8th December 2005, 03:50 PM
E-Mails Invalid or Rejected
Registration Date: Aug 2005
Karma Power: 0 Karma: 55
Can Minitab Return specification limits required to achieve a given Cpk?
Yes, I know specification limits should be set and agreed to with the customer. But sometimes a stake needs to be put in the ground to get people talking.
Minitab is happy to report the Cpk values if I supply a target and specifications, is there a way to supply a Cpk value and have it give me the specificaitons that result in that Cpk? Or is there another way to do this? I have been manualy recursing to get this info (Give specs obtain Cpk, adjust specs get new Cpk, continue until converged), but it seems that there should be a quicker way.
Thanks for any help.
8th December 2005, 04:03 PM
yellow #2
Registration Date: Sep 2005
Karma Power: 20 Karma: 63
Originally Posted by davis007
... But sometimes a stake needs to be put in the ground...
Aim higher! The stake belongs above the navel and below the chin.
I've looked for the same thing with no luck. I use the eyeball method.
8th December 2005, 04:12 PM
related question
One other question I meant to ask the gurus. When I use equal sided specifications (High-target = target-minimum), vary the size of the range and plot the resulting Cpm values vs the width of the specification I get what looks like a very straight line. Is this line really straight in all cases? Can I just get two values draw a straight line and obtain my specs to achieve a given Cpm? Is the same true for Cpk? Does it matter if the data is normal or not?
8th December 2005, 04:20 PM
Registration Date: Sep 2003
Thanks Given to Others: 27
Karma Power: 123
Since Cpk is the smaller of
Cpl = (X-bar - LSL) / 3s
Cpu = (USL - X-bar) / 3s
you could work the algebra backwards to solve for USL & LSL.
I get the spec limits at (X-bar) +/- (3*s*Cpk).
Assuming you know X-bar and s for your process, you can just plug in the numbers. Note that only one of the spec limits must be at the numbers listed above. The other one could be anywhere farther out and you would still get the same Cpk
Added after seeing the second post:
As for plotting a straight line, it should work. I wouldn't have thought to do it that way, but it makes sense after a little thought. If you plot Cpk along the x axis and one of the spec limits along the y axis, then the equation above looks suspisciously like
USL = (X-bar) + (3*s) * Cpk
y = b + m * x
So your graph should be a straight line with a slope m = 3*s and a y-intercept of b = (X-bar)!
Tim F
8th December 2005, 06:03 PM
Courtesy Access
Registration Date: Oct 2004
Thanks Given to Others: 109
Karma Power: 94 Karma: 3086
First, you can always calculate Cpk in Excel and use the "Solver" function ( Tools-->Sol ver) to determine the specification limits.
Second, I'm not sure what you are looking to prove through this exercise. What will happen is that the specification limits required to meet the desired Cpk may end up so large that you could drive a Mack truck through them.
Out of curiosity, what are you looking to prove?
Wayne
8th December 2005, 06:33 PM
Not really trying to "prove" anything. Have a new product rolling out and am in the process of working up specifications. The customer is requesting 6 sigma level of performance, but does not seem to be willing to give a specification range for the parameters of interest. For example after several conversations about a key dimension the response on the specifications was we need the dimension to be x inches. No range for acceptance just the center point. So my question is in this case what would you propose for a specification and tolerances? X +/- 0.5%, 1.0%, etc? It turns out my equipment will operate at 6 sigma level at +/- 0.35%. So lacking any other information from the customer and using my best guess as to whether or not this will meet there needs I plan on proposing this as the specification. If nothing else I hope to get some type of dialog started with the customer. If they suggest a wider range great, if they want a narrower spec, I already have some idea what that will cost me in productivity, scrap, etc. As I indicated in the first post this is just a stake in the ground to try and get a process that is stalled, not on our end, rolling again..
8th December 2005, 07:59 PM
Courtesy Access
I had a feeling this was the direction you were heading but just wanted to be sure. Something to keep in mind is that Cpk is measurement of a process against specification limits. Process capability measurements don't necessarily equate into a "quality" product.
Let's take a process that we'll assume is in control but has a poor Cpk index when compared to a tolerance of +/- 0.020". We can increase the Cpk value to 1.66 if we increase the tolerance to +/- 0.100".
Now we take a part (B) which mates to the first part (A). Part "A" is at X+0.050" and Part "B" is at X-0.050". The stackup yields a gap of 0.100". Both parts are clearly acceptable when checked individually, but when used together the gap would be 0.060" greater than the narrower tolerance even though the narrower tolerance yields a lower Cpk.
Tolerances shouldn't be decided solely based upon some index without regards to other factors involved. Just recently I was involved in a similar discussion with our engineering group regarding a new product and their focus on a "good" Cpk versus what truly makes sense.
For your particular application it may work to go the route of setting tolerance limits based on the ability to achieve a certain Cpk value, but that isn't always the case.
Just food for thought.
Wayne
9th December 2005, 09:46 AM
Thanks for the insite. In this case we are not talking about parts that mate together, but your point is well made.
