Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Quality Tools, Improvement and Analysis > Quality Assurance and Compliance Software Tools / Solutions > Using Minitab Software
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 18th October 2005, 07:48 PM
Jim Thomson Jim Thomson is offline
Registration Date: Jul 2005
Karma Power: 18
Jim Thomson has less than 100 Karma points so far.
Let Me Help You Finding standard deviation of ranges in Minitab
I have recently been assigned the task of calculating a variety of statistics for our top 15 products. The one statistic that has me baffled is the sigma of the ranges. I can't seem to find it in Minitab. Is there a way to do this in Minitab? Thanks.
Jim Thomson
Sponsored Links
Old 18th October 2005, 09:36 PM
Miner's Avatar
Miner Miner is offline
Registration Date: Apr 2002
Thanks Given to Others: 166
Karma Power: 251
Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.
Default
Jim Thomson
How do you intend to use this information?
You can brute force this information by putting each value of the subgroup in a separate column. Use the Calc by Rows function to calculate the Range and place the results in a new column. Then do statistics on that column to obtain the sigma.
However, I cannot understand why you would want this information. The Range is influenced by the subgroup size. This is why you have to use different A2, D4, d2, etc. constants based on subgroup size to calculate control limits.
Sponsored Links
Old 19th October 2005, 10:31 AM
Darius's Avatar
Darius Darius is offline
Courtesy Access
Registration Date: Mar 2002
Thanks Given to Others: 21
Karma Power: 65
Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.
Default
Maybe I don't understand but..
Setting MINITAB Options
Methods and Standard Values
Statisticians sometimes disagree about the best methods for estimating certain parameters. Similarly, acceptable standard values (like alpha levels) may vary from person to person or company to company. Options allow you to choose your preferred test methods and parameters.
Problem: You prefer to use the average of subgroup ranges to estimate the standard deviation in n X-R chart.
Solution: Change the estimation Options setting.
and welcome to the cove.
Vits er thorf, theim vitha ratar; daelt er heima hvat; at augabragthi verthr, sá er ekki kann ok med snotrom sitr.
Old 19th October 2005, 05:58 PM
Karma Power: 18
Default
This is a customer driven requirement. I asked the same question as I have never seen this metric before.
I will probably use the "brute force" method and grind through the thousands of numbers We have a great deal of data but it is not readily available.
Thanks for the help in this.
Jim Thomson
Old 7th May 2006, 01:37 PM
Statistical Steven's Avatar
Statistical Steven Statistical Steven is offline
Consultant
Registration Date: May 2005
Thanks Given to Others: 36
Karma Power: 43
Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.
Send a message via Yahoo to Statistical Steven
Default
Jim Thomson
General question here....if the customer asks for an invalid statistical analysis, do you do it just because they ask for it?
Can you ask the customer what does sigma of the range mean? Sounds like you are taking the variance of variances.
Steven Walfish
When in doubt, ask your company statistician!
Old 8th May 2006, 08:36 AM
David Hartman's Avatar
David Hartman David Hartman is offline
Courtesy Access
Registration Date: Feb 2003
Karma Power: 66
David Hartman is appreciated, and has over 1300 Karma points.David Hartman is appreciated, and has over 1300 Karma points.David Hartman is appreciated, and has over 1300 Karma points.David Hartman is appreciated, and has over 1300 Karma points.David Hartman is appreciated, and has over 1300 Karma points.David Hartman is appreciated, and has over 1300 Karma points.David Hartman is appreciated, and has over 1300 Karma points.David Hartman is appreciated, and has over 1300 Karma points.David Hartman is appreciated, and has over 1300 Karma points.David Hartman is appreciated, and has over 1300 Karma points.
Default
Jim Thomson
You might want to give your customer a call and ask their intent. Because as I read this they could be asking for "the sigma of ranges [or list of numbers, instead of the statistical meaning of the word "range"]. In other words, their intent may be as simple as asking for the sigma of your actual data. Then again, maybe not - but you will not know without asking.
David D. Hartman
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Tolerances +/- 1 standard deviation? Adam S Inspection and Test, Sampling and Related Topics 8 15th February 2008 06:29 PM
Mathematical difference between mean Deviation and Standard Deviation Abhijeet SPC Monitoring and Statistical Analysis Techniques 3 11th July 2006 10:20 AM
Can the Standard Deviation (SD) value be zero? Cognizant Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11 15th June 2006 10:33 PM
Standard Deviation - Working vs. Thinking imceepee Definitions, Acronyms, Abbreviations and Interpretations 4 27th March 2006 01:46 AM
Gage R&R (Ranges Method) - Reproducibility standard deviation Martin Kies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4 28th October 2003 06:54 AM
The time now is 08:43 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
