9th May 2006, 07:03 AM
Involved - Posts
Registration Date: Mar 2006
Karma Power: 15 Karma: 20
Regression Analysis - Understanding the Regression Analysis Concept - Springs
Sir/Mam,
Any one briefly explains about the regression analysis concept
Quality Journey,
Senthil Kumar
9th May 2006, 08:25 AM
Dogs rule
Registration Date: Jul 2002
Thanks Given to Others: 15
Karma Power: 69
There is no psychiatrist in the world like a puppy licking your face. - Ben Williams
9th May 2006, 08:54 AM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Good link.
Summary: In statistics, regression analysis is used to model relationships between random variables, determine the magnitude of the relationships between variables, and can be used to make predictions based on the models.
9th May 2006, 11:17 AM
Involved - Posts
Regression Analysis
Originally Posted by Marc
Good link.
Sir ,
Thank u for ur kind reply,we are the spring manufacturer for the oil seal.
The process for making the spring - winding the coil on the mandrel with a required diameter ,the resultant coildiameter involves the addition of spring back property.
Now we try to express the relationship between the mandrel diameter to coil diameter based on the material type of spring wire.
I need the details for planning the experiment,If required I send the technical details also
Quality Journey,
Senthil Kumar
31st August 2006, 05:01 AM
Registration Date: Oct 2005
Karma Power: 17 Karma: 10
Re: Regression Analysis
hi senthil,
Do you have any training material on spring manufacturing? I just want to know more about this. Can u please forward me through mail? my id is meeranahamed - at - hotmail - dot - com
31st August 2006, 05:09 AM
Karma Power: 605
Originally Posted by ahamed
hi senthil,
Do you have any training material on spring manufacturing? I just want to know more about this. Can u please forward me through email?
Or, better yet, can it be shared here by posting as an attachment to a post?
26th October 2006, 06:38 AM
Registration Date: Jun 2005
Karma Power: 18 Karma: 10
Re: Regression Analysis - Understanding the Regression Analysis Concept - Springs
hi, i think my concern is somewhat similar to his concern only that I plan to use linear regression analysis in determing the lifespan of a certain machine part. do you know a method or process on how i will be able to determine the variables (independent or dependent) to measure so that i could create a realistic result?
thank you guys for any help.
26th October 2006, 09:25 AM
Registration Date: Apr 2002
Thanks Given to Others: 166
Karma Power: 251
You need to provide additional information on what you are attempting to accomplish. On the surface, that fact that you are dealing with the life of a product indicates that you may need to use a reliability method such as weibull analysis over regression. If you provide more detail, we can better assist you.
"A fool can learn from his own experiences; the wise learn from the experience of others." - Democritus, 460-370 B.C.
