29th January 1999, 01:31 AM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Ford's QOS (Quality Operating System) and Q1
Does anyone know anything about a QOS Assessment form?
30th January 1999, 10:57 AM
Yep.
You can get them from
National Reproductions Corporation
29400 Stephenson Highway
Maidson Heights, MI. 48071
(810) 398-7900
BAsically, it is a little pamphlet that is similar to an audit checklist, to make sure you have implemented all of the elements that make up a solid QOS. I have on on my desk, unfortunately, I am at home right now. When I get to work, I will copy some of the info down in here.
I had to "implement" a QOS during our recent Q1 efforts. BAsically, you are satisfying the intent of a QOS by virtue of QS-9000..a system for business measurables, with goals, and evidence of progress towards those goals.
I called out the term "QOS" in a couple of my level II documents, in reference to customer satisfaction...
Have a nice day
Bryon
30th January 1999, 05:20 PM
Karma Power: 605
The number is now 248 398-7900 and the company name has changed to Lason Systems. They said to 'call back Monday'.Thanks for the info, Bryon.
31st January 1999, 08:57 PM
Karma Power: 605
Bryon - Could you FAX me a copy of the form? 513 777-3394.
Thanks!
1st February 1999, 06:11 PM
Karma Power: 605
Got the FAX! Thanks!
When I did my first QS implementation a few years ago the client was doing QOS which satisfied a number of QS9000 requirements (such as analysis and use of companu level data). That I understand. I didn't remember the form.
28th July 2000, 09:36 AM
I'm interested in Ford QOS Assessment Sheet
if you have it pls. send me or let me known the right person's access
29th July 2000, 12:46 AM
E-Mails Invalid or Rejected
Registration Date: Sep 1998
Karma Power: 0 Karma: 40
Bryon,
I too would like a copy if you don't mind. It sounds like you have a handle on Q1. I have been searching for info on this and what the criteria is for becoming Q1. Any help you can give me would be GREATLY appreciated!!!I have requested this info in another area of this forum and mentioned I tried to get info from Ford-but no response.
Thanks, Dawn
31st July 2000, 09:28 AM
Registration Date: Sep 1999
Karma Power: 90
Check with Ford SQA. It is my understanding they are no longer certifying to Q1 for new suppliers.
Also check your hardcopies for the latest revision. I just called a Ford SQA and was told that QOS info is only available on the Ford network.
The SQA I talked did not know the address (??) but maybe someone else out there has it.
[This message has been edited by Sam (edited 31 July 2000).]
