The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 17025 - General Metrology, Measurement Device, Calibration and Test Laboratories > ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories
Forum Username
Elsmar Cove Forum Sidebar
Custom Search
Monitor the Elsmar Forum
Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Sponsor Links
Sponsored Links
Courtesy Quick Links
Howard's
Atul's
Symphony Technologies
Marcelo Antunes'
SQR Consulting
Bob Doering's
Quality Digest Portal
Reply
Old 5th May 2006, 05:02 PM
Jerry Eldred's Avatar
Jerry Eldred Jerry Eldred is offline
Registration Date: Dec 1999
Thanks Given to Others: 7
Karma Power: 113
Jerry Eldred is appreciated, and has over 1700 Karma points.
Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.
Lots of very good info in all of the above posts, to which I don't disagree with any (not to mention that my specialty is not dimensional - although I have been in the business nearly 30 years).
The temperature issue with calibration of calipers is more an uncertainty issue (as the coefficient of expansion for your gage blocks comes into play). A legitimate method if calibrating away from 20 Deg C (68 Deg F) is to apply coefficients. HOWEVER, if that temp is away from 20 Deg C, I am guessing temperature stability is not good either. Therefore, since expansion and contraction of the gage blocks takes some period of time (one of you dimensional experts can fill in better on this), and IF your temp fluctuates, there is an increase in the instability of the actual value of each block.
Therefore, in such an environment, you may expect fluctuations in the actual performance of your gage blocks, and fluctuations in your calibrated readings (away from the true nominal). Using 68 Deg F as a reference temp for calibrations was established to improve the uncertainty of the calibrations. You might consider TRYING to achieve as close to 68 Deg F as possible even if your spec allows the deviation. In a lab where I used to work, we had a looser spec, but the dimensional guy surveyed and found the coldest spot in the room. He does the dimensional work there.
I don't believe matching the operating environment of the calipers is necessarily beneficial UNLESS there is a very predictable operational environment. For example, if they are alway used at 85 Deg F, calibrating them at 85 Deg F (including applying the coefficient to account for gage block expansion -- a miust) may potentially provide better calibration results. Problem is, because the calipers and gage blocks were designed around the 68 Deg F context, you may find readings are always a little skewed.
Again, you experts chime in on the following.... Am I correct the coefficients on ceramic blocks are better for unstable environments? If so, you may want to consider a different type block.
Okay. I haven't posted in a while and wanted to chime in about something. Have a great weekend everyone, and I hope I added some value to the discussion.
Sponsored Links
Old 8th May 2006, 12:21 AM
Hershal's Avatar
Hershal Hershal is offline
Metrologist-Auditor
Registration Date: Mar 2004
Thanks Given to Others: 1
Karma Power: 265
Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.
Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.
Hi Jerry, welcome back.
Good advice.
Hershal
Sponsored Links
  #11
Old 12th October 2009, 01:59 PM
hcnataraj hcnataraj is offline
Registration Date: Oct 2009
Karma Power: 15
hcnataraj has less than 100 Karma points so far.
Please Help! Re: Controlled Environment - Environmental Requirements for calibrations
Hello this is Nataraj,
What should be the intensity of light, noise level and vibration if we go for Lab Accreditation.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Controlled Environment Procedure: Disaster Recovery Plan? TCdavid ISO 13485 and ISO 14969 - Medical Devices - Quality Management Systems 11 18th August 2010 02:54 PM
Controlled Environment for Manufacturing Sterile Product - ISO 11137 sljcookie Other Medical Device Related Standards 2 3rd August 2010 11:16 AM
Inspection Room Environment - ASME standard which addresses environmental controls? Sonjia Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7 20th April 2006 04:50 PM
Information/Instruction Signs that refer to controlled documents - FDA Environment suziwann Records and Data - Quality, Legal and Other Evidence 5 9th August 2005 01:45 AM
Lab Environment Control Temp and Humidity gages have to be controlled and calibrated? JRKH ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories 3 14th June 2001 08:29 PM
The time now is 02:07 AM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, Olde West Chester, Ohio 45069-1929
513 341-6272
