Go Back   The Elsmar Cove Forum > Manufacturing, Service, and Business Systems Processes > Reliability Analysis - Predictions, Testing and Standards
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 1st February 2006, 03:40 AM
patric wessels's Avatar
patric wessels patric wessels is offline
Involved - Posts
Registration Date: May 2004
Karma Power: 23
patric wessels has less than 100 Karma points so far.
I Say... Grubbs Test for Outliers and Why there are no Z-values for N>25
Dear all,
I am not sure if this is the right forum for this subject, but here's the question:
We are trying to assist our operators in determining whether a measured point is an outlier or not. We want to use the Grubbs test for this purpose. The problem is that in case of a large sample we measure 120 points and the tables with the Z-values (for 99% probability) only goes up to 25 samples points.
I am not an expert in statistics but I am sure there is a reason for this.
Can anyone help me out and explain why there are no Z-values for N>25?
Thanks.
Best regards,
Patric Wessels
QA Engineer
Sponsored Links
Old 1st February 2006, 02:36 PM
Miner's Avatar
Miner Miner is offline
Registration Date: Apr 2002
Thanks Given to Others: 166
Karma Power: 251
Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.
Default
Originally Posted by patric wessels
Dear all,
Thanks.
Best regards,
Patric Wessels
QA Engineer
Unless I am misunderstanding your question, a z-table does not depend on sample size. You enter the table using a given z-value and obtain a p-value as an output.
The sample size does come into play when calculating the z-value. See http://www.changbioscience.com/stat/ztest.html for an online z calculator.
Are you sure that you want the z-value? The NIST guide (http://www.itl.nist.gov/div898/handb...on3/eda35h.htm ) shows that the t-value is used for Grubb's test.
"A fool can learn from his own experiences; the wise learn from the experience of others." - Democritus, 460-370 B.C.
Sponsored Links
Old 1st February 2006, 04:02 PM
Tim Folkerts's Avatar
Tim Folkerts Tim Folkerts is offline
Registration Date: Sep 2003
Thanks Given to Others: 27
Karma Power: 123
Tim Folkerts is appreciated, and has over 1700 Karma points.
Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.
Default
I found this table on line that goes up to N = 140. They claim it is for 95% certainty. I tried pasting it here, but it doesn't copy well.
http://www.graphpad.com/articles/grubbs.htm
Also, the NIST Statistics site mentioned on another thread recently has a discussion of Grubbs Test and the formula for calculating the "Critical Z"
I was curious, so I tried a spreadsheet to calculate this, which is attached. You can adjust the alpha level to whatever you want. By playing with the alpha value, I was able to reproduce the table at the first link, so that is pretty good assurance that the calculations are correct. (I included a variety o values for N from 3-1000. For other values you could either estimate between nearby values or just type the number you want in the first column somewhere).
For those, like me, who were rusty on the Grubbs test, basically you calculate the critical value in the table. Then any point more than that many standard deviations from the center is a likely outlier. For example, at N=6 and alpha=0.01, then Z = 2.0; so any point in a set of N=6 that is more than 2.0 standard deviations from the mean is likely an outlier.
Tim F
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting the post it is in, 3. Use at your Own Risk.
Thanks to Tim Folkerts for your informative Post and/or Attachment!
Old 1st February 2006, 04:10 PM
Karma Power: 123
Default
One other side note, some sites seem to call the parameter of interest "Z", others "G", and others "Y". That might be part of the confusion. The "Critical Z" here is not the same thing as the "Z" from the normal distribution tables.
Tim F
Old 5th February 2006, 04:23 PM
Statistical Steven's Avatar
Statistical Steven Statistical Steven is offline
Consultant
Registration Date: May 2005
Thanks Given to Others: 36
Karma Power: 43
Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.
Send a message via Yahoo to Statistical Steven
Default
Tim F
Look into the ESD method.
Steven Walfish
When in doubt, ask your company statistician!
Old 7th February 2006, 08:08 AM
Involved - Posts
Karma Power: 23
Default
Dear All,
Thank you for your contribution to my question. Especially the excel sheet was very helpfull. I think I have a solution for my problem now.
Best regards,
Patric
Old 14th August 2009, 03:47 PM
Campy Campy is offline
Shy Poster (1 to 5 Posts)
Registration Date: Aug 2009
Karma Power: 2
Campy has less than 100 Karma points so far.
Default Re: Grubbs Test for Outliers and Why there are no Z-values for N>25
Note also that ASTM E 178-08: Standard Practice for Dealing with Outlying Observations presents Grubb's test as one method of detecting outliers. Its table goes to n=147 for six different levels of alpha.
Reply
Bookmarks
Tags
grubbs test for outliers, z-values
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Grubbs test to determine one outlier to normalize data Benoit SPC Monitoring and Statistical Analysis Techniques 4 17th August 2009 09:23 AM
Outliers in XmR chart pagnonig SPC Monitoring and Statistical Analysis Techniques 2 16th December 2008 11:46 AM
Hampel Test for Outliers and how it differs from a Grubbs Test for Outliers SteveL SPC Monitoring and Statistical Analysis Techniques 5 22nd November 2007 11:20 AM
Reporting As Found data - Actual before values or test points necessary? Charles Wathen ISO 17025 - Calibration, Measurement Gages and Test Laboratories 2 16th March 2007 01:06 PM
How does Minitab handle outliers in ANOVA? bernchan Using Minitab Software 3 25th April 2006 12:37 PM
The time now is 05:16 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
