Originally Posted by Muleskinner
Hi Angelika,
I do not have an answer for you. I hope some of our most knowledgable AS/EN9100 people will see your post and offer some ideas. Good day to you.
Thank you, Muleskinner, for your kind words – apparently none of the specialists of this forum has had an answer for me. I am not sure if I did not describe my problem clear enough or if none of them has ever had to do with this matter.
In the meantime, I (hopefully) have found a solution how to handle this matter and I would like to share it with you all, at the same time asking you for your opinion and your criticism.
Just a few introducing words to make you more familiar with my problem.
The whole matter came up, when one of my customers had a second-party-audit by a member of ASD (former AECMA) i.a.w. EN 9100.
The auditors found that the company had special processes, i.e., processes that cannot be verified by subsequent monitoring or measurement – including processes where deficiencies become apparent only after the product is in use or the service has been delivered (9100/7.5.2). Painting, laminating, welding, riveting, electroplating are some examples for such special processes which require
special procedures to show conformity with the requirements.
Here is my proposal for a procedure:
1. Determine all the special processes
2. Determine product specification and pass/fail criteria.
3. Determine the required qualification of personnel involved in special
processes and make sure that special processes are performed only by
sufficiently qualified personnel
4. Determine suitable equipment and make sure that only approved
equipment is used when performing special processes
5. Determine and control procedures for performing and inspecting special
processes, including additional in-process-verification points.
6. Determine the required records.
7. Ensure qualification and approval of special processes prior to use (e.g.
by destructing testing of a sample)
8. Compare results from destructive testing with product specification.
9. In case of pass: Release of product
10. In case of fail: error analysis and corrective action
The auditors explained that special processes will be more and more important in the future - this is why I still try to learn more about it.
Looking forward to your comments
Best regards,
Angelika
