Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Records and Data - Quality, Legal and Other Evidence
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 23rd September 1998, 05:36 PM
HectorZuccolotto
Unregistered Guest
Posts: n/a
Default 4.16 File Index per department?
In addition to control forms in a Document Control List (4.5), does anybody can tell me if this list may also be used as the Record Control List (4.16), provided that records location is also identified?
Or every departament must have its file index arranged in accordance with their need?. By instance Purchasing files records by Supplier, Sales by Customer, Engineering by Specs, QA by Audit, CAR/PAR,etc., and Production by Mfg Order.
Thanks in advance for any input.
Héctor
Sponsored Links
Old 24th September 1998, 08:38 AM
barb butrym barb butrym is offline
Courtesy Access
Registration Date: Dec 1998
Karma Power: 63
barb butrym is appreciated, and has over 100 Karma points.barb butrym is appreciated, and has over 100 Karma points.
Default
If the MDL for forms contains the required information from 4.16, then that covers the requirement.
One downfall would be if all the forms are not "quality records" as defined by 4.16. Not every form that is used and filled out is considered a quality record. If you do as you suggest, add a notation some how/where to say which are Quality records as controlled by 4.16......either in the number or indicator. To not do that makes all the forms a record and a real pain !!!
Personally, I like to have each process owner maintain the active records then after one year(or as appropriate per process) combine in a central archive area. This matrix would be listed in a QPxx with the details required by 4.16. The process owner assigns the details.
Sponsored Links
Old 25th September 1998, 03:00 AM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Default
Yes, Hector, you can combine lists (if I understand the question). The only requiremetn is you have the appropriate columns. In fact, if you look in the pdf files directory there is a file named something like doc_mat.pdf where I did just that for a small company.
Each company should decide what they need with respect to size and the complexity of the business.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Process Audit Check List .pdf powerpoint file jrubio Process Audits and Layered Process Audits 9 20th October 2009 07:29 PM
Where are Records listed? A Master Record list? Ingeniero1 Records and Data - Quality, Legal and Other Evidence 14 2nd October 2008 04:42 PM
DCX PSO book 5th Edition - Does anyone have a typical index or check list? Rea APQP and PPAP 6 10th February 2006 10:21 AM
Seeking List of QA Department Job Functions and Responsibilities MarkJoel ISO 9001 - Quality Management Systems Standard 8 22nd October 2004 02:33 PM
The Document List and Record List contain...? Ingeniero1 Records and Data - Quality, Legal and Other Evidence 3 11th June 2004 09:15 AM
The time now is 10:43 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
