The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > SPC Monitoring and Statistical Analysis Techniques
Forum Username
Elsmar Cove Forum Sidebar
Custom Search
Monitor the Elsmar Forum
Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Sponsor Links
Sponsored Links
Courtesy Quick Links
Howard's
Atul's
Symphony Technologies
Marcelo Antunes'
SQR Consulting
Bob Doering's
Quality Digest Portal
Reply
Old 6th January 2006, 01:06 PM
chiragtilara chiragtilara is offline
Registered Visitor
Registration Date: Apr 2005
Karma Power: 35
chiragtilara has less than 100 Karma points so far.
Quid Pro Quo I need help verifying formula's in a database for LCL UCL Cp Cpk PPk
Hello everyone:
I have developed a MS access database which captures data from our legacy LIMS (I would not really say it is LIMS). The visual basic code behind the scene does all statistical calculations like determining LCL;UCL;Cp;Cpk; Ppk and Normality Studies.
Since I do not have sophisticated statistical program which can automatically figure out these parameters, I need your help to find out whether my calculations are correct.
I have attached a spreadsheet having 3 products and their viscosities by batch number. I treated them as individual measurements (for statistical calculations) and plotted Run Chart, Range Chart (individual), calculated LCL, UCL, Cp, Cpk, Ppk and plotted a normal probability plot using a equation that I found in one literature. Also the LSL and USL are 250,000 and 600,000 cP respectively
It would be great if you can punch this data into software you have (minitab etc.) and send a snap shot of results. It would be great if the snapshot shows important parameters like control limits; capability and normality parameters.
I would like to compare the results that you got against mine. If any one is interested in my results let me know.
Thank you in advance.
Chirag Tilara
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting this post, 3. Use at your Own Risk.
Sponsored Links
Old 6th January 2006, 04:27 PM
Miner's Avatar
Miner Miner is offline
Registration Date: Apr 2002
Thanks Given to Others: 557
Karma Power: 391
Miner is appreciated, and has over 1700 Karma points.
Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.
Here you go.
"A fool can learn from his own experiences; the wise learn from the experience of others." - Democritus, 460-370 B.C.
Sponsored Links
Old 7th January 2006, 08:47 AM
Registered Visitor
Karma Power: 35
Hi Miner:
Thanks for your prompt reply. My results are comparable against those of yours. I am assuming that you use Minitab. Attached are results from my database. Let me know what you think, I should change to make the database better.
Chirag
Old 9th January 2006, 09:52 AM
Darius's Avatar
Darius Darius is offline
Appreciated Information Resource
Registration Date: Mar 2002
Thanks Given to Others: 64
Karma Power: 99
Darius is appreciated, and has over 1700 Karma points.
Darius is appreciated, and has over 1700 Karma points.Darius is appreciated, and has over 1700 Karma points.Darius is appreciated, and has over 1700 Karma points.
I checked the report
Maybe I miss something but looks OK, there is a small issue, altho I may be agree with you..., it's not usual to represent target and spec limits in a control chart.
The reason of this idea (not showing specs on a SPC Chart) is because the control has nothing to do with specs, the SPC chart show your process behabiur, the variation and whereabouts.
Looks like SPC take in account that you are centered on specs or leave it to the capability index. You can even check on patterns and nobody will tell you as a pattern out of specs (We are talking on SPC, not precontrol).
Vits er thorf, theim vitha ratar; daelt er heima hvat; at augabragthi verthr, sá er ekki kann ok med snotrom sitr.
Old 9th January 2006, 10:01 AM
Jim Wynne's Avatar
Jim Wynne Jim Wynne is offline
Cross Forum Moderator
Registration Date: Jan 2005
Thanks Given to Others: 1,805
Karma Power: 1451
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
In Reply to Parent Post by Darius
Darius,
In my experience, it's fairly common to show spec limits on control charts. In fact, seeing the spec limits can obviate the need for Cpk calculations. At the same time, with a relatively wide specification band and a well-centered process, the x-axis might get too big. At any rate, they usually do no harm, and might be useful. We should assume that people using control charts have been trained and understand the difference between control and specification limits.
Everyone has a plan until they get punched in the face (Mike Tyson)
Old 10th January 2006, 09:12 AM
Darius's Avatar
Karma Power: 99
JSW05 Wich stat software do you use?, maybe I have to change.
Old 10th January 2006, 09:20 AM
Jim Wynne's Avatar
Karma Power: 1451
I don't use any at the moment; I was just making the point that the inclusion of specification limits is not something that needs to be avoided unless there's a special reason (such as an overly spread-out x-axis) for doing so. Lots of people use Excel or paper or some other means where it's possible to include the spec limits; I don't know how the various commercial packages treat the subject.
Old 11th January 2006, 05:45 PM
dfirka dfirka is offline
Involved - Posts
Registration Date: Nov 2003
Karma Power: 42
dfirka has less than 100 Karma points so far.
question about Minitab results
Regarding the results shown by Miner done with minitab:
Does anyone knows which formula is being used for the standard deviations in the example?
1) At product A, Minitab gives Overall StdDev: 78265, but using Excel and also in Chirag's Soft, we get 78095. The other products show similar discrepancies.
2) In addition, I dont understand the value "within variation", that I suppose should be based on Moving Ranges... but if I calculate Avg(RMov)/d2 for Product A, it's 65120, very different from Minitab's 73901.
Maybe Minitab is using another formula (for 1) or arrange the data in a different way (for 2)
Any ideas?
Thxs
Daniel
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Validation of Cpk and Ppk calculations - Sheet to check Cpk and Ppk values Howard Atkins SPC Monitoring and Statistical Analysis Techniques 4 5th June 2011 11:19 AM
How to calculate for LCL and UCL for Schedule Deviation vanitha250 Quality Tools, Improvement and Analysis 2 11th November 2010 12:16 PM
What is the difference between UCL, LCL and Cp, Cpk blue moon Capability, Accuracy and Stability - Process, Machine, etc. 3 12th February 2009 08:07 PM
When to change UCL and LCL - SPC Software war-eagle SPC Monitoring and Statistical Analysis Techniques 4 15th December 2008 12:50 PM
Self define the UCL and LCL instead of by Calculation dvd101 SPC Monitoring and Statistical Analysis Techniques 12 11th July 2008 10:13 AM
The time now is 02:04 AM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, Olde West Chester, Ohio 45069-1929
513 341-6272
