Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Quality Tools, Improvement and Analysis > Quality Assurance and Compliance Software Tools / Solutions > Excel .xls Spreadsheet Templates and Tools
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 1st May 2006, 04:22 PM
Jennifer Kirley's Avatar
Jennifer Kirley Jennifer Kirley is offline
Registration Date: Jan 2004
Thanks Given to Others: 964
Karma Power: 360
Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.
Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.
Please Help! Formatting an Excel .xls spreadsheet to alarm out-of-calibration status
Suppose a program has spreadsheet worksheets with their lists of gages, their cal due dates and other calibration-relevant data and the supervisors are responsible to know when their worksheet's gages are coming due. The practice of browsing a list of gages to find an out-of-calibration date could be improved upon, I think.
For example, I have seen cells that turn red under certain parameters (some kind of logic function) and I think it's cool but I haven't figured out how to do that. Can anyone tell me how it's done?
I have had trouble with logic functions using dates. Other than Julian date (which would work) can a cell be so formatted to show a message "Danger Will Robinson!" (okay, I'm kidding about the message) based on a past-due date?
Thanks in advance!
Stealth quality versus no quality
Sponsored Links
Old 1st May 2006, 04:28 PM
Al Rosen's Avatar
Al Rosen Al Rosen is offline
Registration Date: Jun 2002
Thanks Given to Others: 48
Karma Power: 192
Al Rosen is appreciated, and has over 1700 Karma points.
Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.
Send a message via AIM to Al Rosen
Default
Thanks in advance!
Look up "conditional formatting" in Excel Help. It will explain it
Al
Sponsored Links
Old 1st May 2006, 04:54 PM
Tim Folkerts's Avatar
Tim Folkerts Tim Folkerts is offline
Registration Date: Sep 2003
Thanks Given to Others: 27
Karma Power: 123
Tim Folkerts is appreciated, and has over 1700 Karma points.
Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.
Default
Jennifer,
Use the "Conditional Formatting" option on the "Format" Menu.
The simplest method is to compare the cell value to a specific number. For instance, you could apply a format when ever a number is less than zero, or when it is between -3 and +3.
The next option is to campare to another cell. For example, you could calculate the upper control limit and then compare a series of cells to that cell.
The final option (I I just recently discovered) is to create a formula as a condition. When the conditional formatting box is open, look at the left most drop-down menu and choose "Formula Is". For example, if you select a range (starting at cell B4) and type the formula
=B4<TODAY()-30
it will test if something is 30 days past due. If you add a second condition like
=B4<TODAY()+7
it can test if it is coming due in the next week.
After you set the condition, you can have the cell color change by selecting "Format", the "Borders". Perhaps a month over due is red, slightly overdue is orange, and due in the next week is yellow.
I could attach a simple example if it would help...
Tim F
Old 1st May 2006, 05:00 PM
Karma Power: 360
Default
Originally Posted by Tim Folkerts
I could attach a simple example if it would help...Tim F
Let me fool with it a bit and see what I come up with.
Thanks guys!
Always learning...
Old 1st May 2006, 05:28 PM
Karma Power: 360
Default
The color formatting (I used red for 1st formatting: past due, and gold for 2nd formatting: dates within a week of due date) didn't work when the referenced date was more than a month away from any of the listed due dates.
Old 1st May 2006, 05:38 PM
tomvehoski tomvehoski is offline
Courtesy Access
Registration Date: May 2001
Karma Power: 67
tomvehoski is appreciated, and has over 1100 Karma points.tomvehoski is appreciated, and has over 1100 Karma points.tomvehoski is appreciated, and has over 1100 Karma points.tomvehoski is appreciated, and has over 1100 Karma points.tomvehoski is appreciated, and has over 1100 Karma points.tomvehoski is appreciated, and has over 1100 Karma points.tomvehoski is appreciated, and has over 1100 Karma points.tomvehoski is appreciated, and has over 1100 Karma points.tomvehoski is appreciated, and has over 1100 Karma points.
Default
Try this:
Condition 1:
Cell Value Is Less Than =TODAY() Format is Red
Condition 2:
Cell Value Is Less Than =TODAY()+7 Format Gold
Once a condition is met, Excel stops evaluating further conditions. So even though a past due gage is also less than today + 7, Excel never checks since condition 1 was met. Make sure you enter the = sign.
Old 1st May 2006, 05:59 PM
Karma Power: 360
Default
Thanks Tom! I will try that this evening I think.
Old 2nd May 2006, 01:10 PM
Dave Dunn's Avatar
Dave Dunn Dave Dunn is offline
Involved - Posts
Registration Date: Jul 2003
Thanks Given to Others: 1
Karma Power: 38
Dave Dunn is appreciated, and has over 500 Karma points.Dave Dunn is appreciated, and has over 500 Karma points.Dave Dunn is appreciated, and has over 500 Karma points.Dave Dunn is appreciated, and has over 500 Karma points.Dave Dunn is appreciated, and has over 500 Karma points.Dave Dunn is appreciated, and has over 500 Karma points.
Default
If the gages are listed in a long worksheet and have the calibration due date listed, you could sort the worksheet using the due date. That way you not only could find the ones that are overdue, but you could keep track of the ones that are coming due.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
5 Whys Template - Excel .xls Spreadsheet jrubio ISO/TS 16949 - International Automotive Quality Systems Standard 10 27th October 2009 04:15 PM
How do we calculate the control chart by using excel .xls spreadsheet? amanbhai Excel .xls Spreadsheet Templates and Tools 4 23rd February 2009 11:46 PM
Gage R&R Studies Excel .xls spreadsheet Carlos D. Excel .xls Spreadsheet Templates and Tools 8 29th June 2007 06:13 PM
Gage R&R Excel .xls Spreadsheet Problem mgoward Excel .xls Spreadsheet Templates and Tools 5 18th January 2007 06:05 AM
Basic TS 16949 Requirements in an Excel .xls Spreadsheet ranvir.jaryal Excel .xls Spreadsheet Templates and Tools 9 11th December 2006 07:33 AM
The time now is 05:03 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
