Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
5th February 2006, 04:04 AM
Involved - Posts
Registration Date: Aug 2004
Karma Power: 39 Karma: 10
Is a t-test used in non-normal data analysis?
As Homogeneity of Varirance( Mintab) can test normal and non-normal data for variance.
My question is does t -test can do it? if not, how we can compare two non-normal data mean value? thanks
5th February 2006, 11:42 AM
Deming Disciple
Registration Date: Feb 2004
Thanks Given to Others: 150
Karma Power: 262
In Reply to Parent Post by jackylpt
Yes, the t-test is based upon an assumption of normality. If you are concerned about the normality of your data, here are some options:
1. Assume the Central Limit Theorm will get you to "good enough". Generally if you have more than 10 samples you probably are getting close.
2. Ignore the issue. With only 5 samples (for example) it is pretty hard to prove your data are not normal anyway.
3. If you know what distribtution the data are, or theoretically "ought to be", run a mathematical transform to shift them to normality. An example is time to failure data can tend to be exponential.
4. Run your own tests using random numbers and check distributions like what you have been seeing to see how good the t-test is at avoiding false alarms and avoiding failure to detects.
5. Shift to non-Parametric tests.
Steve Prevette
"A Passionate Statistician", ASQ CQE, ASQ Fellow
5th February 2006, 02:11 PM
Statistician
Registration Date: May 2005
Thanks Given to Others: 206
Karma Power: 134
Homogenity of variance tests like the t-test assume normality. If your homogenity test shows no statistical difference between the two variances, the using a t-test to compare means is conservative. If the variances are not equal, using the Sattherwaite's approximation might help.
Again, you should first test the data for normality using Wilks-Shapiro or Kolmogorov-Smirnov.
Steven Walfish
When in doubt, ask your company statistician!
10th March 2011, 01:21 PM
Involved in Discussions
Registration Date: Dec 2010
Thanks Given to Others: 6
Karma Power: 13 Karma: 40
Re: Is a t-test used in non-normal data analysis?
Statistica steven:
Why not to use Anderson test instead of Kolmogorov?
thanks
10th March 2011, 07:14 PM
Registration Date: Apr 2002
Thanks Given to Others: 557
Karma Power: 391
These tests are sensitive to departures from normality in different areas.
The Anderson-Darling is sensitive to departures from normality in the tail areas.
Wilks-Shapiro and Kolmogorov-Smirnov are sensitive to departures from normality in the center.
You should select the test that is most appropriate for your specific situation.
"A fool can learn from his own experiences; the wise learn from the experience of others." - Democritus, 460-370 B.C.
Thank You to Miner for your informative Post and/or Attachment!
11th March 2011, 10:23 AM
Statistician
Karma Power: 134
In Reply to Parent Post by Miner
Miner, excellent point!
My general rule of thumb is to stick with a single test (I tend to use W-S) to avoid the "shopping" for a good p-value. Having said that, if you know that you might have a long tail, Anderson-Darling is perferred.
Steven Walfish
11th March 2011, 10:51 AM
Registration Date: Jun 2010
Thanks Given to Others: 24
Karma Power: 23
One thing to keep in mind -if you're using a software package such as Minitab, is what normality test they use by default. You can use several specific normality tests within Minnie, but it defaults to the A-D test for the basic reports. Just FYI. Also - I believe some of the tests are sample size sensitive, so you might take a look at how much data you have as an input to which test you select.
You can use a non-parametric test like Mood's median to see if any differences exist without worrying about distribution though, but take a look at what the data is. If it's something like a hole diameter then you might expect that to be normally distributed. However, if you're evaluation cycle times or arrival times, you would look more toward a lognormal, so a t-test might not be what you choose. Make sure you have continuous or interval data, not just numbers.
Cheers,
Adam
11th March 2011, 12:55 PM
Registration Date: Jan 2003
Thanks Given to Others: 1,002
Karma Power: 324
all of the above complications and caveats are true for statistical tests that are based on the assumption of Normality.
on the other hand in the real world most processes, experiments and data are relatively straighforward. As long as the experimental structure is correct* the only necessarry analysis is to plot the raw data and look for the differences. The Tukey-Duckworth approach is typically sufficient for a statistical sanity check.
I've solved hundreds of problems and performed thousands of analyses of various types and with the exception of screenign experiments and thsoe that were looking for really small differences - I've never used - or needed a t-test or ANOV. (although I do admit that at times I will run the test after I've completed the analysis just for those individuals who 'have to see the p value' because graphs elude them) I have used ANOM on occassion but not lately. Why get all fancy when you don't have to?
*the biggest error I've seen in experimental analyses is not an incorrect statistical test, but a poorly designed experimental structure.
Statistics without physics is gambling; Physics without statistics is psychics
Thank You to Bev D for your informative Post and/or Attachment!
Forum Posting Settings
