Go Back   The Elsmar Cove Forum > Manufacturing, Service, and Business Systems Processes > Lean - Lean in Manufacturing and Services
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 18th April 2006, 05:51 AM
johnnybegood johnnybegood is offline
Involved - Posts
Registration Date: Jun 2001
Karma Power: 37
johnnybegood has less than 100 Karma points so far.
Question Siemens pick and place machine for chip placement - Utilization - Splicing
We are using Siemens pick and place machine for chip placement. Our goal is to continuous production during component replenishment. In Siemens machine, the feeders that can be removed, reloaded, and placed back on the machine while the machine is running (without missing a beat). We have 4 Siemens machine and there may be more than 50 feeders. How can the operator will be visually notified when the reel falls below a set level?
Right now the operator is always on look out walking from one machine to the next and sometime she has to take out the reel and check.
Sponsored Links
Old 18th April 2006, 12:13 PM
Steve Prevette's Avatar
Steve Prevette Steve Prevette is offline
Deming Disciple
Registration Date: Feb 2004
Thanks Given to Others: 60
Karma Power: 190
Steve Prevette is appreciated, and has over 1700 Karma points.Steve Prevette is appreciated, and has over 1700 Karma points.
Steve Prevette is appreciated, and has over 1700 Karma points.Steve Prevette is appreciated, and has over 1700 Karma points.Steve Prevette is appreciated, and has over 1700 Karma points.Steve Prevette is appreciated, and has over 1700 Karma points.Steve Prevette is appreciated, and has over 1700 Karma points.Steve Prevette is appreciated, and has over 1700 Karma points.Steve Prevette is appreciated, and has over 1700 Karma points.
Default
I don't know the physical setup you have, but certainly a common tool used is status lights above each reel (or supply bin). You'd need some sort of remote sensor of the level on the reel, but then it could trip a yellow light at a warning level, and a red light when attention is needed. On a lot of assembly lines I've seen these lights are on a pole just above the machine.
Steve Prevette
"A Passionate Statistician", ASQ CQE, Fluor Government Group
The opinion stated above does not necessarily reflect that of my employer.
Sponsored Links
Old 19th April 2006, 08:39 AM
M Greenaway's Avatar
M Greenaway M Greenaway is offline
Courtesy Access
Registration Date: Dec 2001
Thanks Given to Others: 10
Karma Power: 80
M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.
Default
If you know how many items are on a reel, how many of these items go onto an assembly, and how many assemblies you have made you should be able to calculate when a reel needs changing (allowing a little tolerance for the odd hiccup).
This could be plummed into some simple software.
Old 25th April 2006, 06:40 PM
Involved - Posts
Karma Power: 37
Default
Perhaps I have post the question wrongly as I think my biggest challenge to this problem is that the opeartor fail to scan the reel. We have the software to count the the component usage. It will auto request from the store when the level of component reach a certain predetermine limit. However this doesnt work if the operator does not scan the reel. When there is no data input the machine will not know how much been use and thus will not 'request'for replenishment. Question is how to fool-proof the scaning of the reel each time the operator replenish the reel?
Old 26th April 2006, 10:12 AM
D.Scott's Avatar
D.Scott D.Scott is offline
Registration Date: Feb 2001
Thanks Given to Others: 80
Karma Power: 149
D.Scott is appreciated, and has over 1700 Karma points.
D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.D.Scott is appreciated, and has over 1700 Karma points.
Send a message via Yahoo to D.Scott
Default
I think the answer Steve gave will fit your problem exactly. We use a similar system in our Pick-and-Place processes.
Take a moment to re-read Steve's answer and see if you can picture that in your process. I am sure he would be glad to clarify any additional questions about his solution.
Good luck.
Dave
"Time you enjoyed wasting is not wasted time"
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Closed or Resolved: Preventive Action for The Cove - 'Post' Button Placement Sidney Vianna Forum Suggestions, Complaints, Problems and Bug Reports 24 27th September 2008 07:30 AM
Machine Tool Calibration - Machine Capability Studies on CNC Machine Tools mlthompson Manufacturing and Related Processes 5 17th May 2008 04:34 PM
Capacity Utilization - How to do a capacity utilization project Andy_80 Six Sigma 2 4th June 2007 06:24 PM
Opinions about or Recommendations of Placement Agencies - Seeking USA employment Fandango Occupation Discussions 3 21st October 2005 11:16 AM
TS 16949 Certification date requirement of suppliers by Bosch, Delphi & Siemens Quality-1 ISO/TS 16949 - International Automotive Quality Systems Standard 6 7th April 2005 01:37 PM
The time now is 04:02 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
