Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Documentation Control Systems, Procedures, Forms and Templates
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 21st November 1999, 07:32 AM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Covering Ass Hard Copies from Electronic Media
I particularly liked this 'rant':
-----snippo-----
Subject: Re: Use of "electronic" doc /../Hankwitz/Summerfield/Pfrang
Date: Fri, 5 Nov 1999 14:48:38 -0600
>From: George Summerfield <gsummerf@dciem.dnd.ca>
>Gary:
>If your master copy of the document resides on a LAN system, but someone
>needs to print it to take to their workstation, then you have a document
>control problem that must be addressed. On the other hand, you can have it
>stipulated that ANY printed material in your work area is automatically
>considered an 'uncontrolled' document; but that just isn't practical in
>most applications.
I completely disagree that printing a paper copy of an electronic original document automatically creates a "document control problem."
I can prove this by reciting each of the Standard's document control requirements and demonstrating how a printed paper copy meets every requirement:
1. Section 4.5.2 requires: "The documents...shall be reviewed and approved for adequacy by authorized personnel prior to use."
My response: As long as the electronic master is reviewed and approved for adequacy by authorized personnel prior to use, then a printed paper copy of that master is a perfectly valid document. The Standard does not require the paper copies to receive a separate review and approval; however, if you want to cover this possibility, then simply designate the people who make paper copies as "authorized personnel" and have them "review and approve" the paper copy (i.e., confirm that it matches the electronic master) prior to use.
2. Section 4.5.2 also requires: "A master list...identifying the current revision status of documents shall be established and be readily available...."
My response: This language is about the master list, not about the control of the document, so it is not relevant to this proof.
3. Section 4.5.2(a) requires the control procedures to ensure that appropriate documents are available where they are needed.
My response: Paper copies actually help ensure that appropriate documents are available where needed.
4. Section 4.5.2(b) requires the control procedures to ensure that invalid and/or obsolete documents are removed or otherwise not incorrectly used.
My response: Paper copies whose revision level matches the revision level of the electronic master are valid.
5. Section 4.5.2(c) requires that obsolete documents are suitably identified.
My response: Paper copies whose revision level does not match the revision level of the electronic master can easily be identified as obsolete.
6. Section 4.5.3 requires that "Changes...shall be reviewed and approved by the same functions/organizations that performed the original review and approval...."
My response: See my response in number 1 above. As long as the same methods are used to review and approve document changes, this requirement will be satisfied.
Now, I challenge you to cite the specific requirement of the Standard that is violated by printing a paper copy of an electronic original document.
I am sorry if I seem contentious, but I have seen far too many people wrongly assert that something is an ISO violation because they never cite any specific requirement of the Standard that is violated.
>Another way to acquire a document control problem with electronic media is
>to advertise that everything is available for viewing on a web page. But,
>the web master may not be the writer (process owner) of each document.
>John Doe, who has access to his documentation, pulls down his document and
>revises it, then sends you (web master) a copy of the revised edition to
>post to the web page. Unfortunately, you're up to your eyeballs in other
>IT problems and the revision is not posted for a couple of weeks. His
>people are no longer using the proper document, and this could have serious
>repercussions; dependant upon how important that process/procedure document is.
>In short, you have to address how you maintain document control; just like
>it stipulates is 4.5 of the compendium. Whether the document is hard
>(paper) or soft (electronic), it must be controlled. Controlling the
>master copy alone is easy. Most companies have big problems controlling
>the numerous copies of that master copy. Can you decide not to address
>that; no!
>George
Frankly, I don't know of any company that has "big problems" controlling the numerous copies of their master documents. They simply put a version number (or a date, which can be equivalent to a version number) on each document, and then as long as the person using the document checks to make sure he or she is using the correct version, there is no problem. Again, like I said above, I challenge you to cite the specific language from the Standard that is violated.
-- Doug
Sponsored Links
Old 21st November 1999, 11:06 AM
barb butrym barb butrym is offline
Courtesy Access
Registration Date: Dec 1998
Karma Power: 63
barb butrym is appreciated, and has over 100 Karma points.barb butrym is appreciated, and has over 100 Karma points.
its simply a matter of discipline and ones own document control procedure. and what is and is not allowed....typically the way it happens is someone is caught using an out dated revision to work on product, then its an issue.
Probably, whoever offered the scenario, left out the details (as so many of us tend to do?)....and its not an ISO issue, but a potential for one ....therefore the generalized statement may have been taken out of context.... It does leave you wide open/vulnerable...and it does lead an auditor to the "what happens if...questions" So as a consultant many try to eliminate the potential problematic scenarios. Then in reverse as a consultant turned auditor, many cannot completely remove the hat, and force their views into the standard. The answer lies in the evidence....was there any evidence to show lack of control or non-adherence to procedure?
Sponsored Links
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Hard copies from 10-20 years ago - Document Control and Retention Times question vinqua Documentation Control Systems, Procedures, Forms and Templates 19 7th May 2008 07:32 AM
Controlled Copies of a Quality Manual in an electronic media (file/server) Bob the QE ISO 10013 - Quality Management System (QMS) Manuals 9 3rd April 2008 12:50 PM
Do you still collect hard copies of objective evidence when auditing? chergh ISO 19011 and ALL Auditing Discussions 20 28th June 2005 01:21 PM
Are Hard copies necessary? kaliweb Documentation Control Systems, Procedures, Forms and Templates 4 20th June 2001 04:28 PM
Control of electronic media documents Violetta Monroe Documentation Control Systems, Procedures, Forms and Templates 5 23rd November 1998 05:25 PM
The time now is 05:21 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
