Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Records and Data - Quality, Legal and Other Evidence
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 15th September 1999, 12:08 AM
Howard Atkins's Avatar
Howard Atkins Howard Atkins is offline
Forum Administrator
Registration Date: Jul 1997
Thanks Given to Others: 100
Karma Power: 195
Howard Atkins is appreciated, and has over 1700 Karma points.
Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.
Send a message via Skype™ to Howard Atkins
Question Are production samples quality records?
I had a discussion with one of my suppliers as to the length of time it is neccessary to save production samples.
4.16.1 talks about retention of PPAP approvals and quality records. I do not know of any other place that there is a definition of saving samples. My case is that production samples are quality records.
Has anyone got any ideas about this question.
Sponsored Links
Old 15th September 1999, 07:40 AM
Rea Rea is offline
$ Contributor
Registration Date: Nov 1998
Thanks Given to Others: 2
Karma Power: 45
Rea has less than 100 Karma points so far.
As long as you keep the PPAP samples as required then the length of time you keep any other samples would be your own decision. I agree with you they would then be a quality record unless they are from your laboratory and then they would be covered by your lab. scope etc. (4.10.6.3 retention of test samples)
Rea
Sponsored Links
Old 15th September 1999, 07:46 AM
Sam's Avatar
Sam Sam is offline
Registration Date: Sep 1999
Karma Power: 90
Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.
The PPAP manual defines the requirements for "Master Sample"retention on page 14 Para VI.
I do seem to recall reading something about "last off" part comparison, which would indicate that you would retain a part until the end of a production run.
Also your customer may have additional requiremnts.
Old 15th September 1999, 07:51 AM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Question
Let's say you do a first off and last off per setup comparison. Would that be defined in your control plan?
Old 15th September 1999, 11:21 AM
Sam's Avatar
Sam Sam is offline
Karma Power: 90
Yes,I would define it in the control plan, if that method is part of the process.
However, IMO using last part comparison is like final inspection; we really don't trust our in-process controls.
Old 15th September 1999, 02:04 PM
Marc's Avatar
Karma Power: 605
Question
Howard:
Is this what you are referring to? A first off / last off? I haven't seen anything like that with a time defined. I assumed that any retention time for in-process samples was determined by the supplier.
Old 16th September 1999, 12:10 AM
Forum Administrator
Karma Power: 195
I am not referring to PPAP samples rather to samples of a series lot.
I save samples of each lot thus if I receive a non conformance I can check my samples as approved at set up against the non conformance.
Apart from customer requirement does anyone know of a clause that "demands" retention of samples. Does one have to with each approval of PPAP to define the time that you require samples retained?
Thanks.
Old 16th September 1999, 04:11 AM
Marc's Avatar
Karma Power: 605
Yin Yang
That's what I thought you meant, Howard. I cannot remember such a requirement anywhere. The only sample retention requirement I am aware of (other than a customer specific requirement) is the PPAP retention requirement.
You said:
This was not a customer requirement, was it?
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Seeking Production Control Plan samples KidPaddy ISO/TS 16949 - International Automotive Quality Systems Standard 4 26th March 2009 11:39 AM
ISO 9001:2000 4.2.3- Quality Records, Production Travelers JkelleyCDS Records and Data - Quality, Legal and Other Evidence 9 9th September 2008 08:02 PM
Whether the word BETA means prototype samples or the Production samples senthil ISO/TS 16949 - International Automotive Quality Systems Standard 1 29th May 2006 04:19 PM
AS9100 Quality Record - 4.2.4 simply states Records, not Quality Records alrtorrro Records and Data - Quality, Legal and Other Evidence 3 3rd December 2003 09:18 AM
Control of Quality Records - What are the quality records required by QS-9000? Rea Records and Data - Quality, Legal and Other Evidence 3 19th April 2000 07:59 PM
The time now is 04:55 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
