The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Quality Tools, Improvement and Analysis
Forum Username
Elsmar Cove Forum Sidebar
Custom Search
Monitor the Elsmar Forum
Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Sponsor Links
Sponsored Links
Courtesy Quick Links
Howard's
Atul's
Symphony Technologies
Marcelo Antunes'
SQR Consulting
Bob Doering's
Quality Digest Portal
Reply
Old 8th September 2005, 10:50 AM
RudyB RudyB is offline
Registration Date: Feb 2004
Thanks Given to Others: 2
Karma Power: 38
RudyB has less than 100 Karma points so far.
Question Reject Rates - Lots and split lots
Good Morning Everyone,
I'm a manufacturing engineer for a small company that doesn't have a formal quality system in-place (owner's decision). We do have an individual that inspects items upon receipt that are fabricated to our drawings.
For the most part, the lots are accepted/rejected base on the results of sample inspections (he uses the tables in M-S-105).
Typically, our reciepts (lots) are either accepted or rejected based on the sample results. We then report supplier preformance based on lots accepted.
Example - 10 lots inspected, 9 accepted equals a 90% acceptance rate.
Occasionally when we really need an item, he inspects the entire lot, sorting out the good & bad, and making it a split lot.
MY QUESTION(s) - What is the appropriate method to report on lots that have been split (or) is there another approach we should take on reporting vendor performance based on the inspection method we use?
TIA,
Rudy
Sponsored Links
Old 8th September 2005, 11:12 AM
Al Rosen's Avatar
Al Rosen Al Rosen is offline
Registration Date: Jun 2002
Thanks Given to Others: 71
Karma Power: 413
Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.
Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.
Send a message via AIM to Al Rosen
In Reply to Parent Post by RudyB
TIA,
Rudy
Hi Rudy, welcome to the cove. I believe that the lot fails even if you sort.
If you have lot sizes that vary, you can use the total no. of items to determine % accepted(rejected).
(Total items in all passing lots/Total no of items in all lots)*100 = % Accepted
Al
Sponsored Links
Old 8th September 2005, 11:27 AM
CarolX's Avatar
CarolX CarolX is offline
Registration Date: Jun 2000
Thanks Given to Others: 472
Karma Power: 280
CarolX is appreciated, and has over 1700 Karma points.
CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.
Hi Rudy,
Look at it this way...why did you sort? Because it was rejected on initial inspection.
I track first piece approval through my manufacturing process. If my inspector has an out of tolerance condition, it is still considered a reject, even if engineering approved it "as is".
Hope this helps a bit.
CarolX
Theater is life, film is art, and television is furniture.
Old 8th September 2005, 11:40 AM
Jim Wynne's Avatar
Jim Wynne Jim Wynne is offline
Cross Forum Moderator
Registration Date: Jan 2005
Thanks Given to Others: 1,779
Karma Power: 1445
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
In Reply to Parent Post by Al Rosen
Yes--even if a lot is sorted, if it's lots-accepted-or-rejected that is being counted, then the lot that gets sorted has to be counted among the rejected lots.
This could be misleading unless 100% inspection is being done, because it's possible that there are defectives in the lots that "pass." It works as a measure of how many lots pass, of course, but I think it would be better to compare the number of pieces received vs. number nonconforming, regardless of whether the defectives are found in receiving inspection, production, or customer returns.
We aim to please. You aim too, please.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Inspecting a Length of Weld - High Reject Rates krichmond0306 Manufacturing and Related Processes 7 2nd December 2010 09:55 PM
How to define c=0 Reject Rates The Capt Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14 19th November 2009 09:24 AM
FOC (3 lots) - First of Code - Are you still doing 3 lots for FOC? MasterBB Other Medical Device and Orthopedic Related Topics 1 6th November 2009 04:31 AM
Traceablity of Small Part Lots Supplied to Production taken from Large Lots? ignatiuswong Lean - Lean in Manufacturing and Services 7 13th March 2008 11:45 PM
Lots of products - need CP's Shaun Daly ISO/TS 16949 - International Automotive Quality Systems Standard 9 7th March 2003 03:25 PM
The time now is 03:07 AM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, West Chester, Ohio 45069-1929
513 341-6272
