3rd February 2006, 04:22 PM
Involved - Posts
Registration Date: Jul 2005
Thanks Given to Others: 1
Karma Power: 21 Karma: 135
E-coat on Galvanized Steel parts - Visible and irregular texture on the surfaces
We are in stamping and welding business in automotive industry. Currently we have experienced some problems with the galvanized steel parts after e-coating. There are some visible and irregular texture on the surfaces and we got complaints from our customers  . When we tried to talk with our E-coat vendor to find out the root causes, they insisted that it is the plating problem. Do any of you have the expeirence and knowledge that could shed some light on this issue?
3rd February 2006, 04:46 PM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Did your e-coat supplier visit your facility? Or just talk to you and maybe evaluate some parts you sent them?
Is it a visual issue as opposed to a 'texture' you can feel?
3rd February 2006, 04:53 PM
Involved - Posts
Both visible and finger-feelable, though the parts do not have appearance requirements, just for anti-corrision, sometime i feel it is not right and necessary to e-coat after galvanizing
6th February 2006, 05:17 PM
Karma Power: 605
Any e-coat experts here? I've been through some e-coat issues but it's not my forte.
As to whether it is 'right' or not, have you done any durability or reliability testing (such as salt spray) to determine whether it is important or not?
6th February 2006, 05:25 PM
Involved - Posts
We do not have the equipment and capability to conduct salt spray test. We have to trust the vendor's test report, and the results are good ? !
6th February 2006, 05:36 PM
Karma Power: 605
I keep coming back to the appearance issue. I have seen the streaking problem. I just wasn't involved in the solution. I know we had the e-coat supplier and the equipment manufacturer in (in this case there wasn't a clear visual requirement, either, but the customer complained) and between them and the manager who over saw e-coat they solved the issue. I know they did some disassembly of parts of the line, cleaned it up, but that's about all I remember.
6th February 2006, 06:46 PM
Registration Date: Apr 2002
Thanks Given to Others: 166
Karma Power: 251
I have a little experience with e-coat, but am not an expert. My experience has been that appearance issues where typically (but not always) caused by either the condition of the underlying substrate or the thickness of the coating.
"A fool can learn from his own experiences; the wise learn from the experience of others." - Democritus, 460-370 B.C.
21st February 2006, 07:43 AM
Involved in Discussions
Registration Date: Aug 2000
Thanks Given to Others: 54
Karma Power: 41 Karma: 20
coatings
What type of coating is being applied? Don't forget that there are standards for the coating thicknesses. It also depends on how the material ordered was coated. Over the last 35 years I have seen alot of electro plated galvanized. Alot has to do with what type of coating is applied. The typical coating is zinc and when applied is very smooth. Don't forget they are applying a very small amount to each side and if done properly leaves the surface smooth. If there is an irregular texture then go back to the coater. They will know what happened. Don' forget, they have to apply coatings to standards- ASTM.
