Go Back   The Elsmar Cove Forum > Manufacturing, Service, and Business Systems Processes > Reliability Analysis - Predictions, Testing and Standards
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 12th December 2005, 10:20 AM
jkittle jkittle is offline
Involved - Posts
Registration Date: May 2005
Thanks Given to Others: 15
Karma Power: 22
jkittle has less than 100 Karma points so far.
Question Reliability Questions - System vs Component Reliability - Target Values
Can anyone tell me what the difference is between system and component reliability target vales? I have a new project that is being launched and this is part of my planning requirements.
Sponsored Links
Old 12th December 2005, 10:38 AM
Rob Nix's Avatar
Rob Nix Rob Nix is offline
qualitas ad nauseam
Registration Date: Sep 2003
Thanks Given to Others: 3
Karma Power: 79
Rob Nix is appreciated, and has over 1700 Karma points.Rob Nix is appreciated, and has over 1700 Karma points.Rob Nix is appreciated, and has over 1700 Karma points.Rob Nix is appreciated, and has over 1700 Karma points.Rob Nix is appreciated, and has over 1700 Karma points.Rob Nix is appreciated, and has over 1700 Karma points.Rob Nix is appreciated, and has over 1700 Karma points.Rob Nix is appreciated, and has over 1700 Karma points.Rob Nix is appreciated, and has over 1700 Karma points.Rob Nix is appreciated, and has over 1700 Karma points.Rob Nix is appreciated, and has over 1700 Karma points.Rob Nix is appreciated, and has over 1700 Karma points.
Default
They are at different ends of the reliability spectrum. Component reliability is the reliability of each of the "pieces" of the product, subsystem, and/or system (e.g., a switch, diode, connector, clamp, etc.), and the target is generally the historic reliability (or a little better with improved designs) of past component performance.
System reliability is the composite reliability of all components and/or 'subsystems made up of many components'. The targets established for system reliability are based on calculating all of the 'pieces', whether they are in series or parallel, and other factors. These calculations require some knowledge and background into reliability engineering. I've tried to simplify it as much as possible above. Please tell us a little more about your specific situation.
Rob - The sum of anecdotes is not data. -Roger Brinner
Sponsored Links
Old 12th December 2005, 10:39 AM
Tim Folkerts's Avatar
Tim Folkerts Tim Folkerts is offline
Thanks Given to Others: 27
Karma Power: 123
Tim Folkerts is appreciated, and has over 1700 Karma points.
Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.
Default
Consider a car engine. Component reliability is how well each part works -- the fuels pump is 99.2% reliable, the spark plugs are 99.996% reliable, etc... System reliabilty is how well the whole system works when put together. System reliability can be improved by such approaches as including parallel components and redundancy.
Tim F
Old 12th December 2005, 10:49 AM
Involved - Posts
Karma Power: 22
Default Reliabilty
Tim,
I hate to be so ignorant on this subject but what do you mean by "System reliability can be improved by such approaches as including parallel components and redundancy" What do you mean by parallel components and redundancy? I am not a reliability engineer and not very familiar with any terms associated with reliability. Thanks for your help!
Jerry
Old 12th December 2005, 11:05 AM
Karma Power: 123
Default
Parallel means two (or more) items that both perform a particular task at the same time. For example, a truck might have dual tires, so that if one fails, the truck can still operate - perhaps not quite at 100%, but well enough to get by until repairs can be made.
You can also have standby components or systems. For example, an emergency generator for a hospital. This systems only kicks in when there is a failure in the primary system. The space shuttle has - I believe - 5 computers! to manage key tasks. Even if 4 of them fail, the fifth can still handle the task.
Both of these set-ups would be considered redundant, since they are not needed as long as things are working properly.
Tim
P.S. I moved & merged the posts from two other threads. I don't see any forum specifically for reliability, but this seemed like a good choice.
Old 12th December 2005, 12:06 PM
Rob Nix's Avatar
qualitas ad nauseam
Karma Power: 79
Default
Tim makes good points of which I only alluded to (i.e. series vs. parallel systems). Not to be a killjoy, but like I said earlier, if you do not have some background here, it might be difficult to accomplish your task.
Again, we might be able to help if you give us some details on the specific product you are working on and what you are expected to accomplish.
Old 12th December 2005, 12:44 PM
Involved - Posts
Karma Power: 22
Default Reliability
The project is the launch of a new entrance door on a school bus.
The old door has premature seal failures and frame failures. The new door takes care of these issues and is cheaper as well.
Old 12th December 2005, 01:35 PM
Statistical Steven's Avatar
Statistical Steven Statistical Steven is offline
Consultant
Thanks Given to Others: 36
Karma Power: 43
Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.
Send a message via Yahoo to Statistical Steven
Default
Component Failure are:
Seals
Hinges
Glass
Material (metal that rusts, plastic that cracks, etc.)
System Failure would be the door fails to work.
An example of a redundant system would be if the door opened electronically, but there was still a manual door open in the event the electronic one did not work.
Does that help?
Steven Walfish
When in doubt, ask your company statistician!
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Reliability Prediction - Predicting the Reliability of an Inductor (Semi-conductor) QE Reliability Analysis - Predictions, Testing and Standards 8 6th November 2009 12:09 PM
Confidence and Reliability - Reference to a 90/95 confidence and reliability level johnnyB Reliability Analysis - Predictions, Testing and Standards 18 15th June 2009 07:58 PM
Accuracy of the SN 29500 FIT values - Reliability Forecast and PPM trevor_says_hi Reliability Analysis - Predictions, Testing and Standards 3 16th August 2008 03:32 PM
Calculating Series System Reliability and Reliability for Each Individual Component jag53 Reliability Analysis - Predictions, Testing and Standards 4 17th April 2006 09:20 AM
System Reliability Projections using the Series Probability Formula SteveTIB Reliability Analysis - Predictions, Testing and Standards 2 16th April 2002 03:04 PM
The time now is 12:38 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
