Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
28th May 2006, 07:03 AM
Registration Date: May 2006
Karma Power: 29 Karma: 15
Procedure vs. Work Instruction (WI) - What is the difference?
What is the difference between procedure and work instruction?
Thanks to eramanath for your informative Post and/or Attachment!
28th May 2006, 10:24 AM
Forum Administrator
Registration Date: Jul 1997
Thanks Given to Others: 142
Karma Power: 400
In Reply to Parent Post by eramanath
Welcome, this thread is just for introductions.
Try here to start with
SOPs (Standard Operating Procedures) vs. Policies, procedures and work instructions
and search the various forums
Good hunting
Lean starts with your documentation
Save trees
Thank You to Howard Atkins for your informative Post and/or Attachment!
1st June 2006, 01:34 PM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 7,441
Karma Power: 400
See the thread Howard linked to. Usually the procedure is a higher level document but one can argue that they are the same and that their use is semantics.
One Test is Worth 1000 Expert Opinions - The plural of anecdote is not data - Correlation does not imply Causation
1st June 2006, 02:26 PM
Registration Date: May 2003
Thanks Given to Others: 693
Karma Power: 234
In Reply to Parent Post by Marc
...one can argue that they are the same and that their use is semantics.
I don't personally care what they're called - but because some do - I always say:
Procedures - tell you who does what when.
Work Instructions - tell you how to do something.
First thing each morning, I try on my bathing suit. Then, nothing worse can happen the rest of the day.
Thank You to Cari Spears for your informative Post and/or Attachment!
Registration Date: Jun 2000
Thanks Given to Others: 472
Karma Power: 280
You can also scroll down to the bottom of this page for links to similar threads.
CarolX
Theater is life, film is art, and television is furniture.
1st June 2006, 02:27 PM
Involved in Discussions
Registration Date: Jan 2005
Karma Power: 36 Karma: 70
Make your own definition
In few older quality system documents I have helped develop in the past we have used the discriminating criterion that procedures are documents that explain inter- departmental activities while work instructions are activity specific instruction to be carried out usually by a single associate or by a small team within one department.
With the process focus introduced with the 9K2k version, this discrimination is insignificant.
1st June 2006, 03:31 PM
Dirk
Registration Date: Jun 2004
Thanks Given to Others: 410
Karma Power: 153
Not sure it matters
I am not sure it matters what the difference is between a procedure and a work instruction but I use the EXACT same terminology as Cari Spears. Word for word. The only thing I add is that "Who" means title or department not actual name. "When" generally means in what sequence, not clock time.
Regards,
Dirk
1st June 2006, 03:39 PM
Karma Power: 234
In Reply to Parent Post by vanputten
... "Who" means title or department not actual name. "When" generally means in what sequence, not clock time.
Exactly.
Forum Posting Settings
Similar Discussion Threads
| Discussion Thread Title |
Thread Starter |
Forum |
Replies |
Last Post or Poll Vote |
How do you decide what is a Process, a Procedure or Work Instruction?
plastic |
Documentation Control Systems, Procedures, Forms and Templates |
82 |
16th November 2012 09:00 PM |
Process Flow Chart is a Work Procedure or a Work Guide, or a Work Instruction
jm1231 |
28 |
8th March 2012 11:52 PM |
Can a WI (Work Instruction) be alone without depending on a Procedure?
QAMTY |
ISO 9000, ISO 9001, and ISO 9004 - Questions and Discussions |
5 |
30th September 2011 05:02 AM |
What is the difference between a Procedure and a Work Instruction?
abcauto |
2 |
15th July 2010 07:29 AM |
How do you reference a WI (Work Instruction) to a procedure?
mickeld - 2005 |
16 |
18th June 2004 10:07 AM |
