Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
11th January 2006, 08:18 AM
Shy Poster (1 to 5 Posts)
Registration Date: Dec 2005
Karma Power: 31 Karma: 10
Process Interaction Chart example as required by ISO 13485 2003
Hi could anyone provide me an example of a Process Interaction Chart as "required" by ISO 13485 2003?
Regards, Robert
11th January 2006, 10:54 AM
Registration Date: Jun 2002
Thanks Given to Others: 71
Karma Power: 413
In Reply to Parent Post by hofrob
Regards, Robert
There are numerous examples already attached in posts. You can find them by using the search towards the top of the page. You can also scroll down the page that your post appears on and find similar threads that may contain what you are looking for. The requirement for ISO 13485 is the same as ISO 9001.
Al
1st December 2008, 01:53 PM
Registration Date: Oct 2008
Karma Power: 19 Karma: 10
Re: Process Interaction Chart example as required by ISO 13485 2003
Regards, Robert
ISO 9001:2000 - A Process Interaction Matrix
A Case Study
By Mark Kaganov
This article was originally published by Quality Progress in October 2004, p 194
Abstract
This article presents a case study of development and implementation of a process interaction matrix to address one of the requirements of ISO 9001:2000 standard [1]. Going beyond a simple case study model, this tool may also be used for quality management systems (QMS) compliant with ISO 13485:2003 standard [2]. This article will be of interest to companies developing or improving their QMS for such standards.
Introduction
One of the new requirements of ISO 9001:2000, specified in the paragraph 4.2.2 c), requires a company to develop a quality manual that, among other attributes, shall contain “a description of the interaction between the processes of the quality management system.” Through my experience, as a professional auditor, with dozens of companies around the world, I found that very few businesses had developed practical approaches to address this requirement. Attempts to document process interactions range from busy and hard to read flow charts to establishing cross-reference tables in the quality manual. I observed one of the best tools to address process interaction requirement at Quality Works, a small on-line publishing company. ...
For the entire paper visit quality-works website
1st December 2008, 02:45 PM
Appreciation Courtesy Access
Registration Date: Mar 2004
Thanks Given to Others: 145
Karma Power: 73
Hello mkaganov,
I have to wholeheartedly agree with your comment that "few companies have developed a practical approach to addressing this requirement".
However, while the referenced Model (from Quality Works) provides an interesting cross-reference of the how the Standard interfaces with the Business Operating System, it does not answer the question of how the processes in the system interact with each other, and most certainly sheds no light on their sequence. It does not meet the requirement. I would not recommend it as the solution to the question posed.
Patricia Ravanello
1st December 2008, 03:15 PM
Patricia,
I am lost! Where did you see a “cross-reference of the how the Standard interfaces with the Business Operating System” on our Process Interaction Matrix? The table at http://**********/article-process-interaction.htm shows ONLY processes that a company uses. While you stated that “… it does not answer the question of how the processes in the system interact with each other” symbols “<” and “>” show these interactions per the legend on the bottom of the chart. While you also noted that it “… certainly sheds no light on their [processes] sequence”, the arrow next to the product realization processes defines exactly that sequence. Take another look at it – it is a cool tool and hundreds of companies are using it.
Regards,
Mark Kaganov
Reason: Link removed per TOS.
1st December 2008, 03:46 PM
Karma Power: 73
In Reply to Parent Post by mkaganov
Patricia,
I am lost! Where did you see a “cross-reference of the how the Standard interfaces with the Business Operating System” on our Process Interaction Matrix? The table at http://********/article-process-interaction.htm shows ONLY processes that a company uses. While you stated that “… it does not answer the question of how the processes in the system interact with each other” symbols “<” and “>” show these interactions per the legend on the bottom of the chart. While you also noted that it “… certainly sheds no light on their [processes] sequence”, the arrow next to the product realization processes defines exactly that sequence. Take another look at it – it is a cool tool and hundreds of companies are using it.
Regards,
Mark Kaganov
Hello Mark,
I owe you a partial apology. The PDF version posted is not very clear, even if enlarged, and I mistakedly assumed that the processes listed down the left-hand column represented the elements and sub-element of the standard (hence, my comment regarding the "interface of the standard with your system processes). I see now, that the same processes are listed both down and across the matrix.
So let me restate my commnets...the matrix referenced still falls short of the requirement to identify/define the "Management System Processes" (not every sub-process in the organization), and to demonstrate their sequence (not just Product Realization) and interaction.
As an example...if I go to your 'Purchasing Process" in the left column, it appears to have no interface with the "Corrective Action Process" or the "Management Review Process"....I could go on with several similar "lacking interfaces"...I think you get my point.
I believe the point of this exercise is to capture the dynamics of the "Business/Management/Quality Operating System", thereby demonstrating an organization's understanding and vision of the "System"...and not necessarily to try to capture and interrelate all the nuances of every process and sub-process.
As you mentioned, most companies have failed to identify a practical approach to this, because they are trying to capture too much information in one model, and end up with a document that fails to really provide any value to anyone.
The model provided still does not address the requirement, as I understand it.
 Patricia
1st December 2008, 05:20 PM
Patricia,
P: I owe you a partial apology.
M: Accepted, if you send me your root cause analysis
P: "...the matrix referenced still falls short of the requirement to identify/define the "Management System Processes" (not every sub-process in the organization), and to demonstrate their sequence (not just Product Realization) and interaction."
M: This matrix was not intended to be a complete list of processes for every compnay. This is an example for a given compnay and specific set of process.
P: ...if I go to your 'Purchasing Process" in the left column, it appears to have no interface with the "Corrective Action Process"
M: Look at the "Purchasing" in the horizontal line on the top - here are all your interfaces with CAPA, MR, etc.
P: The model provided still does not address the requirement, as I understand it.
M: Training, trainig and training... Visit our ********and give me a call. I think I can help you.
Regards,
Mark
1st December 2008, 08:54 PM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 7,541
Karma Power: 400
 While I appreciate your offer to help on a personal level, this forum is really more geared towards helping people here in the forum rather than referring people to your web site and/or business. Your participation here is appreciated, but self promotion is a touchy subject here.
One Test is Worth 1000 Expert Opinions - The plural of anecdote is not data - Correlation does not imply Causation
Forum Posting Settings
