Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Documentation Control Systems, Procedures, Forms and Templates
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 28th March 2000, 09:29 AM
chuy sanchez
Unregistered Guest
Posts: n/a
Question documentation question ?
help!!!!
in my company , each departament wants to make their ouw job instruction, you can tell me is correct but also want a make a diferent FORMAT FOR EACH DEPARTAMENT. !!!!
how can handle ??
it is possible ????
help me.......
Sponsored Links
Old 28th March 2000, 11:20 AM
gmac
Unregistered Guest
Posts: n/a
Thumbs up
Similar situation here, but shows interest by all departments, solution was to issue the procedure template and ask them to complete the relevant section, this in a lot of cases was as simple as a flow chart, these were then collated through the Q.A. dept who standardised cross-references , numbering systems etc.
Sponsored Links
Old 28th March 2000, 04:23 PM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Yin Yang
My question is are you talking about level 2 procedures or actual job / work instructions?
Typically you want a consistent format but lets make sure you're talking about the same type of document in each department.
Old 28th March 2000, 11:11 PM
David Mullins's Avatar
David Mullins David Mullins is offline
Aussie Bloke
Registration Date: Nov 1999
Karma Power: 51
David Mullins has less than 100 Karma points so far.
Yin Yang
You want people (internal and external) to recognise that a document is part of the management system. If each department's work instructions look different (in terms of format) then you lose the cognisability of the documents.
It IS good that they are writing them, as it gives them ownership. Just try to convince them that it suits the greater need to adopt the common format, that way improtant details won't go missing.
Old 3rd April 2000, 06:13 PM
Tom Parsons
Unregistered Guest
Posts: n/a
Look!
We found this to be a real balancing act. The compromise was to require that all departments use a common cover page (containing requirements for approvals, unique numbering, etc.), produce a separate work instruction on how they exercise control of their WIs and include a couple of small sections in each WI explaining the purpose and scope of the document. Beyond that, they're free to write them however they see fit. By doing this, each department has the freedom to construct the WI in the way most useful for themselves, while the initial feel and look of all WIs has some consistency.
I write this as if it's a done deal. Actually, we're still in the middle of implentation and finding some resistence, but we're trying to stand firm.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Re-certification Audit with new department in which procedures are not finalized jeanmarc ISO 9001 - Quality Management Systems Standard 2 15th January 2008 08:19 AM
Same format for WI (Work Instruction) and Procedures? tvillan ISO 9001 - Quality Management Systems Standard 23 8th July 2007 05:28 PM
Work Instructions - Format and Various WIs per Department noboost4you Documentation Control Systems, Procedures, Forms and Templates 29 16th February 2007 12:24 PM
What is Your Favorite Format for Systems and Procedures? TownDawg Documentation Control Systems, Procedures, Forms and Templates 11 22nd February 2004 08:31 PM
The time now is 08:02 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
