Go Back   The Elsmar Cove Forum > Manufacturing, Service, and Business Systems Processes > Manufacturing and Related Processes
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 23rd September 2005, 09:59 AM
asutherland's Avatar
asutherland asutherland is offline
E-Mails Invalid or Rejected
Registration Date: Aug 2005
Karma Power: 0
asutherland is appreciated, and has over 300 Karma points.asutherland is appreciated, and has over 300 Karma points.asutherland is appreciated, and has over 300 Karma points.asutherland is appreciated, and has over 300 Karma points.
Please Help! Are there any welding experts out there? Problem with porosity
We have a problem with porosity.
Machine Type Motoman Robot
Control System YASNAC
Control speed 30 TO 70 cm/min
Weld wire type Lincoln / supra mig vltra / En 440 G4Sil /AWS A5.18 ER 70S-6
Weld wire feed rate Unknown at this time
Type of Gas 8% CO2
92% Argon
17 to 20 liters/min
Blend (Mison 8)
Gauge of steel 3 to 50 mm
Type of steel Domex, Hardox, Weldox
Sponsored Links
Old 23rd September 2005, 10:06 AM
Jim Wynne's Avatar
Jim Wynne Jim Wynne is offline
Courtesy Access
Registration Date: Jan 2005
Thanks Given to Others: 755
Karma Power: 611
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
Default
Here's some good information: Common Problems and Remedies for GMAW
Sponsored Links
Old 23rd September 2005, 10:33 AM
Karma Power: 0
Default
Alfred E Neuman comes through again.
Excellent web site and great place to start.
Thx JSW
Old 23rd September 2005, 02:13 PM
Jim Howe Jim Howe is offline
Registration Date: Jun 2004
Karma Power: 0
Jim Howe is appreciated, and has over 200 Karma points.Jim Howe is appreciated, and has over 200 Karma points.Jim Howe is appreciated, and has over 200 Karma points.
Default Porosity
I am not a welding expert. Several years ago, however, I needed a definitive explanation of weld porosity. An old Navy buddy sent me the attached. Hope it helps.
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting the post it is in, 3. Use at your Own Risk.
Old 24th September 2005, 01:12 PM
Karma Power: 0
Default
Looks good too.
Will review this with the welding team and see where they want to start.
Old 6th October 2005, 07:02 PM
gard2372's Avatar
gard2372 gard2372 is offline
Sr. Quality Engineer
Karma Power: 33
gard2372 is appreciated, and has over 400 Karma points.gard2372 is appreciated, and has over 400 Karma points.gard2372 is appreciated, and has over 400 Karma points.gard2372 is appreciated, and has over 400 Karma points.gard2372 is appreciated, and has over 400 Karma points.
Default
Just a thought....
How is the quality control of your weld wire? I se you listed AWS specs, but take a look at the cert from the manufacturere of the weld wire, and store you weld wire in an over, or humidity controlled storage unit. Improperly manufactured weld wire may have impurities in it witch may down the mfg process may cause discontinuities when the NDT inspector finds them.
Almost all electrodes used for GMAW of steels have deoxidizing or other scavenging elements (cleaning agents) added to minimize the amount of porosity and improve mechanical properties. The use of an electrode wire with the proper amount of deoxidizers is most important when using oxygen- or C02-bearing shielding gases. I'm not sure if this applies to Argon purging as well though.
The electrode also needs to match the tensile or yield strength of the base metal, depending on which criteria has been used for the design. This is usually the first criteria with plain carbon and low-alloy steels, as well as with some aluminum and magnesium welding applications.
Some of the factors that affect porosity are moisture in the atmosphere, contamination of shielding gas, welding position, welding parameters, contamination of base or filler metal, and surface cleanliness.
Any welder struggles with the porosity problem and has developed solutions which vary in effectiveness. Some of the porosity factors are:
No cleaning prior to welding
Mass cleaning of surfaces in the weeks prior to fabrication
Local cleaning of weld areas immediately prior to welding with coated abrasives
Local cleaning of weld areas immediately prior to welding with wire brushes
Strict use of iron-free coated abrasives
Strict use of fine wire brushes
Hope this helps in any way possible.
Rob
"It costs a lot to build bad products"
Old 5th April 2007, 07:58 PM
mwccwi's Avatar
mwccwi mwccwi is offline
Getting Involved (6 to 9 Posts)
Registration Date: Aug 2006
Karma Power: 14
mwccwi has less than 100 Karma points so far.
Default Re: Are there any welding experts out there? Problem with porosity
Miller Electric http://www.esabna.com/html/eu.cfm
ESAB http://www.esabna.com/html/eu.cfm
OR try the welding Teacher http://www.weldingteacher.com/
Old 5th April 2007, 11:33 PM
Jennifer Kirley's Avatar
Jennifer Kirley Jennifer Kirley is offline
Registration Date: Jan 2004
Thanks Given to Others: 964
Karma Power: 360
Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.
Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.
This site discusses oxygen content in steels as a contributor to porosity.
Stealth quality versus no quality
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Projection welding of pipe (cold drawn seamless tube) with rod spatter problem ek911 Manufacturing and Related Processes 8 1st May 2009 10:29 PM
Welding Certification to AWSD1.1/D1.1M Structural Welding code gmowry Professional Certifications and Degrees 1 3rd February 2009 04:47 PM
Welding - Is welding always a special process per ISO9001:2000 Clause 7.5.2 Sohail ISO 9001 - Quality Management Systems Standard 33 7th November 2008 12:44 PM
Ultrasonic Welding of PBT plastic parts - Defining the cause of over-welding sadhusong Manufacturing and Related Processes 3 26th September 2008 11:00 AM
Resistance welding process - Cold rolled and some zinc plated welding keithm696 Various Other Specifications, Standards, and related Requirements 2 8th January 2007 11:47 AM
The time now is 10:00 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
