How many sampling plans available.
Prasanth.Ch
Sponsored Links
Old 1st September 2005, 11:27 AM
Phil P's Avatar
Phil P Phil P is offline
Phil P
Registration Date: Oct 2004
Karma Power: 25
Phil P is appreciated, and has over 100 Karma points.Phil P is appreciated, and has over 100 Karma points.
Default
Hi prasanth,
Variable sampling plans can be used to gradually reduce the level of inspection required to verify conformance.
The objective of such plans is to allow inspection frequency to be reduced as confidence in a given process increases, or conversely to allow inspection frequency to be increased as confidence falls.
I'm not sure what you're getting at with the question 'how many are available?'. If you're asking how many types of variable sampling plans are available, then it's probably the wrong question. If you need one then you'll be best served by looking at a number of different examples and picking the best bits (for your purposes) from each. As with most document issues it's generally better to tailor make them for each organization.
I can upload a copy of the one that we use to give you an idea, if you think it'll help.
Sponsored Links
Old 1st September 2005, 04:22 PM
Bev D's Avatar
Bev D Bev D is offline
Registration Date: Jan 2003
Thanks Given to Others: 265
Karma Power: 137
Bev D is appreciated, and has over 1700 Karma points.
Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.
Default
OR does your question concern variable DATA (continuous data) sample plans vs attribute DATA (pass/fail data)?
Old 2nd September 2005, 01:10 AM
Karma Power: 18
Default Can any one explain about different variable sampling plans Reply to Thread
Hi Phil p,
Thanks for the infromation. I want to know how many variable sampling plans are available and how to select a sampling plan from the available variable samling plan.
If possible can you please explain.
Prasanth.Ch
Old 3rd September 2005, 10:18 AM
Jennifer Kirley's Avatar
Jennifer Kirley Jennifer Kirley is offline
Registration Date: Jan 2004
Thanks Given to Others: 964
Karma Power: 360
Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.
Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.
Default
Prasanth, I suspect you would be better served by a more comprehensive information source than through singly asked questions.
NIST provides information on acceptance sampling here http://www.itl.nist.gov/div898/handb...ion2/pmc22.htm as a portion of its comprehensive informational site on Process or Product Monitoring: http://www.itl.nist.gov/div898/handb...ion2/pmc22.htm
Here is a link to NIST's site with ready information to print out: http://www.itl.nist.gov/div898/handb.../pff/index.htm
I hope this helps!
Stealth quality versus no quality
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Sampling Spreadsheet to help determine the sample size for sampling plans Tim Folkerts Inspection and Test, Sampling and Related Topics 28 24th November 2008 12:55 PM
Confusion on Lot Sampling - How to use sampling plans vasilist Inspection and Test, Sampling and Related Topics 3 31st October 2008 01:21 PM
Sampling Plans - Can a company create its own Sampling Plan? Lizzie Inspection and Test, Sampling and Related Topics 2 19th September 2006 06:10 AM
How do you explain sampling plans to management? jmp4429 Inspection and Test, Sampling and Related Topics 7 10th November 2005 11:57 AM
ISO/IEC 17025 Sampling Plans - Sampling clauses not applicable for test labs? el_quixiote ISO 17025 - Calibration, Measurement Gages and Test Laboratories 4 27th May 2003 10:28 AM
The time now is 05:05 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
