Go Back   The Elsmar Cove Forum > National and International Business Standards > RoHS, REACH, ELV, IMDS and Restricted Substances Related Regulations
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 5th December 2005, 01:28 AM
knight_sirk's Avatar
knight_sirk knight_sirk is offline
Involved - Posts
Registration Date: Oct 2005
Karma Power: 20
knight_sirk is appreciated, and has over 100 Karma points.knight_sirk is appreciated, and has over 100 Karma points.
Send a message via Skype™ to knight_sirk
I Say... IMDS concern (re: CaZn Complex Stabilizers) - No CAS number
Hi to all!
Does anyone here involved in MDS uploading?
Please, kindly help...
How can i add CaZn complex stabilizer in the basic substance of a material?
Since it doesnt have any CAS # and not listed on the Basic Substances in the IMDS.
The only result that appears on my search in the IMDS is:
- Calcium complex soap for lubricants
In which based on my research, CaZn Stabilizer is also known as lubricants and thickeners.
Would the above search result be acceptable for CaZn Stabilizer?
This is the only information we can have from our supplier.
Thanks in advance!
Sponsored Links
Old 5th December 2005, 04:05 PM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Default
Sounds right, but I'm not dealing with this on a daily basis.
Anyone else?
Sponsored Links
Old 5th December 2005, 06:09 PM
Ron Rompen's Avatar
Ron Rompen Ron Rompen is offline
Involved - Posts
Registration Date: Oct 2004
Thanks Given to Others: 5
Karma Power: 46
Ron Rompen is appreciated, and has over 900 Karma points.Ron Rompen is appreciated, and has over 900 Karma points.Ron Rompen is appreciated, and has over 900 Karma points.Ron Rompen is appreciated, and has over 900 Karma points.Ron Rompen is appreciated, and has over 900 Karma points.Ron Rompen is appreciated, and has over 900 Karma points.Ron Rompen is appreciated, and has over 900 Karma points.Ron Rompen is appreciated, and has over 900 Karma points.
Send a message via AIM to Ron Rompen
Default
I haven't run into quite this problem before, but I believe I know a way around it, presuming you have sufficient information.
If you know the chemical makeup of the product, you can create an IMDS entry for it as a stand-alone; then reference that one in your component IMDS.
Ron S Rompen
Goju Ryu
Kitchener, Ontario
Do other dogs think that poodles are members of some strange religious cult?
Old 6th December 2005, 04:21 AM
Involved - Posts
Karma Power: 20
Default Insulation Material
The above mentioned CaZn Complex is a content of the Wire Insulation.
Here's the Material Composition of the Wire Insulation (PVC Compound):
Raw Material <CAS Number>
- Polyvinyl chloride (PVC) resin (58%)- <9002-86-2>
- Plasticizer (DINP) (9%) - <68515-48-0>
- Stabilizer (CaZn complex) (25%) - <no CAS # & not in the IMDS Basic Substances>
- Filler (5%) - <system (Further Additives)>
- Others (3%) - <system (Misc.)>
These are the material content I already entered in the Insulation material Subcomponent of a Wire. I used wild cards (pseudo substance) for the Filler & others.
I cannot continue to upload completely the MDS since i lack a basic substance. The Material Composition should be equal to 100%. And i cannot use a wild card for the CaZn since wild cards should not go above 10%.
Why does CaZn not in the list of Basic Substances in the IMDS but it is a widely used Stabilizer?
Any help?...
Old 6th December 2005, 09:16 AM
Craig H. Craig H. is offline
Been around a while
Registration Date: Jan 2002
Thanks Given to Others: 281
Karma Power: 171
Craig H. is appreciated, and has over 1700 Karma points.
Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.
Default
Have you asked your supplier for a MSDS?
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
IMDS Standard material number, definition - AISI 1008 steel juliov RoHS, REACH, ELV, IMDS and Restricted Substances Related Regulations 10 7th December 2008 03:06 AM
IMDS Plating Issues - Need to enter QQ-N-290 Nickel Plating into the IMDS bfd_dan RoHS, REACH, ELV, IMDS and Restricted Substances Related Regulations 3 1st October 2005 03:30 PM
CAS No. - PPAP (I.3 and I.3.1 - requisite 8) Gilberto APQP and PPAP 6 28th September 2005 08:35 AM
Trying to find CAS numbers - The Database of chemical substance information Giselle ISO/TS 16949 - International Automotive Quality Systems Standard 3 22nd July 2005 12:57 PM
Reliability Prediction of Complex Assemblies SteveTIB Reliability Analysis - Predictions, Testing and Standards 2 1st March 2002 09:34 PM
The time now is 09:16 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
