Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 17025 - Calibration, Measurement Gages and Test Laboratories > Calibration Frequency (Interval)
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 31st October 2005, 10:00 AM
mshell's Avatar
mshell mshell is offline
Involved - Posts
Registration Date: Aug 2003
Karma Power: 50
mshell is appreciated, and has over 700 Karma points.mshell is appreciated, and has over 700 Karma points.mshell is appreciated, and has over 700 Karma points.mshell is appreciated, and has over 700 Karma points.mshell is appreciated, and has over 700 Karma points.mshell is appreciated, and has over 700 Karma points.mshell is appreciated, and has over 700 Karma points.
Please Help! Illuminance Meter - Extending Manufacturer's Recommended Calibration Frequency
We currently have 2 illuminance meters being calibrated annually by the manufacturer. I have reviewed the records of calibration for the last 3 years and found that the meters have been in calibration each time we have sent them out. The manufacturer certificate (traceable to NIST) requires annual calibration. I would like to extend the calibration period to every 2 years based on minimal use and previous test results. Can I do this without losing the NIST traceability?
Mshell
Sponsored Links
Old 31st October 2005, 10:05 AM
Jim Wynne's Avatar
Jim Wynne Jim Wynne is offline
Courtesy Access
Registration Date: Jan 2005
Thanks Given to Others: 755
Karma Power: 611
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
Default
Yes. Calibration intervals are not related to traceability, unless whomever is doing the calibration is destroying their records after 12 months, which is highly unlikely. You determine the proper interval for your application, not the manufacturer or calibration source.
Sponsored Links
Old 31st October 2005, 10:41 AM
Jerry Eldred's Avatar
Jerry Eldred Jerry Eldred is offline
Registration Date: Dec 1999
Karma Power: 89
Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.
Default
The general rule is that you "may" extend interval when in-tolerance history says the probability is they will remain in-tolerance for the new longer interval, and you "must" decrease the interval when out-of-tolerance history so dictates.
Depending on what you must comply with, it may or may not be reasonable to double the interval. I ran the NCSLI RP1 Method A3 Interval Tester, and at 95% in-tolerance target, the longest new recommended interval was 14.4months (I varied % in-tolerance all the way to 1% and the confidence factor all the way down to 1% as well, and still only came up with 14.4 months as the maximum recommended interval. This is based on the National Conference of standards Laboratories Recommended Practices.
However, on the more practical side, if you really want to adjust the interval to 24 months, I would recommend reviewing the certificates, and perhaps calling the lab that cal'd them for you, and ask to determine if the units were ever adjusted or optimized by them during any of those calibrations. If they have never been adjusted or optimized, that would indicate that the units may have remained in-tolerance for the three years, and 24 month interval may be fully appropriate. Again, depending on what you must comply with (ISO, FDA, FAA, etc.), it may or may not be important for you to document that. The calibration interval is, after all is said and done, the statistically probable amount of time (or usage) within which an instrument may be expected (to a defined degree of confidence) to remain within specified tolerances.
As the first repy indicated, it will not magically go out of tolerance on the due date. What does happen is that from the instant the calibration label is applied (kind of like magic - sorry, it's Monday morning) the is a statistical increase in the probability that it will not remain in specs., which increases until the time at which it will likely be out of tolerance.
The more history you acquire, the higher the confidence in how long it will remain in tolerance. Method A3 uses the average interval and the maximum interval in statistically determining new intervals. IMPORTANT NOTE: When adjusting intervals, use the actual amount of time between calibrations (old cal date to new cal date), not the assigned interval (12 months). If you went significantly over 12 months, during any of the previous calibrations on your meters, that could increase the allowable new interval (per that recommended practice).
Also, as was previously posted, the customer assigns the interval (according to IEC/ISO17025). The manufacturer's interval is not binding, it is their recommendation. What that is based on depends on the manufacturer. You might even talk with someone at the manufacturer and ask them what it is based on, and what the risks might be with a two year interval.
Could be at each calibration that they do a periodic maintenance on the optics that could degrade (surface contamination buildup, for example) if left for two years.
It may well be fully acceptable to go two years (and in my opinion, there is reasonable likelihood that is the case). But I feel duty bound to share the risk potential.
There are two opposing forces in any circumstance where the interval is adjusted:
1. COST: if the interval is too short, too much is spent on unneeded calibrations.
2. RISK/COST: if the interval is too long, there is ALWAYS statistical increase in the risk of undesired out-of-tolerance. I added COST to the second statement, because that is an often overlooked potential impact of too long an interval. The undesired out-of-tolerance may result in "inaccurate" decision based on an out-of-tolerance reading.
Both of the above must always be factored into setting of initial intervals, and adjusting them. How the instrument is used and stored impacts how well it retains tolerance. How it is used also determines it's potential impact.
Old 1st November 2005, 09:55 AM
Graeme's Avatar
Graeme Graeme is offline
$ Contributor
Registration Date: Sep 2000
Karma Power: 63
Graeme is appreciated, and has over 700 Karma points.Graeme is appreciated, and has over 700 Karma points.Graeme is appreciated, and has over 700 Karma points.Graeme is appreciated, and has over 700 Karma points.Graeme is appreciated, and has over 700 Karma points.Graeme is appreciated, and has over 700 Karma points.Graeme is appreciated, and has over 700 Karma points.
Send a message via AIM to Graeme Send a message via MSN to Graeme Send a message via Yahoo to Graeme
Default
To add to the excellent information from Jerry and JSW05 --
Another part of the risk/cost consideration on extending intervals is this: if one of the meters is found to be out of tolerance, you are required to evaluate the impact of the OOT condition on the product and, if necessary, recall all items that meter was used on back to the last time it was known to be in tolerance. That can be a very substantial cost.
An "insurance policy" that can help with this is the practice of making regular measurements of a product item (or other appropriate stable artifact) that is reserved for use as a check standard. At specified intervals (depending on your use of the meter) the check standard is measured in exactly the same way as routine product measurements, and the results are plotted on a control chart. Examination of the control chart will indicate potential problems and action may be taken much sooner than waiting for the next calibration results. The "last known good date" is immediately before the control chart starts to indicate a problem. Naturally, a precondition for this is that the meaurment process is in a state of statistical control.
While agreeing that the manufacturer's recommended interval (if any) is only a guideline, if you are in a regulated industry there are other considerations as well. In many cases the regulating agency mandates that the manufacturer-suggested interval shall be used unless other conditions are met. For the agency I am most familiar with (FAA), any change of the interval must be justified on the basis of statistical analysis of actual data and a defined end-of-interval reliability goal. That means, using Jerry's calculations as an example, you could only justify extending the interval to 14 months. (It also means that any of the reactive methods listed in RP-1 can not be used.)
Graeme C. Payne
ASQ Sr. Member; CQE; CCT
"Does it matter if the measurement result is wrong?
If it does, then calibrate the instrument.
If it doesn't matter, they why are you making the measurement?"
(P. G. Stein, 2000)
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Calibration of a frequency measurement device/frequency source Ruebenn ISO 17025 - Calibration, Measurement Gages and Test Laboratories 2 25th March 2009 01:48 AM
What is the recommended calibration frequency for gage blocks? mcowan Calibration Frequency (Interval) 2 28th January 2009 12:50 PM
Extending Surface Plate Calibration Frequency mhirand20 ISO 17025 - Calibration, Measurement Gages and Test Laboratories 3 23rd January 2009 05:03 PM
Calibration - Manufacturer's Calibration Certificate Date edelsal ISO 9001 - Quality Management Systems Standard 8 11th January 2009 10:36 PM
Plug Gage Calibration - Manufacturer's Certification vs. Calibration Laboratory Dawn ISO 17025 - Calibration, Measurement Gages and Test Laboratories 2 24th January 2000 07:25 PM
The time now is 03:41 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
