17th May 2006, 11:33 AM
E-Mails Invalid or Rejected
Registration Date: Mar 2005
Karma Power: 0 Karma: 10
Using AQL to get true random sampling using General Inspection Level II
OK, say I have 20000 pieces in an order, and if I'm using General Inspection Level II, I will need to inspect 315 pcs.
Now, say those pieces are in boxes of 50. So there are 400 boxes. How many boxes would I sample to get a good random sample and representation of the shipment? Could I use an GI Level II again? Which would mean I would have to open 50 boxes.
17th May 2006, 11:50 AM
Courtesy Access
Registration Date: Jan 2005
Thanks Given to Others: 755
Karma Power: 611
It's not that easy. For the sample to be truly random, each member of the population must have an equal chance of being selected. The situation you describe is the reason that actual random sampling is rarely done, but the integrity of the sampling plan is out the window unless randomness is assured.
17th May 2006, 12:00 PM
Registration Date: Sep 2003
Thanks Given to Others: 27
Karma Power: 123
I just checked the expected results if the sample was truly random. In that case, you would expect to check (approximately): - 0 items in 180 of the boxes
- 1 item in 145 of the boxes
- 2 items in 57 of the boxes
- 3 items in 15 boxes
- 4 items in 3 boxes
This would say that a truly random sample would require opening (about) 220 of the 500 boxes.
Tim F
17th May 2006, 12:08 PM
Courtesy Access
Karma Power: 611
But you can't work backwards in the actual sampling process (i.e., you can't assume that if you open 220 boxes that you've done random sampling).
An actual random sample might require all 500 boxes to be opened, or some (random) number equal to 500 - x. Unless you're prepared to uniquely identify each part and use a random-number table, you're not doing random sampling.
17th May 2006, 12:27 PM
Consultant
Registration Date: May 2005
Thanks Given to Others: 36
Karma Power: 43
Boxes are not usually random, as they usually represent time order of the process. If you need to sample 315 pieces, I would create a random number generator that gives me 315 numbers between 1 and 500. If you allow for replicates, you might sample more than 1 part in a given box.
You can never get a true random sample, so you have to assume you get the best representative sample.
Steven Walfish
When in doubt, ask your company statistician!
