20th February 2006, 12:55 PM
Registration Date: Feb 2005
Thanks Given to Others: 1,784
Karma Power: 297
AIAG Guide - CQI-8 on LPA's (Layered Process Audits)
Has anyone seen this guideline on Layered Process Audits?
I am interested in the comments made in the 'Foreword' and then (again) in the 'Background' and 'Summary', which state (in part);
"Industry data show that most manufacturing quality issues are caused by poor process control - often a failure.....to follow the required process steps".
and..........
"Employees typically do not refer to instructions or procedures before every step of a process; they often complete the process by memory....."
Does anyone know of the sources of "industry data" cited in this document? Does anyone have any comments regarding "operators not following their instructions" as a reason for quality issues.........compared, perhaps to Demings' musings........?
Andy
'Cause you know sometimes words have two meanings.....
20th February 2006, 09:06 PM
An Early Cover
Registration Date: Jul 2003
Thanks Given to Others: 193
Karma Power: 104 Karma: 3066
Where I work
and..........
Andy
Hi Andy
Here where I work, "operators not following their instructions" is an all too common reason for quality spills - with one caveat.
I would change it to read "operators not following their approved instructions".
"Someone" has "told them" to make a change from the formal method and has not taken the time to revise and retrain all the people.
That "someone" is never the operator...it is always a member of Demings beloved management.
So I think the failure is one of management to provide correct and current methods and educate all employees.
I can see LPA very easily being used to blame operators - Deming would not support this.
But a decent root cause done around why did they not follow procedures would soon reveal a system problem - possibly Deming would support this?
I guess it depends on the use made of the tool - and the bias of the tool user.
As a rough estimate, 80% of our spills are due to someone doing other than what is written down. When shown the document with the correct method (and their training record), we often get well "they" told me to.
I believe them....not their fault...you gotta do what your boss tells you to do...even when you know it is wrong. Shuttle o-rings is a sad case.
20th February 2006, 11:06 PM
Karma Power: 297
I'm not sure that LPA's will be used........
as a punitive tool (or result in such).
However, will they reveal that, in most cases, the reason for folks not following the work instructions results from some other process(es) not functioning effectively - like APQP??? (if you're an automotive supplier, who will have to do LPA). Or will they just be pencil whipped by the "auditors" (despite the guidance emploring us not to)??
What OEM actually involves their operators/associates in the development of PFMEA's/Control Plans/Work instructions? Since when did the new products teams ever utilize the vast, experience and resources available to them to ensure the process is well documented (as in something that operators can actually do.......
In the past I have seen station on a machining line (one that would be a candidate for LPA) and found that the associate had to gauge at least 15 features on one side of a component then 'leap' to the other side of the conveyor to gauge more, since the part couldn't be turned. And all in a very short cycle time!  How could the operator 'follow instructions'?? I don't remember 'gymnastics' being on their competencies
An LPA would find this and fix it, obviously.
But what part of the LPA would address this to the Launch Team or Process Engineering or the fact that the machining process was incapable, caused broken taps/drills because the run rate compromised quality for quantity.................????? Which manager is going to bring back that little snippet of info to 'Management Review' and understand where the business process that designed and then launched an incapable process?
Caster, thanks - we're on the same page.
Anyone got a different experience?
Andy
29th March 2006, 07:12 AM
Shy Poster (1 to 5 Posts)
Registration Date: Aug 2004
Karma Power: 22 Karma: 10
Layered Process Audit Guidelines - The AIAG's CQI-8
I was tasked to implement Layered process audits. Does anyone have guidelines on this please.
29th March 2006, 09:17 AM
Dogs rule
Registration Date: Jul 2002
Thanks Given to Others: 15
Karma Power: 69
I don't know that there published guidelines (except possibly with Delphi) but we go with:
* Operator - hourly checks of the process parameters
* Cell Technician - checks by shift
* Value Stream Mgr. - checks by week
* Plant Mgr. - checks by month
Each position has differing checklists to go by. We haven't had any issues with a customer (yet!).
Hope that helps some.
There is no psychiatrist in the world like a puppy licking your face. - Ben Williams
29th March 2006, 09:30 AM
Karma Power: 297
AIAG document is available.......
and I have a copy. I'm not certain if (due to the normal concerns) I should post it here, but there is one available. It's a combined effort from GM/DCX.
Andy
29th March 2006, 10:09 AM
Involved - Posts
Registration Date: Jan 2004
Thanks Given to Others: 5
Karma Power: 36
You can download the guidelines for Layered Process Audits from the AIAG website. The document number is CQI-8.
Have a nice day, unless you've made other plans.
Ann Morgan cleverly disguised as "Quality PhD"
29th March 2006, 11:32 AM
Forum Administrator
Registration Date: Jul 1997
Thanks Given to Others: 100
Karma Power: 195
As far as I understand the document is a free to download only to members of AIAG everyone else needs to buy it.
If you search for layered audits or LPA you will find a lot of discussion and files.
Here are some to start with
What is a Layered Process Audit?
What is a 'layered audit'? Layered Process Audit (LPA) - A GM requirement?
You can’t fake quality any more than you can fake a good meal.
* William S. Burroughs
