Elsmar Cove Quality DiscussionsThe standard for temperature range to be controlled - ISO 17025 Inspection LaboratoryThe Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > > >
Forum Username
Wooden Line
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links Elsmar Cove visitors will find useful in the quest for knowledge and support:
Jennifer Kirley's
Conway Business Services
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Ajit Basrur
Claritas Consulting, LLC
International Standards Bodies - World Wide Standards Bodies
International Organization for Standardization - ISO Standards and Information
Quality Digest
Reply
  Post Number #1
Old 14th December 2005, 06:20 PM
GregC
Question The standard for temperature range to be controlled - ISO 17025 Inspection Laboratory
What is the standard for temperature range to be controlled in a ISO 17025 Inspection Lab. We Certify Automotive Check Fixtures
Sponsored Links
  Post Number #2
Old 15th December 2005, 01:50 AM
Hershal's Avatar
Hershal
If there is an automotive standard for that which defines the parameters, then that will provide details. Otherwise I may suggest a similar environment to an electronic calibration lab.....23 +/-3 C, 40 +/- 5% RH.
Hershal
  Post Number #3
Old 15th December 2005, 08:26 AM
Ken K's Avatar
Ken K
These are the requirements for test lab conditions.
GM - 21 +/-2C 50 +/- 5% RH
Ford - 23 +/-2C 50 +/- 5% RH
DCX - None Listed
Toyota - 20 +/-2C 65 +/- 5% RH
Hope this helps.
  Post Number #4
Old 15th December 2005, 08:53 AM
GregC
Thanks, This does help. It appears there is no set mean temp, but there is a +/-2C parameter. I guess it's who you are building for.
  Post Number #5
Old 16th December 2005, 10:35 AM
W. de Jong's Avatar
W. de Jong
Influence of dT
We examined the influence of the dT within extremes of our daily temp. range. Then we put it in our uncertainty budget. In our case the influence was very small in relation to our certified uncertainy (0,5% rel). If possible i'd try that option as well. If its a risk factor then control the ambient temp.
BR
  Post Number #6
Old 20th December 2005, 08:16 PM
Grizz1345's Avatar
Grizz1345
Lab Controls
According to ANSI/ASME B1.2-1983 2.4 Temperature 2.4.1 states A temperature of 68 degrees F(20C) is the standard temperature used internationally for linear measurements. Nominal dimensions of gages and product as specified and actual dimensions as measured shall be within specified limits at this temperature. For screw thread gaging, the acceptable tolerance on the standard temperature is ±2F (±1C). Hope this helps. Merry Christmas to all
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Emoticons are On
[IMG] code is On
Similar Discussion Threads
Calibration Laboratory Temperature of 20?C ?1? C & Laboratory Personnel SATHYABALARAMAN General Measurement Device and Calibration Topics 7 3rd April 2013 01:19 AM
What is the temperature range for drug manufacturing? Ethan Loh Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and other related Regulations) 4 29th March 2011 01:31 PM
Inspection Humidity Control - Range for Mechanical Inspection Rick Hart Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1 14th June 2010 02:56 PM
Mass vs. Temperature vs. Time - Determining Time in a Temperature Controlled Room djaphro Manufacturing and Related Processes 5 26th March 2008 06:41 PM
Help DOD inspection - Standard temperature calipers should be calibrated at? megan c General Measurement Device and Calibration Topics 7 26th October 2004 01:10 PM
The time now is 09:49 PM. All times are GMT -4.
Misc. Internal Links
NOTE: This forum uses "Cookies"
