Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Design and Development - Process and Product
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 11th April 2001, 11:54 PM
Johnny Jewel
Unregistered Guest
Posts: n/a
Please Help! Design department can't tolerance analysis its way out of a paper bag.
Here is a question that, although more design-related, definitely impacts the quality field in the area of Quality Plans, measurement, and effectiveness of design documentation. First, let me describe one way the organization I work for portrays the importance of drawing dimensions.
-- Critical Dimensions -- Dimensions determined to be critical to the part's fit and function. Critical dimensions will be indicated on the print by brackets or other indicators. These dimensions must meet a Cp of 2.0 and Cpk of 1.5.
-- Major Dimensions -- Dimensions that are toleranced beyond the standard block tolerance. This would include all GD&T dimensions.!!!!!!!!! (!!!!!!!!!!! mine)
-- Minor Dimensions -- Dimensions whose tolerances are not explicitly written on the drawing (non-functional dimensions) and whose limits are defined by general tolerances or as indicated in the title block area of the print.!!!!!!!!!!!!!!(Mine, again).
-- The last 2 must pass a First Article Inspection with Majors having 5 parts measured, and 4 of the 5 must be within 63% of the tolerance range.!!!!!!!!!!(Oops, those darn!!!!!!!!!'s again!). Minors have 1 part measured, and must be in tolerance.
-- (Regarding "standard block tolerance" and "title block area", our drawings have default tolerances something like 3-place decimals tolerance is ±.005, 2-place decimals ±.010, and so on.)
1.) Has anyone seen anything similar?
2.) Does anyone know the source of this?
3.) Can you tell I am not neutral on this method?
-- I believe that the designer, thru design reviews, drawing reviews, tolerance analysis, FMEA's, and other means should decide which dimensions are significant and at what level. These dimensions must all meet the same capability minimums the company has decreed as the goal, and the tolerances can take up the slack of how important each is. By the way, the "63% IT", as it has been nicknamed, has been put forth as being a Cpk of 1.33. It is, if the process is perfectly centered, and you agree that capability can be estimated with 5 parts.
-- Aaand, there is no hierarchical nature to characteristics described with Geometric Dimensioning and Tolerancing -- it is merely the way the designer has chosen to describe the particular feature, usually because it is the best way; most descriptive and most related to the function of the part.
-- Finally, without telling you the name of my company, I will tell you we are a leader in our field -- and yet our design department can't tolerance analysis its way out of a paper bag. They work strictly with nominals in the development phases and throw in the standard ±'s with little thought. It is rare that prototype parts are even measured to see "what worked". Oh, and they also try to designate as few Critical's as possible so that meeting those pesky Process Capability targets won't hold up release of the product to the producing plant.
-- 4.) Are these attributes common?
Sponsored Links
Old 12th April 2001, 12:20 PM
CarolX's Avatar
CarolX CarolX is offline
Registration Date: Jun 2000
Thanks Given to Others: 419
Karma Power: 176
CarolX is appreciated, and has over 1700 Karma points.
CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.
Johnny,
I'll answer question 4 first -
I Won't say common - but standard. I have yet to see an engineer who will classify characteristics as critical, major and minor.
As for your other question, I can tell you my experience years ago working for defense contractors.
DoD drawings use to have a reference sheet which listed critical, majors and minors. Quality requirements were as follows
Critical - 100% inspection
Major - Sampling inspection performed using MIL-STD-105, Genreal Inpection Level II, .65 AQL
Minor - Sampling inspection performed using MIL-STD-105, General Inspection Level II, 2.5 AQL
Usually anything not specified as critical or major was considered minor.
I don't know if this information will help you. But without a doubt, good luck trying to get engineering to define these for you.
CarolX
Sponsored Links
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Design Plan for use in our Engineering Department - Aviation Electronics thoyer Documentation Control Systems, Procedures, Forms and Templates 2 28th October 2009 12:02 PM
Design and Development of a Service - Medical Department MaryJames Design and Development - Process and Product 20 15th July 2008 10:32 PM
Design For Six Sigma (DFSS) Example For Pump Design and Tolerance processanalyzer Quality Assurance and Compliance Software Tools / Solutions 1 1st July 2008 09:23 AM
Need a help in finding a research paper - Patel, J. K. (1986) Tolerance interval learner777 Capability, Accuracy and Stability - Process, Machine, etc. 2 14th March 2006 12:02 PM
Filtration Industries - Fabrication in Filter Press, Fluid bag, drier bag or etc. darkgelap Various Other Specifications, Standards, and related Requirements 3 19th September 2005 01:31 PM
The time now is 08:08 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
