19th April 2000, 08:26 PM
What is a controlled document?
Question - what types of documents need to be controlled?
Our QM says that all documents used in manufacturing areas need to be controlled, I disagree.
I cannot see why locally prodcued documents e.g. data collection forms used by improvement teams ; process set-up time / cycle time monitoring forms.
I can't find any reference within QS9000 to these types of documents requiring issue control ; I can do without yet more documents to be responsible for!
19th April 2000, 08:43 PM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,892
Karma Power: 604
Q Manual
Level II's
Control plans, FMEAs and other process related documents, for starters. Documents of external origin can be tricky.
There is no requirement for centralized control. Local control is perfectly acceptable.
20th April 2000, 01:50 PM
Courtesy Access
Registration Date: Dec 1998
Karma Power: 63 Karma: 151
I like the rule ,...ok, so if the information in this is wrong or inconsistent...what gets affected...and is that critical? if it matters then it needs some sort of control....The level is dependant on criticality and origin.
26th April 2000, 03:28 AM
Aussie Bloke
Registration Date: Nov 1999
Karma Power: 51 Karma: 84
I ask "do current or new people need to refer to this information to do the job correctly (quality/cost/time)?"
If the answer is YES, because people don't have the required skills or knowledge, the you need a controlled document.
If the answer is NO, and people (including new starters) have the skills and knowledge, then no document is required.
BEWARE, if the answer is NO, and people don't have the skills and knowledge, as well as a standardized methodology, then they do need a controlled document, and they are either fooling themselves, attempting to fool you, or both!
Similar Discussion Threads
| Discussion Thread Title |
Thread Starter |
Forum |
Replies |
Last Post or Poll Vote |
Examples of DCR (Document Change Record) Log and Document Controlled Log
Mark M. Sweeny |
Documentation Control Systems, Procedures, Forms and Templates |
3 |
6th May 2009 07:26 PM |
Controlled Document Definition - What constitutes a controlled document?
shereenk |
Definitions, Acronyms, Abbreviations and Interpretations |
9 |
29th April 2009 04:28 AM |
What is the difference between a controlled document and an uncontrolled document?
johnkwt |
10 |
7th February 2007 12:12 PM |
What Is A Controlled Document?
George Trybulski |
12 |
19th April 2001 01:59 PM |
Controlled Documents - How many copies can be stamped "Controlled Document"?
roadrunner5_2000 |
11 |
27th April 2000 05:54 PM |
