Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
12th January 2006, 05:32 PM
E-Mails Invalid or Rejected by Recipient System
Registration Date: Sep 2000
Thanks Given to Others: 5
Karma Power: 0
Measurement comparison for CMMs?
I have been contacted by someone looking for something that is not in my area of expertise ... so I hope some one can help. since I am not familiar with the work area or equipment, I hope I am interpreting this correctly -- and that this forum is appropriate.
A company has a CMM that is calibrated by the manufacturer. There are some questions about measurements. I believe they are looking for some kind of measurement comparison program, an arrangement is send to different participating organizations to be measured. The measurements are reported and analyzed anonymously. the ressults are an overall set of values and uncertainty for the dimensions of the artifact, and a report to each organization about how well they perform compared to the others.
Is there such a program that anyone knows of?
TIA,
12th January 2006, 05:54 PM
Courtesy Access
Registration Date: Jun 2002
Thanks Given to Others: 63
Karma Power: 112
I've never heard of this program, but we just bought a new CMM and after it was set up and calibrated by the manufacturer, we did a Gage R&R study to further validate it.
I'm not sure why it would be necessary to validate it outside your own operation, unless there is a concern about CMM measurements in general. I know we have non-believers in my company, despite doing a gage R&R comparison study to manual gaging that laid to rest any questions.
Darn Luddites!
Rosie A
Warrior Goddess of Quality
13th January 2006, 03:28 AM
Forum Administrator
Registration Date: May 2000
Thanks Given to Others: 917
Karma Power: 400
In Reply to Parent Post by Graeme
We did something similar with the tensile testers in our group. I don't know the details, but doing the same thing for CMM's could have merit. It feels good to know that results match... or not, in which case it's important to find out why.
/Claes
13th January 2006, 04:33 AM
Involved - Posts
Registration Date: Nov 2005
Thanks Given to Others: 28
Karma Power: 52
Hello Graeme !
My interpretation may be wrong. Here it is. We use video CMM's for plastic part measurement.
I have met the situation, when a tool was approved, based on product dimensions, and when we got it, my measurements were out of tolerance. We use in different factories, several types of CMM's, fixtures, are manufactured in different places, and the measuring prgrams are build by different persons. So shortly, when I have a global project, when parts are manufactured in different plants, and dimensions are critical for assembly, I do the following:
Prepare one set of samples
Run gage R&R in my factory, and I'm participating in it.
My mesurement is the standard
Then send samples, to first second and third factory, and they perform the measurement on the same samples.
For me the most important, is how far are they, from my measurement, and not the R&R results.
Just my approach, to the problem described above, if I did not missunderstud.
I suppose that you know, how a video CMM is calibrated. There is a standard program, run on a calibrated etalon.
György
13th January 2006, 09:17 AM
Registration Date: Apr 2002
Thanks Given to Others: 555
Karma Power: 389
I remember seeing an ASQ publication years ago that dealt with inter-laboratory correlations. I don't know if it is still available.
There a several other options that come to mind. One would be to perform an MSA using the different CMMs as different operators. The Reproducibility would be the measurement variation between CMMs.
Another would be to scatter plot, box plot or perform regression analysis between labs.
"A fool can learn from his own experiences; the wise learn from the experience of others." - Democritus, 460-370 B.C.
13th January 2006, 09:29 AM
Cross Forum Moderator
Registration Date: Jan 2005
Thanks Given to Others: 1,779
Karma Power: 1445
TIA,
This is known as "round robin" testing. A group of companies measure the same part--and the results are analyzed. I've attached a research paper from NIST on the subject, which might shed some light. I think that more information may be obtained from CMM manufacturers, who are likely to have similar information.
We aim to please. You aim too, please.
13th January 2006, 10:02 AM
Karma Power: 389
In Reply to Parent Post by JSW05
This would be a good model to base your study on.
However, I would expect much higher variation between CMMs when using actual product and fixtures versus ball-plates. NIST is using a rather idealized situation here with an extremely uniform product and a modular product and fixture.
13th January 2006, 10:09 AM
Karma Power: 1445
In Reply to Parent Post by Miner
Absolutely. When you add the vagaries of drawing interpretation and datum construction the chances for variation increase significantly. This sort of testing must be very carefully designed and controlled if the results are going to mean anything. Part of the design and control might be no control--give someone a part and a drawing and a CMM and see what happens--or it might be controlled for fixturing, integrity of specifications, etc. Like all other experiments, the design depends on what you're trying to find out.
Forum Posting Settings
