Go Back   The Elsmar Cove Forum > National and International Business Standards > FDA (United States Food and Drug Administration) > Medical Devices (21 CFR part 820)
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 19th December 2005, 11:19 AM
Paul22 Paul22 is offline
Registered Visitor
Registration Date: Sep 2004
Thanks Given to Others: 4
Karma Power: 21
Paul22 has less than 100 Karma points so far.
Please Help! Temperature indication In Vitro Medical Devices USA
Dear all,
I can't find at the FDA website wether a temperature indication (for storage) of In Vitro Medical devices should be either in degrees ceelcius (°C) or degrees Fahrenheit (°F) or perhaps even both.
Does somebody knows? Thanks.
Paul
Sponsored Links
Old 21st December 2005, 01:23 PM
Al Rosen's Avatar
Al Rosen Al Rosen is offline
Registration Date: Jun 2002
Thanks Given to Others: 48
Karma Power: 192
Al Rosen is appreciated, and has over 1700 Karma points.
Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.
Send a message via AIM to Al Rosen
Default
Originally Posted by Paul22
Dear all,
Paul
I don't know that the FDA specifies this, but degrees farenheit is the most common temperature scale used in the USA. I have noticed that some FDA documents specify temperature in degrees C with the degrees F value in parentheses, for example, Review Criteria Assessment of Portable Blood Glucose Monitoring In Vitro Diagnostic Devices Using Glucose Oxidase, Dehydrogenase or Hexokinase Methodology states,
  1. Extended exposure to air and light may alter results. It is recommended that the strips be stored in the original capped vial at temperatures below 30 ° C (86 ° F). Avoid exposure to excessive humidity; do not freeze.
I have seen device labeling with only degrees C. I have used degrees F with degrees C in parentheses. I don't think you will have problem with any way you do it, as long as it is clear which temperature scale you are using.
Al
Sponsored Links
Old 23rd December 2005, 04:24 AM
Registered Visitor
Karma Power: 21
Default
Thanks Al,
I will consider your proposal. In my opinion it seems also the best to use both temperature units.
Have a Merry Christmas and a Happy 2006
Paul
Originally Posted by Al Rosen
I don't know that the FDA specifies this, but degrees farenheit is the most common temperature scale used in the USA. I have noticed that some FDA documents specify temperature in degrees C with the degrees F value in parentheses, for example, Review Criteria Assessment of Portable Blood Glucose Monitoring In Vitro Diagnostic Devices Using Glucose Oxidase, Dehydrogenase or Hexokinase Methodology states, I have seen device labeling with only degrees C. I have used degrees F with degrees C in parentheses. I don't think you will have problem with any way you do it, as long as it is clear which temperature scale you are using.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
ISO 25424:2009 Sterilization of Medical Devices Low Temperature Steam & Formaldehyde bio_subbu ISO 13485 - Medical Devices - Quality Management Systems 1 22nd October 2009 03:05 AM
In vitro diagnostic medical devices - Labeling Standards EN 375, EN 591 cwokeeffe ISO 13485 - Medical Devices - Quality Management Systems 6 6th August 2009 11:11 AM
Exporting medical devices to Australia - Regulatory system for medical devices Bridget Various Other Specifications, Standards, and related Requirements 23 9th December 2006 02:38 AM
Calibration of Thermometers and Temperature Sensitive Devices Garner Davis ISO 17025 - Calibration, Measurement Gages and Test Laboratories 15 11th August 2006 05:18 PM
Accelerated Stability Studies - In vitro Diagnostic Devices Vincnet ISO 13485 - Medical Devices - Quality Management Systems 2 23rd December 2003 04:21 AM
The time now is 08:37 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
