The Cove Business Standards Discussion Forums
Controlled Environment - Environmental Requirements for calibrations
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > > >
Forum Username
Wooden Line
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links Elsmar Cove visitors will find useful in the quest for knowledge and support:
Jennifer Kirley's
Conway Business Services
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Ajit Basrur
Claritas Consulting, LLC
International Standards Bodies - World Wide Standards Bodies
AIAG - Automotive Industry Action Group
International Organization for Standardization - ISO Standards and Information
Quality Digest
Reply
  Post Number #1
Old 4th May 2006, 04:48 PM
AlanJ_QA
Question Controlled Environment - Environmental Requirements for calibrations
I have proposed performing internal calibrations of caliers and micrometers. My supervisor has said that we can not do this because ISO 17025, section 5.3 requires a controlled environement. I need some references to published calibration standards to convince him that the ambient temperature, if within say 70 +/- 5 degrees F. and if that temperature is recorded at the time of the calibration, that we will meet all requirements of ISO, Dod, Etc.
Sponsored Links
  Post Number #2
Old 4th May 2006, 05:46 PM
Grizz1345's Avatar
Grizz1345
Temperature Standard
In ANSI/ASME B1.2-1983 Gages and Gaging for Unified Inch Screw Threads it states in paragraph 2.4.1 A temperature of 68 degrees F (20 C) is the standard temperature used internationally for linear measurements. --- For screw thread gaging, the acceptable tolerance on the standard temperature is 2 degrees F.
This is the generally accepted standard for calibration labs worldwide. Hope this helps.
  Post Number #3
Old 4th May 2006, 08:08 PM
Hershal's Avatar
Hershal
The typical accepted environmental parameters for dimensional calibration are:
20 C +/-1 C
30-50% RH
For more information, see NCSLI' RP-7 (Recommended Practice).
If you do internal cal, make sure your gauge blocks are sent to a laboratory accredited to ISO/IEC 17025 by an internationally recognized accrediting body to assure traceability, and that your procedures are documented and validated and personnel trainined, and that you have completed your measurement uncertainty calculations.
Traceability involves an unbroken chain of comparisons to SI through National or international standards, such as the standards maintained by NIST, and stated uncertainties at each step. This is according to the internationally accepted definitions in the VIM (Vocabulary of General and Specific Terms in Metrology).
Hope this helps.
Hershal
  Post Number #4
Old 4th May 2006, 08:30 PM
Jen Kirley's Avatar
Jen Kirley
In Reply to Parent Post by AlanJ_QA
Welcome to The Cove! These tools have a resolution of thousandths? Ten-thousandths? Tight calibration lab environmental controls are usually called out for tight tolerances or to control conditions subject to regulations. Being ISO registered in itsself doesn't require such tight controls in many cases.
Are your working conditions far outside the 65-75 degree range you specify? (Don't forget humidity!) I used to work in a machine shop that reached 90 degrees and 80 percent humidity. Arguably it would be foolish to calibrate the tools at a strict 68 degrees and 50% humidity because the difference between lab and shop floor would invite error. Do you see what I mean? But we measured in thousandths as a rule.
Your need for ISO 17025 controls is based on what? Customer requirements, contracts and regulations might call out a need for strict calibration control, but as I understand the standards they don't get that prescriptive.
Here's an article on calibration that I hope will help. http://www.qualitydigest.com/feb97/gagecal.html
  Post Number #5
Old 4th May 2006, 09:28 PM
Helmut Jilling
Many, if not most, companies I see calibrate (or verify) their basic hand gages like calipers and mics. If your tolerances are not especially narrow, the advice given above by Hershal and Jennifer should be adequate to meet your needs. If you work to very tight tolerances, you probably would not be using calipers in the first place.
  Post Number #6
Old 5th May 2006, 07:23 AM
apestate's Avatar
apestate
I also wonder why ISO/IEC 17025:2005 is being quoted by your manager. ISO 17025 does not apply to your activities unless you're using that standard.
If you are not calibrating calipers/mics in house, you're certainly not using 17025.
20 C +/-1 C
30-50% RH
Hershal, where is this standardized? I see "generally accepted" and wonder on what that is based.
  Post Number #7
Old 5th May 2006, 07:39 AM
harry
Daytime temperatures over here are about 27-30 degrees C and 32-36 degrees C outdoors. Calibration is usually done in air conditioned rooms of about 25 degrees C. Correction factors are then applied to cater for the difference between calibration room temperature and ideal temperature. If accuracy is important, the same correction table can be used to take care of the difference in ambient/shop temperature versus the temperature at which the instrument is calibrated.
Such tables are usually supplied with instruments for tropical climate.
  Post Number #8
Old 5th May 2006, 12:25 PM
Hershal's Avatar
Hershal
In Reply to Parent Post by atetsade
The standardization is documented in such locations as military requirements, NCSLI RP-7, and accepted international norms. It is certainly possible to calibrate outside the norms, but then the uncertainty values increase. Remember the gauge blocks are cal'd at 20 C, so if the calipers are cal'd at 25 C, then the 5 C difference is taken, divided by square root of three because it is a rectangular distribution, and included as one of the Type B contributions.
As for ANS/ISO/IEC 17025, for internal cal, it certainly does apply. ISO 9001 is woefully inadequate in the calibration requirements because that is not the intended purpose, where 17025 and ANSI/NCSL Z540-1-1994 are both intended to cover calibration activities. 17025 also covers testing activities, where Z540 does not.
Hope this helps.
Hershal
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Emoticons are On
[IMG] code is On
Similar Discussion Threads
Controlled Environment Procedure: Disaster Recovery Plan TCdavid ISO 13485:2016 - Medical Device Quality Management Systems 14 10th April 2015 05:43 PM
Clean Room as a Controlled Environment - Requirements Aphel ISO 13485:2016 - Medical Device Quality Management Systems 12 25th April 2014 03:03 AM
Cleanliness Requirements for Raw Materials Used in a Controlled Environment srrbell Quality Manager and Management Related Issues 4 19th March 2014 01:46 PM
Controlled Environment Classification ifserav Qualification and Validation (including 21 CFR Part 11) 1 3rd October 2013 07:35 PM
Medical Device Manufacturing in Controlled Environment? How to decide? Cardinal Fan Other Medical Device Regulations World-Wide 1 13th January 2012 01:17 PM
The time now is 08:07 AM. All times are GMT -4.
Misc. Internal Links
NOTE: This forum uses "Cookies"
