The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Inspection, Prints (Drawings), Testing, Sampling and Related Topics
Forum Username
Search the Elsmar Cove
Custom Search
Monitor the Elsmar Forum
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page  Elsmar Cove Twitter Feed
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Sponsor Links
Courtesy Quick Links
Howard's
Marcelo Antunes'
SQR Consulting
Bob Doering's
Quality Digest Portal
Reply
Old 11th April 2006, 09:42 AM
ScottK's Avatar
ScottK ScottK is online now
Not out of the crisis
Registration Date: Apr 2006
Thanks Given to Others: 173
Karma Power: 292
ScottK is appreciated, and has over 1700 Karma points.
ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.ScottK is appreciated, and has over 1700 Karma points.
Question Automating variable inspection - Calipers, micrometers, and optical comparators
He everyone. I guess this is my first "Real" post.
anyway - I'm looking for a faster way to measure outside dimensions (and even some inside dimensions if possible) on a threaded part. We make valves - relief valves, check valves, etc and this would be used post machining to check component parts, as opposed to assembled valves.
Currently we use calipers, micrometers, and optical comparators to measure diameters, thread pitch, length, etc.
I would like to automate this in order to speed the first article and in-process inspections.
I was wondering if any of you might have a recommendation.
I've used OGP's Smartscope in the past for extrusion profiles, but this is a pretty complex device and would take a lot of training if I would want machien operators to do their own inspection some day.
Thanks!
Sponsored Links
Old 12th April 2006, 05:16 PM
Paul F. Jackson Paul F. Jackson is offline
Involved - Posts
Registration Date: Feb 2001
Thanks Given to Others: 2
Karma Power: 71
Paul F. Jackson is appreciated, and has over 700 Karma points.Paul F. Jackson is appreciated, and has over 700 Karma points.Paul F. Jackson is appreciated, and has over 700 Karma points.Paul F. Jackson is appreciated, and has over 700 Karma points.Paul F. Jackson is appreciated, and has over 700 Karma points.Paul F. Jackson is appreciated, and has over 700 Karma points.Paul F. Jackson is appreciated, and has over 700 Karma points.
Use a laser micrometer.
Search laser the internet for "laser micrometer"
Caution
1) surfaces must be clean
2) centerless ground valves must free of odd lobbing otherwise the measurements will not reflect the true OD.
3) measurements should be made at a slight angle relative to the grinding lay or else the the resolution will vary due to the surface finish.
Paul
Sponsored Links
Old 13th April 2006, 09:50 AM
ScottK's Avatar
Karma Power: 292
In Reply to Parent Post by Paul F. Jackson
Caution
Paul
thank you. I will look into it!
Old 13th April 2006, 11:23 AM
David Hartman's Avatar
David Hartman David Hartman is offline
Involved in Discussions
Registration Date: Feb 2003
Thanks Given to Others: 3
Karma Power: 105
David Hartman is appreciated, and has over 1500 Karma points.David Hartman is appreciated, and has over 1500 Karma points.David Hartman is appreciated, and has over 1500 Karma points.David Hartman is appreciated, and has over 1500 Karma points.David Hartman is appreciated, and has over 1500 Karma points.David Hartman is appreciated, and has over 1500 Karma points.David Hartman is appreciated, and has over 1500 Karma points.David Hartman is appreciated, and has over 1500 Karma points.David Hartman is appreciated, and has over 1500 Karma points.David Hartman is appreciated, and has over 1500 Karma points.David Hartman is appreciated, and has over 1500 Karma points.
You might want to look into a portable articulating arm CMM (such as those offered by Romer or Faro Technologies). These can be equipped with laser-based visual measurement devices, and are relatively economical (extremely in-expensive for a CMM).
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Can I calibrate Optical Comparators internally? Bob Gallinger - 2007 ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories 21 12th October 2012 10:24 AM
Gage Repair Shops near Pheonix, AZ - Variable Gages - Micrometers, Calipers, etc. erbearica Calibration and Metrology Software and Hardware 3 19th June 2011 09:35 AM
Is there a standard that I should use to Calibrate Calipers and Micrometers? fletch ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories 8 28th March 2008 03:00 PM
Precision tool storage such as micrometers and calipers? Lundberg ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories 5 24th September 2007 06:15 PM
Gage R&R Required on Micrometers and Calipers? dbulak Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5 30th January 2002 09:24 PM
The time now is 10:21 AM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, Olde West Chester, Ohio 45069-1929
513 341-6272
