Go Back   The Elsmar Cove Forum > Manufacturing, Service, and Business Systems Processes > Manufacturing and Related Processes
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 8th February 2006, 08:32 PM
Dr. Electron Dr. Electron is offline
Registered Visitor
Registration Date: Feb 2006
Thanks Given to Others: 7
Karma Power: 19
Dr. Electron is appreciated, and has over 100 Karma points.Dr. Electron is appreciated, and has over 100 Karma points.
Please Help! Silicone Bonding Sheeting + Static Electricity - Lightning like patterns of sticking
Good Afternoon everyone!
We've been witnessing an incredible phenomena where our silicone sheeting bonds with the polycarbonate surface it is spread onto during manufacturing in a lightning like pattern. We believe that after it is cured...a static charge is somehow baking the silicone to the poly...and is causing these crazy patterns of sticking. The static electricity would have to reach temperatures about 312 F though...and we are skeptical that is possible.
Has anyone ever experienced this kind of phenomena?
Sponsored Links
Old 8th February 2006, 10:15 PM
Marc's Avatar
Marc Marc is online now
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Default
Why are you looking at static electricity as the cause?
Sponsored Links
Old 8th February 2006, 11:07 PM
Tim Folkerts's Avatar
Tim Folkerts Tim Folkerts is offline
Registration Date: Sep 2003
Thanks Given to Others: 27
Karma Power: 123
Tim Folkerts is appreciated, and has over 1700 Karma points.
Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.
Default
I'm not an expert with plastics, but your use of the word "crazy" reminded me of a phenomemon called "crazing" which is is cracking of materials (plastics & ceramics mostly) into patterns that could resemble "lightning". Sometimes it goes all the way throuhg a material; sometimes just the surface. Typically it is caused by thermal, mechanical or chemical stress.
If the problem is just patterns in the adhesion of the materials, then crazing probably isn't related.
A quick web search found
"A major electronics equipment and computer manufacturer first encountered the polycarbonate compatibility problem with dissipative polymers. Their field service people noticed that polycarbonate-containing components were "crazed" which then cracked when used. Later, they found another crazing problem that was time related and was traced back to their static dissipative shipping and storage bags. This second polycarbonate compatibility problem became critical when a costly worldwide product recall was required to replace the crazed parts.
In general, polycarbonates can be seen as polar, rigid thermoplastics. As expected with chemistry's "like dissolves like" rule, a polar solvent or molecule with a polar end will try to dissolve into the polycarbonate surface. However, because polycarbonate is rigid, it cannot expand or swell to accommodate the solvent. It accommodates the solvent molecule by surface cracking or crazing at a stress point, which leads to further surface attack and ultimately breaks in two."
Don't know if that is at all related, but it might give an idea or two.
Tim F
Old 10th February 2006, 02:41 PM
Registered Visitor
Karma Power: 19
Default
We are able to peel all the other silicone off the carrier, but the lightning like sections appear as if they're baked in and do not peel off at all. Other than static electricity...we can't imagine anything else being able to charge the material and polycarbonate to a temperature that could cause such strong adhesion.
Thanks!
Old 10th February 2006, 02:51 PM
Registered Visitor
Karma Power: 19
Default
Originally Posted by Tim Folkerts
" Later, they found another crazing problem that was time related and was traced back to their static dissipative shipping and storage bags. In general, polycarbonates can be seen as polar, rigid thermoplastics. As expected with chemistry's "like dissolves like" rule, a polar solvent or molecule with a polar end will try to dissolve into the polycarbonate surface. However, because polycarbonate is rigid, it cannot expand or swell to accommodate the solvent. It accommodates the solvent molecule by surface cracking or crazing at a stress point, which leads to further surface attack and ultimately breaks in two."
Thank you so much for this answer. I did a lot of research on crazing yesterday and found some very interesting material. It is particularly interesting because we believe that something is done to the polycarbonate before we use it...that is further inticing this kind of behavior out of it. Thus the part with the "traced back to their static dissipative shipping and storage bags" really caught my eye. I took a look at a lot of crazing pictures and it does look similar...and is also mainly on the edges of the polycarbonate which is supposedly typical of crazing.
Of course the kicker is...the fact that it adheres so prominently to the polycarbonate when it does this...and that throws me for a loop.
Thanks again!!
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
How to calibrate patterns used in manufacturing Gowithqlty1 ISO 17025 - Calibration, Measurement Gages and Test Laboratories 6 21st April 2009 01:05 AM
Chemical Bonding vs. Human Bonding (men = metals, so women = non-metals) Tim Folkerts Funny Stuff - Jokes and Humour 1 7th November 2005 04:27 PM
Big news! Marc Smith reaches 55 - no lightning strikes! Wes Bucey General News and Business Articles 34 22nd June 2005 08:32 PM
Validation of Casting and Forging Patterns Fatboy Various Other Specifications, Standards, and related Requirements 1 16th February 2005 11:35 AM
Out of Control patterns for non-normal distributions arezoo SPC Monitoring and Statistical Analysis Techniques 1 19th June 2001 01:25 AM
The time now is 11:05 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
