13th February 2006, 11:14 PM
Obsessed to Quality
Registration Date: Aug 2005
Karma Power: 18 Karma: 10
Lot Cycle Time Measurement - Statistical explanation why 95%tile
Expert,
In my industry the lot cycle time performance is measured as Cycle time at 95%tile. Is there any statistical explanation why 95%tile and not plainly maximum or average Cycle time? Thanks for your input.
13th February 2006, 11:35 PM
Courtesy Access
Registration Date: Jan 2005
Thanks Given to Others: 755
Karma Power: 612
Originally Posted by Cesar2005
Expert,
I'm not an expert, but...
Percentile rankings are used to describe statistical distributions. or more precisely, how an individual compares to the distribution. In your case, you say that cycle times at the 95th percentile are used as some sort of performance standard. What this means is that 95% of the cases are either greater than or less than that figure, depending on what you're measuring (I suspect that the 95th percentile represents a relatively long cycle time). It's possible to do something similar with control charts. What industry are you in?
13th February 2006, 11:41 PM
Obsessed to Quality
Hi Jim, Thanks for your input  . Understand why a percentile is used. What is not clear to me is why the number 95%, what becomes the basis of this number? can it be 97% or 98%? Is the selection of this number has something to do with the distribution shape (skewed as opposed to normal) etc etc. I'm into electronics industry.
14th February 2006, 10:12 AM
Courtesy Access
Karma Power: 612
Who chose the number? It can be anything less than 100, I suppose (there is no 100th percentile because that would mean that a point exists outside of the entire population from which the point was drawn). I've personally never heard of using percentile rankings to describe cycle-time goals. The shape of the distribution isn't relative, because percentile rankings assume a normal distribution.
14th February 2006, 11:55 AM
Registration Date: Sep 2003
Thanks Given to Others: 27
Karma Power: 123
I expect that 95th percentile was chosen as a conservative estimate with no particular statistical significance.
For example, suppose the average cycle time was 1.0 hr, the 95% percentile was 1.5 hr and the max was 2.1 hr. How many cycles could you complete in an 8 hr shift? On average, you could do 8 cycles. Using the 95%-tile, you could be pretty sure of completing at least 5 cycles. At the worst, you might only finish only 3 cycles.
8 cycles is a good long-term expectation.
5 cycles is a pretty good estimate of the minimum of any day.
3 cycles is a worst-case scenario.
Nothing magic about 95%; just a handy conservative estimate.
Just my $0.02
Tim F
14th February 2006, 05:01 PM
Deming Disciple
Registration Date: Feb 2004
Thanks Given to Others: 60
Karma Power: 190
A couple of guesses:
90% and 95% confidence intervals are very common by tradition. And the 95th percentile gives 5% in the tail, corresponding to a 90% two sided confidence interval. It also corresponds to two standard deviations from the average for a normal distribution.
To know what the 95th percentile is, you have to collect at least 20 points. If you are specifying the 99th percentile, you need to collect at least 100 points - and a lot more to have any confidence in the figure, assuming you are doing this non-parametrically.
At least the person knew not to promise the average (or the median).
Steve Prevette
"A Passionate Statistician", ASQ CQE, Fluor Government Group
The opinion stated above does not necessarily reflect that of my employer.
14th February 2006, 10:28 PM
Registration Date: Jan 2003
Thanks Given to Others: 265
Karma Power: 137
yes. without more info from the originator, my guess would be that the person who specified using the 95 percentile knwos a little about the Theory of Constraints. promising - or using - the average cycle time dooms you to failure...covarience comes into play and once you fall behind you can never catch up (anybody remember where Herbie is?)
However, without really knowing more details, we are only guessing
21st February 2006, 03:06 AM
Obsessed to Quality
Hi Jim, Sorry for getting you back on this one rather late. Anyway, CT Goal is expressed in days such as 5,6 or 7. But the collected data of different lots is expressed in terms of percentile. The 5% is considered maverick or out of the norm, there might be some assignable causes in these lots why they goes beyond the target CT.
