Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Documentation Control Systems, Procedures, Forms and Templates
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 30th October 1999, 08:07 AM
JParrish
Unregistered Guest
Posts: n/a
Question Controlling Level 4 Documents
We have yet to gain control of all the forms that are used in our facility. I beleive this is something that needs to be done, but not sure how to get started. Our facility is around 600 - 700 people, and the amount of forms used could be very extensive. I am also not sure how to determine if that form directly affects quality. Where do you draw the line? Any ideas on how to control these forms and when to control them!
Sponsored Links
Old 1st November 1999, 12:33 PM
David Guffey
Unregistered Guest
Posts: n/a
In my experience, you definitely need to control the revision level of the FORM itself. If it's a form to be completed into a quality record, the quality record then needs to be controlled per 4.16.
The problem with controlling the blank form is that there may be so many copies out in the world available for use. If a form is revised, all those copies need to be rounded up, destroyed, and replaced. Using this method, we usually miss a few that are stashed away in somebody's desk.
To get around that most of the time, try to change forms so that previous editions could be used if necessary. Then, make sure your release documentation clearly states "previous revision may be used until depleted" or something similar. If the change is such that the world will fall apart if the old form is used, an extra effort must be undertaken to search for and find the newly obsoleted forms. You have to figure out how to do that within your own system.
One thing I doubt you want to do is get to the point of "issuing" forms. Avoid that at all costs if you can.
Sponsored Links
Old 1st November 1999, 02:02 PM
Laura M's Avatar
Laura M Laura M is offline
Courtesy Access
Registration Date: Aug 1999
Thanks Given to Others: 3
Karma Power: 70
Laura M is appreciated, and has over 500 Karma points.Laura M is appreciated, and has over 500 Karma points.Laura M is appreciated, and has over 500 Karma points.Laura M is appreciated, and has over 500 Karma points.Laura M is appreciated, and has over 500 Karma points.Laura M is appreciated, and has over 500 Karma points.
Send a message via AIM to Laura M Send a message via Skype™ to Laura M
I Say...
This is a tough one. A couple of thoughts come to mind.
Don't get too analytical about which ones affect quality and which ones don't. Personnel or accounting forms may not affect product quality, but there is valid reasons to control them. It's easier to control "all" forms than make a decision. Once people know "all" forms are controlled, then they get used to whatever system you put in place.
The previous suggested about "valid until depleted" only brings to mind how many revisions back? If you pull one out of you desk that is "valid until depleted" it can be a couple versions old, not just one, so be careful.
As a possible suggestion - we established "document control areas" -(file cabinets) that were out in manufacturing areas as well as office areas. Each dept. was given the flexability of determining how to manage them - how many to have etc. Copies of blank forms were kept in these files and it was the resp. of the person who updated the form (authorized personnel who reviewed and approved) to purge the folder. Users of the forms were trained NOT to make their own copies - we used a RED "QS9000" in the corner of controlled copies - and no color copiers were available.
Some departments actually kept only 30 days worth of forms and knew on the 1st of the month the file should be empty - and they replenished it (daily use forms). In most cases the files are closer than the nearest copier, so eventually the system took hold and worked. Another method of control was to only revise on the 1st of the month if possible, and copy the 1st month's worth in a differenct color as a visual indicator. FYI -if your're thinking - were too big, too dirty etc - this was implemented in a 3200 person facility with Die cast, machining, plastic injection molding, heat treating etc.
Not sure if this helps or not...
All manual systems take training and time. People invent their own systems when the system in place doesn't work for them. Get the users of the forms involved - make sure they understand the requirements, and let them come up with what will work. Make the forms easily accessible and controlled, and they will have less reason to work around it.
Old 1st November 1999, 02:06 PM
Kevin Mader's Avatar
Kevin Mader Kevin Mader is offline
One of THE Original Covers!
Registration Date: Nov 1998
Thanks Given to Others: 22
Karma Power: 94
Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.
Send a message via AIM to Kevin Mader
JP,
You may find this useful.
You are setting out to purge the system of useless documents. While a huge task, once clean, keeping it clean may even be larger. Either way, it is nice to clear the slate.
What level 3 documents need to be controlled? As stated earlier, any form that becomes a Quality Record needs to be controlled. So what other documents?
Well, any document referenced in the QM or in Level 2 documents, these should be controlled. For other documents you collect, they need to be put to the test you mentioned; what effect do they have on the system? You may want to use a Risk Analysis tool (maybe create your own), such as an FMEA, to determine the level of risk involved. Low risk, low chance that it needs to be controlled. However, this is not a fast rule. Developing an RPN uses three criteria, Severity, Occurrence, and Detection. For Risk Analysis on Forms, I believe you need to pay particular attention to the Severity and Occurrence factors. Severity deals with direct impact of the failure. The higher, the more consideration should be given. The same is true of Occurrence. Many small failures add up to a big failure in the eyes of auditors. For this reason, even if the Severity rates low, a large Occurrence would drive me towards controlling the document.
I think you will find that many forms in your system are more in tune with working documents. This should make your document control more simplified. However, it is a good idea to make sure your internal auditors routinely challenge the form classification, in either direction.
I hope this helps. Any other ideas out there?
Regards,
Kevin
Old 1st November 1999, 06:34 PM
barb butrym barb butrym is offline
Courtesy Access
Registration Date: Dec 1998
Karma Power: 63
barb butrym is appreciated, and has over 100 Karma points.barb butrym is appreciated, and has over 100 Karma points.
The Hat
watch yourself...don't make a mountain out of a mole hill...is the form just used to collect data for electronic entry? don't control it..... Is it used to track efficiency just within the area? don't control it..... Local control by a supervisor can be controlled easily within the area, and not bog down the doc system..keep it simple guys....some people get carried away
Old 2nd November 1999, 10:00 AM
Sam's Avatar
Sam Sam is offline
Registration Date: Sep 1999
Thanks Given to Others: 1
Karma Power: 90
Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.
I have experimented with control of forms and documents, on a small scale, at the point of use,i.e., manager,supervisor,team (cell). Each person/team would have a master list of their forms/documents, also a copy is given to the document control clerk. When changes are made the DCC reviews the master list and distributes copies as required.
This process was surprisingly effective, however I haven't implemented plant wide as of yet.
Old 2nd November 1999, 11:07 AM
Laura M's Avatar
Courtesy Access
Karma Power: 70
It was amazing to me the extent people went through to keep there own "stash" of forms before we implemented the above system. Once they knew they can get their hands on what they needed, they spent the time doing their job instead of at the copier. Work benches, desks got cleaner in line with our work-place organization efforts that coincided.
While I agree with "don't make a mountain out of a mole hill" build system that can be recognized from one dept to the next. At least where I was, when employees moved from dept to dept - they knew what to look for. The majority of the forms were tied to a PCP reference. Rather than have a "master list" we had a document matrix (by department) that listed the forms and where the master was kept. The master was then the reference "or equivlent" to the master list, and you didn't have to update the list when you update the master. Level 1,2 & 3 documents used the master list.
Old 2nd November 1999, 11:12 AM
Laura M's Avatar
Courtesy Access
Karma Power: 70
re Barb ..."is it used to track efficiency in the area... don't control it"
Not sure I agree here. Is that because efficiency isn't a "quality goal"? QS requires a business plan. Most business plans have efficiency goals. Could efficiency be an indicator for a quality goal....100% on-time delivery for example. It would seem that that's where you get involved in the "is it or isn't it" conversation in the original question.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
HACCP in Egg Production - Controlling hazards at the farm level chipollinij ISO 22000, HACCP (21 CFR 120) and Food Safety 4 4th November 2009 04:54 AM
Identifying and Controlling External Documents Sardokar Documentation Control Systems, Procedures, Forms and Templates 8 6th August 2008 05:30 AM
Controlling 'Uncontrolled' Documents sent to us by Customers Jim Biz Documentation Control Systems, Procedures, Forms and Templates 7 1st October 2001 01:27 PM
Controlling Documents of External Origin Marc Documentation Control Systems, Procedures, Forms and Templates 3 1st October 2001 10:45 AM
Tier 2 & Tier 3 Documents Numbering scheme (Level 2 and Level 3) documents energy Documentation Control Systems, Procedures, Forms and Templates 26 26th June 2001 04:28 PM
The time now is 08:00 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
