Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Documentation Control Systems, Procedures, Forms and Templates
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 22nd July 1998, 01:12 AM
Alicia
Unregistered Guest
Posts: n/a
Default Online Documentation
The company I am working for is considering ISO certification. We have some general questions about establishing an online documentation system using Intranet.
First of all, is it easier to begin with hardcopy control and then convert to online when we get used to document control or should we go online from the beginning?
Second, how are documents controlled? Using passwords to access documents for changes? But anyone can still print the documents and they are uncontrolled right? How can we indicate this?
We have many other questions, but I guess this is a good start!
Sponsored Links
Old 22nd July 1998, 09:24 AM
Roger Eastin Roger Eastin is offline
An Original Cover!
Registration Date: Dec 1998
Karma Power: 54
Roger Eastin has less than 100 Karma points so far.
Default
In my opinion, the first step should be to define your document control system regardless of whether you're going electronic or paper. That's the hard part. The technical solutions for an electronic system can be found (for instance, if most of your documents are in Word, then you can use a combination of the "routing slip" and "cut-and-paste" as a way to do review and approval). However, defining your system up front will guide you into solutions for implementing doc control. There are many innovative ways of doing doc control, so be sure to define the system for what will work for you!
[This message has been edited by Roger Eastin.]
Sponsored Links
Old 22nd July 1998, 11:03 AM
Scott Knutson
Unregistered Guest
Posts: n/a
Default
Personally, I'm a big proponent of online documentation. In my book, it makes it much easier. You can lock out those you don't want making changes; you can set it up for easy review and approval; you can declare that any hard copies, i.e. printed, are uncontrolled. There are myriad uses with an electronic system. But that's not the only way to go. I know of a company who has a totally manual system based on the color of the paper. One color is controlled, the others are not. So it depends on what you want to do. Like Roger said, you should define your systsem first, then decide if you want to go electronic or not. Hope this helps.
Old 26th January 2001, 03:46 AM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,894
Karma Power: 604
Read This!
Also see http://Elsmar.com/ubb/Forum7/HTML/000093.html
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Feedback System (8.2.1) - Requirements for "..establishing a documented procedure..." QRCEC ISO 13485 - Medical Devices - Quality Management Systems 5 22nd July 2007 06:34 PM
Good implementation and documentation class - Is there an online class? rharold Training - Internal, External and Distance Learning 15 10th July 2006 06:31 PM
Moving to Intranet QM (Quality Manual and Documentation) - Recommendations? Russ ISO 10013 - Quality Management System (QMS) Manuals 19 27th April 2005 09:55 AM
AS9100 vs. AECMA vs. Oasis (Online Aerospace Supplier Information System) Angelika AS9100 Aerospace Standard and Requirements 1 5th November 2004 06:35 PM
Establishing/Revamping Training system Rajman ISO 9001:1994 6 1st February 2001 03:33 PM
The time now is 08:23 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
