Go Back   The Elsmar Cove Forum > Information Resources - Papers - Articles - Etc. > Definitions, Acronyms, Abbreviations and Interpretations
Elsmar Cove Forum Visitor Notices
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 8th August 1999, 05:16 AM
Kevin Tan
Unregistered Guest
Posts: n/a
Clown Major Nonconformity - Definition of Major Nonconformity
Hello, this is my first posting to this forum.
I would like to ask for some help in interpreting the definition of a "major" non-conformity in QS9000 audit. There are 3 definitions given, i.e.
a) the absence or total breakdown of a system to meet a QS 9000 requirement. A number of minor nonconformities against one requirement can represent a total breakdown of the system and thus be considered a major.
b) Any noncompliance that would result in a probable shipment of a nonconforming product. A condition that may result in the failure or materially reduce the usability of the products or services for their intended purpose.
c) A noncompliance that judgement and experience indicate is likely to either result in the failure of the quality system or materially reduce its ability to assure controlled processes and products.
I have problem in interpreting the 2nd and 3rd definition. In particular, the term 'probable', 'may', 'judgement and experience' (whose?) can be quite subjective. It appears to have given the auditors a lot of freedom and discretion in raising a major.
Can anyone offer an insight into this?
Thanks.
Kevin
Sponsored Links
Old 10th August 1999, 10:49 AM
Debra Woodford
Unregistered Guest
Posts: n/a
BIG Smile
I am of the understanding that a Major NC is just what you described in 1. A major breakdown or nonexsistance of a QS9000 requierment, and yes minors can add to a major that is where the "Opinion" if you will of the Registra. My experience is the overall impression your auditor gets of your system in general will determine major or minor, however, a NC is a NC, and even an observation in my opinion should be addressed with corrective action.
Sponsored Links
Old 10th August 1999, 12:25 PM
Kevin Mader's Avatar
Kevin Mader Kevin Mader is offline
One of THE Original Covers!
Registration Date: Nov 1998
Thanks Given to Others: 22
Karma Power: 94
Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.
Send a message via AIM to Kevin Mader
Major or minor? Which shall it be? Hmmmm...
Severity of the issue (what is the risk involved and what could reasonably occur if unaddressed) or frequency of the issue (mountains out of mole hills). I believe the Customer expectations need (standards, requirments, guidelines) to drive your actions here. What do they expect? Some are outlined in the QS requirements. Others may be contractually driven.
At any rate, the key word is "reasonable". Is it reasonable to assume that your systems will never produce rejects? Probably not. What levels are acceptable (again, what does the customer expect)? What is the process capability?
As far as issuing a CA request for minors, probably not a bad idea provided caution is exercised. You wouldn't want to create mountains out of mole-hills (some level of nonconformance is expected).
Old 11th August 1999, 04:56 PM
barb butrym barb butrym is offline
Courtesy Access
Registration Date: Dec 1998
Karma Power: 63
barb butrym is appreciated, and has over 100 Karma points.barb butrym is appreciated, and has over 100 Karma points.
Covering Ass
Since there is no way to address every possibility, some grey areas MUST exist...the auditor has the experience to make the call...IF you have chosen your registrar wisely, you will have that confidence in the auditor as well....You also have the right to rebutt and argue your point. If you can provide evidence to the contrary, you are encouraged and welcome to do so...If you do not feel comfortable doing that then perhaps you have chosen the wrong registrar. The registrars I work with are open to such discussions, and will explian the reasoning behind any upgrades to a Major NC......
You are correct in that there is no majic number of minors to add up to a Major...If anyone tells you there is its rubbish...or registrar dependant...It is an auditor comfort level. And the new rules say that any nonconformance must be closed (hard evidence reviewed) before recommending registration...not simply the Majors
Old 13th August 1999, 05:36 AM
Kevin Tan
Unregistered Guest
Posts: n/a
I would just like to thank each of you contributors who responded to my enquiry. Although, it still gives me an uneasy feeling that there is too much discretion placed on the registrar's auditors to be `reasonable'.
Regards,
Kevin
Old 14th August 1999, 01:54 AM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Yin Yang
I just did an internal audit for a client which I have had an association with since February this year. When I first went there, I laughed. It was registered by UL and I thought "UL was paid off." I can better understand the auditor's point in some sense when they 'let slide' certain things.
Key Word = Risk Factor
They are improving. Significantly improving. I found myself asking myself whether I wanted to go beyond offering an observation rather than a 'finding' or 'observation'. In speaking with the quality manager I know there was full understanding of the system deficiencies. I had to come down to risk. Most I noted as observations because I believe the risk factor was low.
Comments?
Old 14th August 1999, 08:53 AM
Courtesy Access
Karma Power: 63
you are right Marc.....risk is a key factor. As a consultant I too have seen the "my, God, they bought the cert" places too, but since I have been doing more registration audits lately, I have to ask, does it work for them? So often we have preconcieved notions of what needs to be, and have gained more respect for the auditors...or perhaps I see more competent auditors? there are still some nasty things going on....for sure....but a client needs to have a good relationship with the registrar so that decisions can benefit the company. When registration hangs in the balance, the auditor needs to be objective...I can tell you those minor/major/observation decisions do not come lightly to any auditor worth his salt.
As I train more and more lead auditors, I see the toughest part of the course is the case studies where the delegate must make the decisions and write up a N/C. They argue their point as if thier life depends on it. The class always splits...and in the end it has to boil down to evidence, and if it meets the intent of the standard. from there I can see if a delegate will make a good auditor or not....typically the class gives off a few that rise above the rest, but most struggle until they gain more experience.
[This message has been edited by barb butrym (edited 14 August 1999).]
Old 14th August 1999, 06:39 PM
Marc's Avatar
Karma Power: 605
Bomb!
Decisions in the ISO arena are a lot easier to make than those in the QS arena.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Nonconformity Records - Nonconformity vs. Scrap - 8.3 Requirements tkevmoore Records and Data - Quality, Legal and Other Evidence 10 24th August 2009 06:23 PM
Major Nonconformity vs. Minor Nonconformity - Definition and Differences hibou Definitions, Acronyms, Abbreviations and Interpretations 9 10th December 2008 02:22 AM
Establishing Internal Audit Nonconformity Level Criteria - Major vs. Minor? stanislavd Internal Auditing 46 18th July 2006 10:47 PM
Major/Minor Nonconformity - Nonconformance from last audit found again mjflkitty Nonconformance and Corrective Action 15 8th November 2004 03:53 PM
Nonconformance vs. Nonconformity - I cannot find major and minor, either! Q rex Nonconformance and Corrective Action 36 18th December 2001 04:43 PM
The time now is 12:29 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
