Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Misc. Quality Assurance and Business Systems Related Topics
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 11th August 1998, 05:43 PM
Mitchell Medford
Unregistered Guest
Posts: n/a
Default Document Evidence for One Piece Flow Processes
We have a process in which our routing is assemble item complete. The process/safety instruction is broken down into different steps by operator. We currently use six operators to complete this process. We use a work traveler to sign off by the last operator to show that steps have been completed. We received an Action Request from UL during our continuous assessment that there is no objective evidence that the first team member performed a go/no go check. We need ideas on how others are documenting one piece flow processes and showing objective evidence that inspection/test requirements are being performed.
Sponsored Links
Old 11th August 1998, 08:05 PM
Marc's Avatar
Marc Marc is online now
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Default
You say you have a traveler which follows the part. Why not have the check listed on the traveler to be initialed by the employee performing the check? This is typically what I see.
Another possibility is a sheet at the station where the check is made on which the check is recorded with assembly ID.
I'm sure some others here will give their experience on this as well.
----- Some Marc Smith Thoughts -----
You might also want to take a good look at the check being made. Is there a reason why it must be confirmed as having been done? That is to say, is there a step down stream in the process where, if someone 'forgot', that a problem would be found/identified?
I am asking the second part as apparently you are doing the process OK and have seen no reason to record the results. From this,I assume the inspection/test is not on the (a)control (or other quality) plan. I have found in the past that UL can be so strict as to be brain-dead - so I always am wary of them. This is not to say UL is bad - just very, very strict and often their auditors have a very narrow paradigm. On the other hand often I go into companies where it is evident they are doing something correctly but they can't explain why they are doing what they do - so it's not always a registrar 'thing'.
My personal paradigm is that if you're inspecting or testing something (even a go/no-go) you might as well record it. But when I'm auditing I often find inspections/tests that are neither recorded nor is there evidence that it has been done. I start asking questions why.
You can have an inspection/test which isn't on a 'quality (or control or other) plan.
Example:
Switch for electronic assembly. At point of introduction to the assembly the switch goes through a go/no-go which is not recorded nor is there any evidence it is done at all. This test is described as a screen by the product engineer. The product engineer explained that the switch is again checked down stream during an assembly functional test. He could show me test results from down stream which showed no evidence of a bad switch getting through to the functional test in over a year. He also explained that the screen was simply not part of their product plan nor did they see a reason to include it.
As an auditor, I cannot tell them what has to be in their quality plan. If they want to do 100 inspections and tests which are not 'part of the plan', that's their business - not mine. Nor is it my business to tell them what should go in their quality plan. I have been in companies which make complex assemblies where the only checks in their 'plan' were receiving (a count and check of the PO against the packing slip was all) and the final functional. Yes - they had a number of in-process checks/inspections - some recorded and some not.
My point in this is to stress: DO NOT jump up and do something an auditor says because s/he is an auditor. It is your business. Can you explain what you are doing and why? That is the biggest factor.
The spec (ISO) says:
4.10.3 a "Inspect and test the product as required by the quality plan and/or documented procedures."
You can have lots of extra tests and inspections in addition to 'formal' tests.
Think first!
[This message has been edited by Marc Smith.]
Sponsored Links
Old 24th August 1998, 10:26 AM
dhillsburg
Unregistered Guest
Posts: n/a
Default
We have a similar one piece flow. Our operators sign the traveler at the end of the stated process and inspections. The last operator signs for all suboperations that comprises the one major....ie "Step 3 Assemble solenoid and all documented inspection/tests" is signed by last operator at a final test stand operation. A total of 4 operators "assemble solenoids" This is just fine with our Registar.....BVQI.
Old 24th August 1998, 10:49 AM
Mitchell Medford
Unregistered Guest
Posts: n/a
Default
DHillsburg,
How do you have this documented in your procedures?
[This message has been edited by Mitchell Medford (edited 08-24-98).]
Old 5th October 1998, 03:50 PM
Leslie Garon
Unregistered Guest
Posts: n/a
Default
I think we're missing a small point here, If the check isn't documented, then the operators are not doing what is said and thus what is said is not what is done, hence, non conformance. If the check is necessary, it should be documented at least in the work instruction.
Recording of in-process checks is not a requirement. It is a means to prove you say what you do and do what you say. but, there are other ways of doing this also.
My recomendations usually follow this line: If you need to make sure the step is completed, record it; If it is done as part of the routine and documented as part of the routine, then proof is in the observation and repitition; If it is critical or a object for traceability, record it otherwise use recording as a means for discipline <sp>.
Old 20th February 2001, 07:16 PM
Joe Baggett
Unregistered Guest
Posts: n/a
I know it sounds costly but if a go/no go fixture can b built into an automatic calcaution device the quantity of conforming and non-conforming checks can be tabulated electronically at any given point in your value stream. I know that precison machining process require this check to be in place before the product can continue through the process.
Old 21st February 2001, 09:54 AM
Sam's Avatar
Sam Sam is offline
Registration Date: Sep 1999
Karma Power: 90
Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.
I would evaluate the process; Do you really need the checkpoint,Can this step be elimated or made a part of the process.
It has been my experience that documented inspection results within a "one piece" flow is not practical. Handling paper with the process defeats the purpose.
Old 21st February 2001, 08:17 PM
David Mullins's Avatar
David Mullins David Mullins is offline
Aussie Bloke
Registration Date: Nov 1999
Karma Power: 51
David Mullins has less than 100 Karma points so far.
Dear MM,
Yesterday I resisted, today I cannot.
Don't just create work for the sake of compliance with some requirement - that is what gives quality a bad name.
Poka-yoke the process to avoid additional work for the operators.
Get imaginative.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Traceability without Working Order - Batch to One Piece Flow clara AS9100 Aerospace Standard and Requirements 1 29th July 2009 06:28 AM
Anyone know how to establish one piece flow in apparel industry? RaymondC Lean - Lean in Manufacturing and Services 9 2nd April 2009 08:30 AM
Implementing One Piece Flow YKT Lean - Lean in Manufacturing and Services 9 8th June 2007 04:34 AM
Looking for some Quality Catch Phrases - First Piece and Last Piece Displays kdelorme Documentation Control Systems, Procedures, Forms and Templates 34 12th October 2006 12:39 PM
Material flow - Evidence for the material flow to our customer ZLYDCOM Definitions, Acronyms, Abbreviations and Interpretations 4 19th June 2006 10:39 AM
The time now is 01:58 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
