Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 19011 and ALL Auditing Discussions > Process Audits and Layered Process Audits
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 9th February 2006, 03:12 PM
michu michu is offline
Registered Visitor
Registration Date: Nov 2005
Thanks Given to Others: 2
Karma Power: 17
michu has less than 100 Karma points so far.
Please Help! Questions about process audits
Hello everybody
I have a few question about process audit:
1. How often this type of audit should be performed?
2.Does the checklist should contains question related with PFMEA i Control Plan?
3.Does name "Process" audit is mandatory or can I named this audit in other way?
Thanks in advance for your help
Sponsored Links
Old 9th February 2006, 04:33 PM
tabare's Avatar
tabare tabare is offline
Involved - Posts
Karma Power: 21
tabare is appreciated, and has over 200 Karma points.tabare is appreciated, and has over 200 Karma points.tabare is appreciated, and has over 200 Karma points.
Default
michu, it would depend what you're doing process audits for. You might want to elaborate.
There are hundreds of process audit options out there.
Sponsored Links
Old 9th February 2006, 04:39 PM
AndyN's Avatar
AndyN AndyN is offline
Registration Date: Feb 2005
Thanks Given to Others: 1,784
Karma Power: 297
AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.
AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.AndyN is appreciated, and has over 1700 Karma points.
Let Me Help You What type of process audit?
Originally Posted by michu
Hello everybody
There are many types of process audit discussed here in various threads at the 'Cove'. Could you give us some more details?
Are you thinking a 'quality system' process, like Purchasing?
Is it a 'manufacturing' process, like assembly?
Is it a 'layered' process audit?
Then we can help you out. You might also like to search the Cove because this kind of question must have been asked (tens of times) before!!
Thanks, Michu
Andy
'Cause you know sometimes words have two meanings.....
Old 11th February 2006, 03:13 PM
Registered Visitor
Karma Power: 17
BIG Smile Question about process audit
It's manufacturing process audit. By the way, could you explain me in short way what's the difference beetwen manufacturing process audit and Layered process audit
Thanks for help
Regards
Michal
Old 11th February 2006, 06:03 PM
António Vieira António Vieira is offline
Involved - Posts
Registration Date: Mar 2005
Thanks Given to Others: 21
Karma Power: 35
António Vieira is appreciated, and has over 400 Karma points.António Vieira is appreciated, and has over 400 Karma points.António Vieira is appreciated, and has over 400 Karma points.António Vieira is appreciated, and has over 400 Karma points.António Vieira is appreciated, and has over 400 Karma points.
Default
Hi Michu
In my opinion, process audits can be done at least 3 or 4 times in each internal quality system audit. If you make a complete QMS audit only once a year, you can perform 4 process audits on each process of your system.
I perform this kind of audits using a check list that is completely based on the process specification. When in the specification or procedure is written one thing the check list has a question about it.
Normally I also have some general quality system questions like the employee functions and quality policy and objectives.
This check lists are always the same in each process audit. They have a scoring method that allows the quality area to check the improvement (or not) as long as audits are made to each process.
Many automakers use this scoring method of classification of their customers in 2nd party audits they perform.
One thing I’ve learned – the more process audits we make, the less nonconformances we have in QMS audits.
Quality never goes out of style!
Old 13th February 2006, 07:35 PM
Caster's Avatar
Caster Caster is offline
An Early Cover
Registration Date: Jul 2003
Thanks Given to Others: 193
Karma Power: 104
Caster is appreciated, and has over 1700 Karma points.
Default LPA is DCX
... could you explain me in short way what's the difference beetwen manufacturing process audit and Layered process audit
A layered process audit is something Chrysler came up with. Each layer of the company does a quick audit.
Foremen audit daily, supervisors weekly, plant managers monthly, and executives quarterly (for example). So each layer does an audit to be visible and demonstrate support and interest. Easy to say, hard to sustain.
LPA are a type of process audit.
Old 13th February 2006, 07:43 PM
AndyN's Avatar
Karma Power: 297
Let Me Help You Typically.......
a manufacturing process audit uses the control plan and work instructions as the audit criteria, following the process flow chart 'down stream' or 'up stream'. A Layered Process Audit (both DCX and GM/Delphi have used them) is a check by 'layers' of management to see if work instructions are being followed (mainly since DCX, the loudest proponent of LPA's) don't utilize Control Plans as their suppliers do. The focus is getting 'issues' escalated to higher management to get them resolved.
Andy
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
ISO/TS 16949 Manufacturing Audits - Check List Questions - 8.2.2.2 mattye ISO 19011 and ALL Auditing Discussions 15 19th October 2009 07:45 AM
New to performing internal audits - Looking for audit questions Charlie H Internal Auditing 5 1st May 2009 01:40 PM
How to ask probing questions during Audits..? The_TBCD ISO 19011 and ALL Auditing Discussions 34 12th March 2009 08:04 PM
Layered Process Audits vs. Internal System Audits jkittle Process Audits and Layered Process Audits 17 9th March 2007 07:43 AM
System Audits vs. Process Audits - A clear definition of the differences between each Alf Gulford Process Audits and Layered Process Audits 2 27th February 2001 04:18 PM
The time now is 04:45 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
