Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
22nd February 2006, 02:01 PM
Involved - Posts
Registration Date: Oct 2004
Karma Power: 39 Karma: 161
Cpk for attribute data? Performing SPC on capacitors - Capacitance measurement
A customer has given us new requirements for performing SPC on capacitors we will be making for them. The requirements ask for us to collect data and calculate our Cpk. No big deal I think, until I read the requirements more closely. They want data collected and Cpk calculated on a capacitance measurement; I can do that. BUT, then then want data and Cpk calculated for whether the capacitors meets the voltage requirement, pass/fail. Can Cpk be calculated for this?
22nd February 2006, 02:19 PM
qualitas ad nauseam
Registration Date: Sep 2003
Thanks Given to Others: 6
Karma Power: 109
Since the Cpk calculation requires a "standard deviation", which in turn requires variable data, the answer is NO, you cannot calculate Cpk for attritbute data.
The problem is, and I see it often, is that customers do a lot of "cut-and-paste" when establishing requirements (specs) for new products. We sometimes receive specs for a new testing machine (e.g., torque or pressure decay) that specify a Cpk < 1.67. All it does is test. GR&R may apply; but Cpk does not. So, what do we do?
Bring it to the customer's attention! Questions regarding requirements should be brought up during contract review. But even if the problem is discovered afterward, explain the situation to the customer - they may very well agree with you that it was an "oops". At the very least, they should explain to you what their true intention is.
I hope this helps a little.
Rob - The sum of anecdotes is not data. -Roger Brinner
22nd February 2006, 02:37 PM
Registration Date: Jun 2002
Thanks Given to Others: 71
Karma Power: 413
In Reply to Parent Post by M Caruso
Could it be that they want it for the leakage current at the rated voltage?
Al
22nd February 2006, 02:46 PM
Thanks Given to Others: 29
Karma Power: 148
I agree with Rob - the requirement as quoted makes no sense and needs to be discussed with the customer.
To go one step further, perhaps you could suggest an improvement. For example, perhaps the cap should work up through 250 V. The pass/fail test might be to simply connect the cap to 250 V and see that it works - that would not work for a Cpk calculation. You could test many caps this way and find a percent defective and then state something like "this defect rate is equivalent to Cpk = x (assuming normally distibuted data)."
Alternatively, you might destructively test the caps by ramping up the voltage slowly until they do fail. That would give you continuous variable that could be used to calculate a Cpk value. It would be a more difficult test and be destructive, but it would produce a Cpk number (if that is truly important to the customer).
Pass/Fail voltage testing:
+ simple
- large sample size required
- gives only a "pseudo Cpk" value
Ramped voltage testing
+ smaller sample size
+ produces a true Cpk
- destructive
- more complicated test.
Just my $0.02.
Tim F
22nd February 2006, 03:24 PM
Involved - Posts
Registration Date: Jul 2005
Karma Power: 41 Karma: 135
+ simple
- destructive
Just my $0.02.
Tim F[/QUOTE]
Great suggestion Indeed!
I have had another case. One of the parts we make is automotive fuel tank support straps. The drawing calls for the spot weld strength's mean minus 3 times deviation > certain amount of Newton. The part is a safety item, and the drawing identifies the spot weld strength as a critical characteristic and we need to monitor it through SPC.
The problem is we could never get weld strength readings and its deviation, for the strap material broke before the weld did when we destruct the samples. What we got is material's tensile stength and its variation. In PPAP package we pointed it out, our customer still asked us to report the "characteristic's" Cpk. For us, the weld strength is just a pass/fail case (actually never failed). Eventually we submitted the strap's strength Cpk instead of weld stength, customer did not challenge it. So until today we keeps monitoring through 'SPC' the strap tensile strength.
Any comments?
22nd February 2006, 04:18 PM
Involved - Posts
Thank you all for your replies. I just needed to make sure that some new statistical method wasn't introduced since I finished school only 10 years ago. I was looking ahead during my schooling and decided to minor in Statistics to complement my Engineering degree. This actually was a big factor in getting my first job right out of college. Anyway.....
From reviewing the specification that was submitted with the requirements, all that is required is that SPC be maintained on major characteristics. I believe someone identified these major characteristics and boilerplated the requirements without reviewing. All requirements repeatedly call for a cert with Cpk and data.
I am going to be contacting the customer and suggest that we keep a p chart on the working voltage characteristic.
We already do 100% testing for each characteristic the customer is asking for us to track. We do it in a pass/fail manner, but some things such as capacitance can be measured and recorded, however the voltage test is strictly a pass/fail test. To change the nature of the voltage test would impact the cost to the customer significantly. Intentionally destroying units is usually done as a proof of concept or during qualification testing but not on a regular basis.
As I read the customers specification, I question why the customer did not consult us first anyway. Their specification has a paragraph that states, "Suppliers shall concur with the use of SPC as described in the individual SPC detailed requirement." Anyway, I will get this straightened out so that all will be happy here and at our customer.
22nd February 2006, 06:21 PM
Email Address Invalid or Rejected by Recipient System
Registration Date: Jul 2002
Thanks Given to Others: 15
Karma Power: 0
In Reply to Parent Post by roland_lu
Any comments?
I wish I could give you an idea but I'm just not well-versed enough in weld strength testing.
FWIW-
My comment is I think you're on a slippery slope. If a weld should fail in the field (the strap stays in one piece) and your customer comes back at you, you don't have a leg to stand on. This is a "CC" and customers get amnesia when suppliers don't have approved documentation. I know I would be very uneasy about this.
23rd February 2006, 09:44 AM
Involved - Posts
In Reply to Parent Post by Bill Ryan
FWIW-
Thank you very much for your comments.
The thing is the test method is specified by the customer, and the weld strength is better than the strap strength with no exception so far for over 1200 samples, and the strap strength is close to 2 times of the required weld strength, everybody except me feels comfortable. We can establish that the weld strength average is good, but no way we could know the its actual number and its variation with the specific test method. I am sure the weld will not fail, but I am not sure if we did it right.
I hope that somebody could give me some ideas.
Forum Posting Settings
Similar Discussion Threads
| Discussion Thread Title |
Thread Starter |
Forum |
Replies |
Last Post or Poll Vote |
Method to compute Cpk for Attribute Data?
reynald |
Capability, Accuracy and Stability - Process, Machine, etc. |
3 |
29th January 2009 06:10 PM |
Gage R&R on Attribute Data Using Minitab 14 - Data from Automated Test Systems
jatabe |
Quality Tools, Improvement and Analysis |
2 |
12th December 2007 07:01 PM |
Attribute capability indices - Cpk and/or Ppk value for an attribute type of feature
Bill Ryan - 2007 |
7 |
11th July 2005 08:53 AM |
Attribute vs. Variables Data - Variable data preferred over Attribute - Auto Industry
amanbhai |
SPC Monitoring and Statistical Analysis Techniques |
3 |
14th June 2005 12:04 AM |
SPC - Go/No Go Sampling - Attribute Data
S. Smith |
Inspection, Prints (Drawings), Testing, Sampling and Related Topics |
2 |
7th November 2000 09:47 AM |
