Go Back   The Elsmar Cove Forum > Manufacturing, Service, and Business Systems Processes > Reliability Analysis - Predictions, Testing and Standards
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 24th May 2006, 03:56 PM
CanuckTester CanuckTester is offline
Registration Date: May 2006
Karma Power: 15
CanuckTester has less than 100 Karma points so far.
Please Help! Master Validation Frequency in production - Absence of leak, thread presence, etc.
Good Afternoon,
I work for a Tier 1 automotive supplier in South Western Ontario. We have end-of-line test/assembly machines to verify a few of the features on the parts(absence of leak, thread presence, backpressure). The settings for these testers are validated once per shift using a 'mastering process'. The master process consists of running several parts with conforming and nonconforming features, and validating whether or not the testers detected all of the features. If the master parts do not pass/fail as required, then we initiate containment on the parts produced prior to the 'mastering procedure'.
My question has to do with the required or recommended frequency of the mastering process. How do I compute the required frequency? I realize that I have not provided data on the actual capability of our process, but I am not so interested in a specific number as I am in the process of arriving at the number. I would really appreciate any suggestions that you may have!
Sponsored Links
Old 24th May 2006, 06:21 PM
Miner's Avatar
Miner Miner is offline
Registration Date: Apr 2002
Thanks Given to Others: 166
Karma Power: 251
Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.
Default
This is normally more of a risk assessment than a true calculation. The interval of mastering should be based on how much material would have to be quarantined in the case of a failure as well as any further processing or possible shipment. A typical approach in calibration is to establish a frequency, monitor the results for out-of-cal occurrences and reduce the interval as appropriate.
If the test provides variable results when mastering, and slowly drifts out of range, you could collect data over time, then perform a regression of results versus time to calculate a time interval to recheck.
"A fool can learn from his own experiences; the wise learn from the experience of others." - Democritus, 460-370 B.C.
Sponsored Links
Old 24th May 2006, 10:06 PM
Karma Power: 15
Lightbulb
Thank you, Miner!
That sounds like a reasonable approach! I think that I will record the number of times that the masters pass/fail on each machine at our current master frequency, and determine the occurence of parts shipped defective for each test (if any) as well as the severity of each defect.
Old 26th May 2006, 09:10 AM
Statistical Steven's Avatar
Statistical Steven Statistical Steven is offline
Consultant
Registration Date: May 2005
Thanks Given to Others: 36
Karma Power: 43
Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.Statistical Steven is appreciated, and has over 700 Karma points.
Send a message via Yahoo to Statistical Steven
Default Mr
Originally Posted by CanuckTester
Good Afternoon,
I hope you are not just adjusting the process every shift. That will lead to overcontrol, and an increase in variability. I would suggest you "sample" once per shift but only make adjustments to the process when a measurement is out of control. Just my
Steven Walfish
When in doubt, ask your company statistician!
Old 29th June 2006, 03:09 PM
Karma Power: 15
Default Re: Master Validation Frequency in production - Absence of leak, thread presence, etc.
I have found the answer to this question in this forum! I reviewed some of the threads, and found the thread referring to the NCSLI RP-1 Method A3 test for determining calibration intervals. Our mastering process is really a type of calibration of our test equipment, and so we can establish an interval statistically by collecting data on the frequency of pass/fail for each check, and then settig our confidence and reliability targets. This can be done using the Freeware on the IGS website. Essentially, you pick a calibration interval, record pass/fail counts, and use that data to verify your interval.
I have attached the relevant link to the calibration interval discussion.
http://elsmar.com/Forums/showthread....ight=method+a3
Again, a few other things will play into the interval such as containment cost and environmental effects on the test system.
www.igsmax.com
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
IQ, OQ, PQ and Validation Master List JJLit Qualification and Validation (including 21 CFR Part 11) 10 2nd November 2009 11:46 AM
Master Validation Plan - What must be included in a "Master Validation Plan"? SK Vision Qualification and Validation (including 21 CFR Part 11) 5 3rd September 2009 02:19 PM
Leak Test - Building a master pump to calibrate pump tester gagelady Inspection and Test, Sampling and Related Topics 4 25th June 2008 08:09 PM
Method Validation for qualitative tests (specifically Absence/Presence) Shimmer ISO 17025 - Calibration, Measurement Gages and Test Laboratories 2 11th June 2008 01:45 PM
Thread Presence Detection - What are companies using? mkbagwell Manufacturing and Related Processes 18 1st April 2008 08:49 AM
The time now is 05:31 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
