The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 17025 - General Metrology, Measurement Device, Calibration and Test Laboratories > Gage R&R (GR&R) and MSA (Measurement Systems Analysis)
Forum Username
Elsmar Cove Forum Sidebar
Custom Search
Monitor the Elsmar Forum
Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Sponsor Links
Sponsored Links
Courtesy Quick Links
Howard's
Atul's
Symphony Technologies
Marcelo Antunes'
SQR Consulting
Bob Doering's
Quality Digest Portal
Related Topic Tags
destructive tests and testing, gage r&r (repeatability and reproducibility), jmp - statistical analysis software, tolerances (dimensional or other units)
Reply
Old 28th December 2005, 01:47 PM
Bookworm Bookworm is offline
Registration Date: Dec 2005
Karma Power: 31
Bookworm has less than 100 Karma points so far.
Please Help! Destructive Testing GR&R (Gage R&R) - Track tester - JMP Program
First and foremost, please bear with me since I am new to Gage R&R testing
I'm trying to run a GR&R test for a track tester. Basically the machine is programmed to push a device in a pre-fabricated track and record its force measurements over a programmed distance. Once a test is run once, the testing material will get deformed, so running the same material through the tester again would give different force measurements.
Since this is a destructive test, do I calculate values like the % Gage R&R in the same manor as I would a non-destructive test? Do I have to actually find a way to change my testing procedure to make it non-destructive? Any ideas?
Also, I'm using the JMP program which asks me to enter a tolerance value (USL-LSL), and I'm not really sure what value I should enter into here, but I know what I enter here has a dramatic effect on my % Gage R&R value.We have no set tolerances or standard devices to use as reference since this is a first round series of tests. Is it then up to the engineers best educated guess on this tolerance value?
Sponsored Links
Old 28th December 2005, 02:55 PM
Miner's Avatar
Miner Miner is offline
Registration Date: Apr 2002
Thanks Given to Others: 557
Karma Power: 389
Miner is appreciated, and has over 1700 Karma points.
Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.
The MSA manual 3rd edition has a section (Chapter IV - Section A & C) that deals with destructive testing.
You can also perform a nested gage R&R.
There are two basic approaches to obtaining the necessary repeat measurements. One is to collect the test specimens, and sub-divide them into smaller samples if possible. This would work for chemical testing and similar needs. The second approach is to use consecutive homogeneous parts from a single lot for the repeats, and parts from different lots for the "parts" themselves.
I am not familiar with JMP, but MSA software is normally looking for the tolerance range (USL minus LSL). Do you have a unilateral tolerance (i.e., a max or min spec)?
Unless your customer requires the P/T Ratio (uses tolerance), you may be better off using the %GRR, which is GRR as a percent of the process variation. This does not use the tolerance, and is better suited to evaluate the gage's suitability for process control.
Also, search this forum. There are a lot of threads dealing with GRR and destructive testing.
"A fool can learn from his own experiences; the wise learn from the experience of others." - Democritus, 460-370 B.C.
Sponsored Links
Old 28th December 2005, 05:22 PM
Karma Power: 31
[The second approach is to use consecutive homogeneous parts from a single lot for the repeats}
So then basically I could measure one design of a device from one lot and then measure the same design of a device from the same lot and compare those results to get my gauge value? And this process is called Nested gage R&R?
I mentioned that the device will permanantely deform after one run. Will I be able to see if there is uniformity in force measurements after deformation between devices if I ran each device two times and compared all force values from the first and second run to get a %GRR? Or should I compare them seperately? ie: find a %GRR for Run 1 of two devices from a single lot, and another seperate %GRR for Run 2 of those same devices
{and parts from different lots for the "parts" themselves}
Finally I wasnt sure what was meant by this statement. Would you mind clarifying? Thanks again!
Old 2nd January 2006, 11:02 AM
Miner's Avatar
Karma Power: 389
In Reply to Parent Post by Bookworm
For the sake of discussion, lets use the "standard" 10 parts x 3 repeats x 3 operators MSA layout. In your situation, the 10 parts would be 10 different lots of the product. These should be the same design, but different lots. Different designs will inflate your process variation (PV) and give you erroneous results. The three repeats and three operators would be 9 consecutive parts. Operator 1 would test parts 1, 4 & 7. Operator 2 would test parts 2, 5 & 8, and Operator 3 the remainder. Analyze the results using the ANOVA method for a nested study. A crossed study is the normal method used when parts can be measured repeatedly. A nested study is used when the can only be measured once.
An MSA is not really the correct method to use for this. You could perform an MSA on the 1st time results, and a second MSA on the 2nd time results to see whether a pretest reduces test variation (your second option). To quantify the change between tests, you have a number of options, including but not limited to regression analysis. Your first option would inflate the process variation and give erroneous results.
See the first section response.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Gage R&R - Destructive Test - Tensile Tester Denise Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 17 6th April 2012 06:03 PM
Part Variation, Unilateral Tolerance, Destructive Testing - Gage R&R Experts pls help Delajo1 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12 13th October 2009 06:48 PM
Help With GR&R (Gage R&R) on JMP ***JMP people please help*** Tres0422 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2 10th February 2009 02:39 PM
How do I do Gage R&R in Destructive Testing? shahshahani Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2 11th January 2003 05:45 AM
Gage R&R Destructive Tests - Tensile tester to check for paper strength Beard Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3 26th April 2000 04:16 PM
The time now is 09:10 PM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, Olde West Chester, Ohio 45069-1929
513 341-6272
