5th May 2006, 02:29 AM
Registration Date: May 2006
Karma Power: 15 Karma: 10
Johnson's Transformation - Minitab 14 - How can I find out Ppk - Non-normal Distribu?
Hello all,
I used Johnson's transformation (minitab 14) to make non-normal data normal in order to get Ppk values for the data. However, there are a few sets that after the transformation Minitab doesn't display any Ppk values (and shows asterisk) although the data sets are normal (high P-value).
I haven't been able to find out the reason for this in Minitab help menu. Does anyone can help me with this? How can I find out Ppk for my non-normal data sets? Thanks.
5th May 2006, 09:18 AM
Registration Date: Apr 2002
Thanks Given to Others: 166
Karma Power: 251
Have you tried Minitab's Capability Analysis for Nonnormal distributions?
"A fool can learn from his own experiences; the wise learn from the experience of others." - Democritus, 460-370 B.C.
5th May 2006, 01:31 PM
Yes. I used minitab 14 to do capability analysis for non-normal data. With a few sets of my data sets I was successful in getting Ppk values,but some others I got Asterisk!!
Thanks for following up!
5th May 2006, 02:12 PM
Karma Power: 251
Can you attach a problem data set in Excel with the specifications? I have Minitab and will review the analysis.
5th May 2006, 11:15 PM
Thanks!
I have attached my data and would like to hear your opinion. But I know what the issue is now. However, I don't have a solution for it.
The data points are all positive numbers; however, limits are -0.2 and 0.2. The transformation algorithm has found Johnson transformation of k2 type curve, i.e. SB- bounded. Hence, during Ppk calculation, an attempt is made to find the log of a negative number by minitab!
Now, is there a way to force Johnson transformation to use k1 type of transformation (SU- unbounded)?
P.S. For some reason I get an error during uploading the excel file. I am typing in the data pooints. There are 16 data points only. The lower and upper limits are -0.2 and 0.2.
0.04799
0.05253
0.0863
0.04157
0.04107
0.0443
0.0611
0.04784
0.05961
0.03917
0.04512
0.05762
0.05059
0.04037
0.0421
0.05436
Thanks for your effort!
6th May 2006, 09:49 AM
Karma Power: 251
I did some analysis with this data, but I would hestitate to draw a conclusion with only 16 data points. Since many non-normal distributions cannot have values less than zero, and your tolerances indicate that it is very possible to have negative values, it would help to have a larger data set that includes a few of these negative values (naturally occurring).
When I review the histogram, I am very reluctant to accept the results of the test for normality because small shifts in a few of the extreme values result in a conclusion for Normality. If you double the number of data points, you may reach a totally different conclusion.
6th May 2006, 05:55 PM
Thanks for your replies and anaylsis.
I have also been reviewing the data myself. And I am questioning the stability of the process.
I have read your reply a few times, and a sentence in the reply is not very clear to me. You wrote, "Since many non-normal distributions cannot have values less than zero, and ..." Are you saying if a distribution is naturally unbounded, and the target is the middle of the tolerance zone, a normal distribution should be expected otherwise the validity of data points is in question? Or the word "many" in the sentence allows for non-normal distributions in this situation for very rare and special cases?
6th May 2006, 09:13 PM
Karma Power: 251
No. Many of the nonnormal distributions available to try to fit the data have a lower limit. This is the same issue that you encountered trying to take the log of a negative number.
Since your process does not have a lower limit, it does not make sense to fit the data with a distribution that does have a lower limit. For example, I fit the data very well using an exponential distribution. However, this distibution showed that the data had a lower limit that could not be passed. The reality of the process says that this cannot be true. Therefore, using this distribution, no matter how good the fit is the wrong thing to do. Always do a reality check.
I believe that the situation that we are seeing is that the small sample size does not accurately reflect the parent population. A larger sample size would better reflect this population and may actually be a normal distribution.
Nonnormal distributions "typically" have an underlying cause that becomes easy to understand in hindsight. For example, machining operations that run to a hard stop or on cams, will almost always be skewed. There will be a high mode near the hard stop with a tail extending in the direction before the hard stop is reached. Form tolerances such as flatness may be normal when they are far from zero, but as flatness is reduced, the physical limit/boundary of zero will impose a more and more skewed distribution as the mode is shifted closer to zero. Physical test results may often be skewed with the tail to the high side. You always seem to get a few test results where everything just seem to work out perfect and the results were extraordinarily good.
