Go Back   The Elsmar Cove Forum > Manufacturing, Service, and Business Systems Processes > Manufacturing and Related Processes
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 17th March 2006, 01:42 PM
Cordon's Avatar
Cordon Cordon is offline
E-Mails Invalid or Rejected
Registration Date: Sep 2004
Karma Power: 0
Cordon is appreciated, and has over 200 Karma points.Cordon is appreciated, and has over 200 Karma points.Cordon is appreciated, and has over 200 Karma points.
Question Hot forming, what are some choices for tooling material?
This is what I have found on S7 material, "It possesses good softening resistance at high temperatures which gives it hot work capabilities."
We are looking at doing some hot forming in house and heat treating while the part is still hot. We have all the info we need on the heat treating process, just wondering if there are some other tooling materials that might be better than S7? Parts will be heated to 1550/1600F.
Sponsored Links
Old 17th March 2006, 02:26 PM
Mark Paul's Avatar
Mark Paul Mark Paul is offline
quality guy
Registration Date: Jan 2006
Thanks Given to Others: 15
Karma Power: 16
Mark Paul has less than 100 Karma points so far.
Default hot forming.
Do you mean, 1375° warm forming?
If so try Novex out of michigan.
They know this type of tooling.
Sponsored Links
Old 17th March 2006, 03:42 PM
Cordon's Avatar
Karma Power: 0
Default
The parts to be formed will be heated to 1550/1600 degrees and then formed to the desired configuration. After that the parts will be quenched to obtain the desired hardness and so on.
We will be making the tooling in house, I was just wondering if the S7 material is a good choice or maybe something similar for cheaper? As always I like to post here to get different opinions
I will check out Novex, Thanks!
Old 17th March 2006, 04:21 PM
Kevin H's Avatar
Kevin H Kevin H is offline
Quality Metallurgist
Registration Date: Jun 2004
Thanks Given to Others: 19
Karma Power: 54
Kevin H is appreciated, and has over 1100 Karma points.Kevin H is appreciated, and has over 1100 Karma points.Kevin H is appreciated, and has over 1100 Karma points.Kevin H is appreciated, and has over 1100 Karma points.Kevin H is appreciated, and has over 1100 Karma points.Kevin H is appreciated, and has over 1100 Karma points.Kevin H is appreciated, and has over 1100 Karma points.Kevin H is appreciated, and has over 1100 Karma points.Kevin H is appreciated, and has over 1100 Karma points.
Default
I beleive that most of the hot-work tool steels begin with an H designation - examples would include H-11, H-12, H-13. S is for shock resistant tool steels. What sort of forming are you planning to do and what grade of steel is involved? 1550/1600 F is on the low side for traditional hot work, and you'll lose heat to your die to begin with, so could potentially quench below austenitc just from die contact - at least at process start-up.
" We have met the enemy and he is us." Pogo
Old 21st March 2006, 10:30 AM
Cordon's Avatar
Karma Power: 0
Default
Thanks for the info on the tooling material Kevin. Sorry, I can't elaborate on the rest but you are correct in what you say, it's a fine line.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Perfect Pop Songs - Your Choices? Migre Coffee Break and Water Cooler Discussions 25 14th August 2009 11:11 AM
Supplier Development - How to buy off on tooling and material qualification mynicky APQP and PPAP 2 11th July 2008 01:36 PM
Looking for a company that does production hot forming Cordon Manufacturing and Related Processes 2 28th June 2006 03:18 PM
Tooling procedure for incoming custom built or commercial tooling and fixtures al40 ISO 17025 - Calibration, Measurement Gages and Test Laboratories 2 24th February 2006 08:12 AM
Exception in design - Tooling - In steel manufacturing, which can be tools or tooling rdesalinas Design and Development - Process and Product 1 30th September 2004 04:30 PM
The time now is 10:59 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
