19th February 2006, 10:38 AM
Registration Date: Feb 2006
Karma Power: 16 Karma: 10
Thread Rolling on 316 Stainless Steel - What Process is Best?
Hi Folks
We are manufacturing Instrumentation Fittings in 316 Stainless Steel. We are cutting threads using lathes & turret lathes. The threads range from 1/8" to 1"NPT/BSP Taper/BSP Parallel & 10-32 UNF to 1-5/16"-20 UN. Metric sizes fom M8-1.0 to M24-1.5 are also used.
We are considering moving to thread rolling but are not able to decide between thread rolling machinery or rolling with Fette or C.J.Winter type rolling attachments on our existing Turret Lathes. The turret lathes we have at present are Herbert No.4 models.
Could anyone let us know the pros and cons of opting for thread rolling and which system to go with ?
Ashim Kumar
19th February 2006, 10:52 AM
Courtesy Access
Registration Date: Jan 2005
Thanks Given to Others: 755
Karma Power: 612
I started a new thread with this post, because it was off-topic in the thread it was originally posted in.
19th February 2006, 11:04 AM
Registration Date: Jan 2004
Thanks Given to Others: 964
Karma Power: 360
Ack! That explains why I just replied to a 2002 thread.
Stealth quality versus no quality
19th February 2006, 11:06 AM
Courtesy Access
Karma Power: 612
It doesn't make any difference how old the thread is, if you have something of interest to add. A lot of people learn from reading the old threads, and sometimes it's good to have some one bump one up with new information.
19th February 2006, 11:11 AM
Karma Power: 360
I'm leaving my post there because I agree with you. I got a Twilight Zone feeling when the thread's recent post disappeared, so it's nice to learn why that happened, and I'm not just seeing things.
19th February 2006, 10:19 PM
Involved - Posts
Registration Date: Apr 2001
Thanks Given to Others: 57
Karma Power: 95
Thread rolling options on 316 stainless
Originally Posted by relylok
Hi Folks
Ashim Kumar
In my experience thread rolling on 316 stainless is not a problem. If I remember correctly we had to slow our speed down a bit but it was still much faster and cleaner than thread chasing. We did all our thread rolling in our turret lathes (Warner Swasey No 3's and 4's) since we were generally machining the ends to size before threading.
I had no experience with rolling tapered threads and so cannot speak to that. However you should not have problems with the straight threads. Just remember that with thread rolling the process is more sensitive to changes in the dia before rolling. The rule of thumb was that each .001 inch change in blank dia woudl result in .003 change in thread height. I busted a few thread rollers in my day by letting the dia get too large.
As for the specific brands of rollers, I cannot directly speak to that. I believe we used Acme but again that was close to 20 years ago. On the whole I think you'll be very pleased with the increase thread quality as well as a reduction in cycle time.
It has been many years since I did any thread rolling so there may be newer and better answers out there.
Hope this helps
James
Low tech is better than no tech.
The only constant is those who declare, "Things around here will never change!!"
