Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
5th October 2005, 01:37 AM
Involved - Posts
Registration Date: Jan 2005
Thanks Given to Others: 18
Karma Power: 45
TS 16949 “Audit observation Report” format or form with Input, Output, Processes
Can anyone send me “Audit observation Report” format comprises of Input , Output, Processes, etc used for auditing TS 16949.
thanks in advance
Sathish
5th October 2005, 11:06 PM
Involved - Posts
Karma Power: 45
Seeking: “Audit observation Report” format comprises of Input , Output, Processes
I've searched in google " audit observation report for TS16949", " audit observation format", "audit obseration format with input, output, processes",
I can't able to find a sample.
Sathish
5th October 2005, 11:53 PM
Quality Manager
Registration Date: Sep 2003
Thanks Given to Others: 452
Karma Power: 1122
In Reply to Parent Post by sathis
Sathish
Try audit TS16949 process
use advanced search (posts, not threads).
If you still need help, write again.
I think you tried to be too narrow in your search term.
6th October 2005, 02:55 AM
Involved - Posts
Registration Date: Aug 2002
Karma Power: 52
I am not sure whether you are looking for audit check-list.If so, pl see attachment. In our situation, internal quality auditor uses this as the starting point for an audit,followed by using detailed check-list for the process being audited.The purpose of the attachment, is to familiarize the process prior to auditing the same.
6th October 2005, 04:55 AM
Involved - Posts
Karma Power: 45
Thank you
Sambasi
Thank you for your post
Any way i will make a similar one
sathish
7th October 2005, 01:05 AM
Involved - Posts
Karma Power: 45
Audit Observation report
I've made a "Audit observation Report" comprising of Input,output, processes etc , any valuable feedback from your side.
any fine tuning in this?
sathish
7th October 2005, 10:48 AM
Quality Manager
Karma Power: 1122
A form is just a form. Next step is the instructions and training to go with the form. What did you have in mind?
8th October 2005, 03:45 AM
A.Vijayakumar
Registration Date: May 2004
Karma Power: 40 Karma: 15
Turtle in A BOX
Hi
I would like to call it as a Box Diagram (Can't call it else...,as Turtle legs got dragged)
Where to fit this Format Satish?
I would like to put our Audit Process
Plan
Internal Audit Annual Plan
Quarterly Plan
Do
Opening Meeting
5 Audit Trials(Processes covered under following headings) PRP,Production, Management, SOP, HR(Max 5 Auditors Min is better)
Mandatory - TS Std,QMS Manual-Turtles Included, Dept Procedures Audit Observation Sheet
NC Report
Optional -IATF Check list, a Clausewise guideline on what and where to check, a Process Approach Guideline on where to start, how to proceed and where to finish for individual processes
Check
Audit Observation sheets filled
NC Report Filled If required
Closing Meeting
Act
NC Closing by auditee
Trg By Internal or External if Reqd
MR Audit on NC Closings
Measurables
No of NC Raised (Min is better)
No of TS awareness Trg given (Max is better)
Customer Audit Results (NC Part Min is Better) (Scoring Mark Max Better)
Audit Plan Adherence
Instructions to follow
NC should be closed with in 90 Days
Auditor 1person Auditee Linked Process owners
Audit should be carried in Auditee working area
Company wide audit in 2 days
Internal Auditors are involved as 2nd party auditors for sister concerns
Internal Auditors should work as a Audit Guide during Cert body audit
Most of the formats are slightly altered from certifying body's formats/reports as per our requirements
Any Improvement suggestions Welcome
Forum Posting Settings
